Question about Dell WL6000 Computer Speakers
I had sound last night and then there was none. I have an x on the bar below where the speaker is located. the no audio device installed and re-installed it. So now what next?
    Problem Solver:
  • 8 Answers
This problem actually happened to me. A lot of people have this same problem and find that downloading the appropriate sound or audio controller fixes the problem. You can do this by searching for 'Dell WL6000 sound driver downlaod' or 'Dell WL6000 audio controller download'. This should fic the problem. However, for me, is did not. So I did a bit of reasearch on the internet, and found that actually, there is no way of restoring sound on the computer; not even re-installing windows, or a new windows package. I tried this, but it didn't work. This is becazuse once the sound is gonefrom the computer, it is permanantly gone. What you have to do, is purchase a new sound card.
Hope that helps,
pennywise25.
Posted on Aug 06, 2010
I have a VSB200. It worked until last night. No sound coming out of it now.
I have the same sound bar and in the middle of watching a movie, it just stopped working. I came to the conclusion that it was the optical hookup on the back of the speaker that had an issue. The problem with the entire situation is that I had only owned the sound bar for around two to three weeks and only watched around four movies on it until this problem. Either a fluke or bad quality. Check your optical connection if that is what you have it hooked up to.
Apr 28, 2011 | Vizio VSB210WS Soundbar
I am using hp pavillion dm4 1009 tu laptop and there is very less sound coming from speaker which is like unable to hear....... can u plz advise me on this.
You will need to adjust the device volume.
Go to Start>Control Panel>Sounds and Audio Devices
Then make sure the slider bar below the Device volume heading is all the way to the right (As close to the High setting as possible).
Then make sure the box next to Place volume icon in the taskbar is ticked. And the Mute box is unticked.
If you click on Advanced it will take you to all the Master Volume settings make sure these aren't muted where possible and check that the little slider bar is in the middle of the two speaker icons.This will make sure sound will come out of both speakers and not just the left or right one.
If these are already set and you still get faint sound then you should try re-installing your laptops audio driver.
Mar 14, 2011 | Computers & Internet
Thier is no sound coming out from my pc. i HAVE INSTALLED my realtek AC'97 sound driver. but their is still no sound.
Have you connected the speakers correctly. When you connect the cord to the ports on the back do you get a popup asking what has been connected and there are options for headphones,line-out etc. Can you see a speaker icon in the status bar? The area with the time on it. Double clicking will bring up the audio properties. Check the volume levels for all like wave,sw-synth etc an check if none of them are muted and even check the main volume , last but not least check the volume on the external speaker or headphones , could be that they are set low.
Hope this helps..
Mar 02, 2011 | Computers & Internet
My lap sound problem..
Some things you need to check
1. Cable connection of the speaker to your computer and the power cable if its plug in correctly. Normally the Audio cable of the speaker is plugged into the green audio port on the computer.
2. You speaker is on mute. Check the speaker icon located on the lower left side of you desktop. If its on mute then try to un-mute the volume and test the speaker.
3. The driver is not installed properly. Check the device manager if there is a Question/Exclamation mark on the Audio devices.
4 If everything are Ok. try to plug the Audio cable of the speaker to any of your Portable sound devices like Ipod. If that still does not work then you need to replace the soundbar. Contact Dell for a free replacement if still under warranty.
Thank you.. Hope this helps..
Jan 04, 2011 | Dell AS500 Sound Bar Computer Speakers
I have just installed speakers on my computer, but I can't get any sound.
Check to make sure the speakers power up.
Check to make sure you have installed the speakers into the correct jack on the back of the PC.
Go into Control Panel and check the settings by double-clicking the "Sounds and Audio Devices" icon. Make sure the Mute box isn't checked and that the volume is turned up.
Dec 09, 2009 | Dell Dimension 4600 PC Desktop
My speaker is muted - no sound on my HP Pavilion zv5
This sounds as though there may be a problem with the driver for the sound card within the computer.
If you enter the device manager (found in control panel) you can update the drivers for this device from within there :o)
Aug 30, 2009 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Speakers only play cd's
Please look in your Start Menu, go to Control Panel, then into Sounds, Speech and Audio Devices. See near the left, and select Advanced Volume Control. Turn up the inputs for the other sounds that you want delivered out to those speakers. Later adjust the levels a little higher if at first the mix of the sounds is not quite loud enough from one or several of the sound sources. Also in Control Panel, Sounds, you can mute out or eliminate annoying unwanted system sounds such as sounds for minimize and maximize a computer window, and the click that occurs when the computer does Complete Navigation -which it does a lot. Go into Sounds and Audio Devices, and into the Sounds tab. Select the Windows Program event such as default beep and click pick NONE from the sound chooser scroll bar that is just below. Scroll up to NONE to eliminate that sound. Now your overall sound experience will be more pleasant, without unneeded sounds playing loudly, unexpectedly.
Feb 24, 2009 | Bose Companion 2 Computer Speakers
No sound on pc
First plug the speaker pin in the back panel and then in the front panel of PC .
If u receive sound in any Panel.. then, may speaker settings in software is not proper... adjust it from the audio software icon in the task bar.. near the clock.....If not then, the that panel got fault...
call local technician
Or Re install audio driver & restart!
Dec 28, 2007 | Acer Aspireā„¢ T180 PC Desktop
Dell WL6000 Computer Speakers Logo
120 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
