Question about Epson Stylus Photo R800 InkJet Printer
When i print my photo's from the files on my laptop ,they print out with lines through them. i use the correct printer ink . the printer is an epson stylus 4450
  • 415 Answers
Try a nozzle check then head cleaning and then printer head alignment ,
and see what happens,
Posted on Jul 29, 2010
New cartridges, letters in misalignment and double struck words
What Causes a Printer to Be Misaligned? ' Chron.com
smallbusiness.chron.com > ... > Setting Up a New Business Basics
A printer that has alignment problems will not print documents accurately. images and text ... Install new manufacturer's cartridges in the printer. If the cartridges ...
How to Replace & Align Canon Ink Cartridges ' Chron.com
smallbusiness.chron.com > ... > Computers
Misaligned cartridges cause poor overall print quality by producing print lines slightly... Remove the new cartridge from its packaging and remove the colored ...
PDF]Stylus Photo R300 / R300M - Product Information ... - Epsonhttps://files.support.epson.com/pdf/r300__/r300__pg.pdfEpsonEPSON Stylus Photo R300 Series - 1. Printer Parts ... asterisk (*). The printer also works with plain paper. Cartridge. Part number. Black. T048120 ... Letter. SCR1001. PremierArt Matte. Scrapbook Photo Paper for Epson. Letter ..... Unwrap the new inkcartridge. .... misaligned, align the print head (see page 11). Related ...[PDF]Epson Stylus NX430 - Quick Guidehttps://files.support.epson.com/pdf/nx430_/nx430_qr.pdfEpsonAfter you set up your Epson Stylus® NX430 (see the Start Here sheet), turn to this Quick. Guide and ..... Load letter- or A4-size paper in the sheet feeder. 2. Press ... Use the following list when you order or purchase new ink cartridges: Note: We ..
Jan 05, 2016 | Office Equipment & Supplies
Printing Streaky
Most likely the printer has been sitting for along time not used or you have used cheap replacement ink. Epsons are notorious for clogging the jets with cheap ink. unfortunately replacing the ink cartridges will not help because the jets are seperate from them. If cleaning numerous times does not work your next best bet is to buy a cleaning ink cartridge for your model. otherwise youll need a new printhead or new printer. If your going to use cheap replacement cartridges stay away from epson.
Jun 16, 2009 | Epson Stylus Photo R320 InkJet Printer
Epson 1400 won't print blacks
Hi
Many problems regarding Ink with Epson relate to using cheap ink consumables. I recommend you buy original Epson black ink catridge. I know its more expensive but you should see the black ink clear.
Be sure to run head alignment and clean printer option first with the current black ink then replace with the new original Epson ink catridge
Thanks
Andy
Jun 14, 2009 | Epson Stylus 1400 InkJet Photo Printer
Epson 2200 - vertical lines
I don't know if this will help as my printer is a different model (the epson stylus photo r280) but I have been battling the vertical line issue for weeks, ever since getting a new imac. I am printing altered photos from photoshop on epson ultra premium matte photo paper. After trying every conceivable setting, and spending an hour with less than helpful tech support from epson (where they insisted I needed to download new drivers) I just resolved it this morning at last by increasing the dpi setting on the print function to beyond what I would normally use(1440x 1440 rather than what I had been using at 720).
The prints came out great at last!
On my older computer with this same printer the prints came out fine at the lower setting. But for some reason it appears that the higher setting is now necessary to eliminate those dreaded lines.
I hope this helps.
Feb 03, 2009 | Epson Stylus 2200 InkJet Photo Printer
Printing lines across the picture
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Overview&oid=90584
Q: How can I tell if the computer or the printer is causing a print quality problem? A: You can print a nozzle check pattern to determine whether the print quality problem is caused by the Epson Stylus Photo RX680 Series or some other source.
Above under FAQ
Dec 10, 2008 | Epson Stylus RX680 Color All-in-One InkJet...
Epson R265 Printer
2. TRASH and REINSTALL the drivers
3. Try a different application and file
4using a PHOTO PRINTER (Stylus PHOTO) try to set the QUALITY OPTION to BEST PHOTO or PHOTO RPM
5. Go to PRINTING PREFERENCES and hit ADVANCE
6. Choose the right PAPER TYPE, SIZE and SOURCE then disable HIGH SPEED
7. Once all those are set choose PHOTO RPM under the COLOR MANAGEMENT box and try printing
8. This will print a lot slower but will be using alot of ink and eliminate the lines
Apr 04, 2008 | Epson Stylus R265 InkJet Photo Printer
Lines Lines Lines
Rollers etc not issue.... Head issue if using correct epson branded inks, 12month warranty take to epson dealer with proof of purchase.
Dec 17, 2007 | Epson Stylus Photo R260 InkJet Printer
Poor 'photos .
No this is not normal for your machine.
If you are CERTAIN you have all the settings set correctly in the printer and driver and you are using genuine ink then should expect photo quality prints.
If the you are CERTAIN the settings are correct and the machine is in warranty you need to contact Epson for a warranty claim. They will talk you through some basic tests on the phone ( make sure you have a full of inks available) and if you experience no improvement they should exchange the machine.
Dec 01, 2007 | Epson Stylus CX6600 All-In-One InkJet...
My printer doesn't want to respond
This is an illustrator/spooling problem. Reinstall the printer following the correct Epson procedure - Epson is very fussy here. Come off line/Disable A/V software -blah blah
Apr 26, 2007 | Epson Stylus Photo R1800 InkJet Printer
Epson 1280 red lines on photo
One of the best possible solution that we can suggest is to run a cleaning cycle for three times. Just to make sure that cleaning is effective please try the step below:
1. Using your computer go to printer utility.
2. Click on Maintenance then select Head Cleaning. Head cleaning usually took 1 minute.
3. Once the Head Cleaning is done Print a nozzle pattern to check whether the head cleaning is effective or not.
Repeat those steps for 3 times. If the nozzle pattern after 3 cleaning cycles still bad. Reseat ink cartridge if possible replace the ink cartridges.
After all those steps and issue still present printer needs to be in service.
Aug 05, 2006 | Epson Stylus Photo 1280 InkJet Printer
Epson Stylus Photo R800 InkJet Printer Logo
82 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
