Question about Logitech Cordless Mouse
Loss of control over my mouse.
The mouse intermittenly, although increasingly more often, seems to lose responsiveness which causes the cursor to move erratically and become unresponsive. It also sometimes performs a right click function when I use the left mouse button as well as behaving as if I still have the left mouse button pressed (ie highlighting text etc)
  • 1,498 Answers
Hi Arsenal,
My Logitech cordless occasionally does the same thing. On mine it was caused by a build up of gunk over the optical sensor. Once I cleaned it, it functioned normally.
I know it doesn't make sense as far as the buttons. I'm just sharing what worked for me. Hope it works for you.
Best regards
Mike
Posted on Jul 29, 2010
I changed the battery on my mouse and although the light comes on the mouse it will not move the cursor. Any suggestions?
You need to try restarting your computer and make sure that your receiver is plugged into your computer. I have this issue from time to time and this solves it.
Jan 23, 2011 | Logitech Cordless Mouse
The computer reads the mouse and the usb thing as working properly but the when i move the mouse the cursor stays there so basically my mouse isnt responding at all
Hello Dear... Mouse cursor don't response, It possible your usb port fail to response because one of your usb drivers is missing ...To find out about it please, check in your setting control panel, click on system then on hardware then on device manager.. it will show a yellow icon ...this icon need to be install or re-install due to corrupt file inside your machine...To fix that problem delete that icon and restart your PC then your pc will ask you to insert you windows CD to re-install the corrupt file for your usb controller..
Oct 15, 2010 | Microsoft Wireless Notebook Optical Mouse...
Sir, i want to know about the optical mouse in detail. what is the important point of it to use. thanks, tin
Optical mouse was developed by Agilent Technologies and introduced to the world in late 1999, the optical mouse actually uses a tiny camera to take 1,500 pictures every second. Able to work on almost any surface, the mouse has a small, red light-emitting diode (LED) that bounces light off that surface onto a complimentary metal-oxide semiconductor (CMOS) sensor.
The CMOS sensor sends each image to a digital signal processor (DSP) for analysis. The DSP, operating at 18 MIPS (million instructions per second), is able to detect patterns in the images and see how those patterns have moved since the previous image. Based on the change in patterns over a sequence of images, the DSP determines how far the mouse has moved and sends the corresponding coordinates to the computer. The computer moves the cursor on the screen based on the coordinates received from the mouse. This happens hundreds of times each second, making the cursor appear to move very smoothly.
Optical mice have several benefits over wheeled mice:
No moving parts means less wear and a lower chance of failure.
There's no way for dirt to get inside the mouse and interfere with the tracking sensors.
Increased tracking resolution means smoother response.
They don't require a special surface, such as a mouse pad.
Although LED-based optical mice are fairly recent, another type of optical mouse has been around for over a decade. The original optical-mouse technology bounced a focused beam of light off a highly-reflective mouse pad onto a sensor. The mouse pad had a grid of dark lines. Each time the mouse was moved, the beam of light was interrupted by the grid. Whenever the light was interrupted, the sensor sent a signal to the computer and the cursor moved a corresponding amount. This kind of optical mouse was difficult to use, requiring that you hold it at precisely the right angle to ensure that the light beam and sensor aligned. Also, damage to or loss of the mouse pad rendered the mouse useless until a replacement pad was purchased. Today's LED-based optical mice are far more user-friendly and reliable.
Thanks and regards,
Anil.B.R
Aug 18, 2010 | Computers & Internet
Mouse Cursor Jumping while typing causing major typing errors
Reinstall the Mouse Drive rplease and it should work.
Please write abck if you still face problems.
Jul 01, 2010 | Lenovo 3000 Y410 Laptop
My wireless mouse - cursor refuses to follow sometimes!
Try cleaning the lazer on bottom with a q tip with some rubbing alcohol on it. Check to make sure the reciever for the mouse isn't too close to any wireless router,phone,or microwave. In the control panel there are mouse settings you can play with too to see if that makes a difference. Re-install any software for the mouse.
May 12, 2010 | Computers & Internet
Cursor jumps around
Does the cursor jump around when your hands are nowhere near the touchpad? The touchpads are heat and pressure sensitive. I personally have very warm (and sometimes sweaty) hands. I have this problem often when working on laptops. If I hover my hands over the pad, it causes the mouse to move. I've had to take a business card, put tape on one side of it, and use it as a flip-cover for the touchpad on most of my laptops. If the cursor moves around when you're nowhere near the laptop, then you may want to try disabling the pointing stick (if it has one). I've had several clients with laptops where the pointing stick mouse control go crazy and move and click on things.
May 13, 2009 | Dell Inspiron 1420 Laptop
USB mouse is jittery
Try the mouse on a different surface, also be sure you do not have any light directed at the mouse - this confuses the eye. Although no mouse pad is required for an optical mouse, sometimes it helps
Apr 01, 2009 | HP USB Optical Scroll Mouse
Cursor jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
  1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
  2. Adjust the sensitivity of the touch pad:.
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
  3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
Aug 14, 2008 | Computers & Internet
Lapptop touch pad not responsive
hii srm-mom ....
see jst fallow wat i m sayin....
go to start option>control panel>printer n other hardware>mouse
here u can set urs mouse speed n urs mouse pointer....
if u r not able to see ny mouse pointer choose diffrent pointer..
if irs mouse speed is slow u can increase it also...
try dis tell me.....
dis settting for windows xp nly....
if ur usin vista same as it but sm diffrent..
thanks...
Jun 22, 2008 | Toshiba Satellite A135-S4527 Notebook
Logitech mouse problem
sounds like you have reverse mouse enabled  go into the control panel find the properties for you mouse, this should be a check box you can disable.
Oct 24, 2007 | Logitech Cordless Desktop MX3200 Laser...
Logitech Cordless Mouse Logo
904 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
