Question about GE 24 in. Profile PDW9880JSS Built-in Dishwasher
Leaking dishwasher Model # PC30169 year 2001 GE profile. The dishwasher leaked, we replaced t;he bottom door seal.and it still leaks. We recently replaced our sink and garbage disposal...could an;y of these be the problem? Neal
  • 1462 Answers
SOURCE: Leaking door (Running Water)
being in the uk i dont know this appliance, but the fault is probably that it is overfilling caused by crap in the airchamber or the hose leading to the pressure stat blocked or a split in this hose
Posted on Apr 15, 2007
  • 1314 Answers
SOURCE: Dishwasher drains into sink
im going to try to help but cant quite understand what your talking about is this a portable or built in washer just reply it will e mail me
Posted on Jan 01, 2008
SOURCE: Bad smell
Most problems with smells in Bosh Dishwashers come from failure to have the 20" rise in the drain line between the dishwasher and the drain as the installation manual requires.
My factory installer failed to do this. After looking at the installation manual, which shows a 20" rise, I used electrical ties to hold the drain line 20 inches above the floor. The smell which was causing us to run the rinse cycle every day to get rid of the smell has not been back in five days.
Posted on Aug 20, 2008
Loringh
  • 185 Answers
SOURCE: garbage disposal (water won't drain out of sink standing water)
There should be an overload button somewhere on the bottom of the disposal motor. This is to prevent the motor from trying to run if the chopping blades are jammed, otherwise the motor would burn up.
First, try to move the blades with something like a broom handle. Using a flashlight you should be able to see the blades. there's probably three of them. try to make sure each one can move even a little bit.
Next, with the disposal switch in the off position, find the overload button and push it in, Then turn on the disposal switch and see if it runs. If the overload button trips off again, repeat the above steps until the blades can turn.
Let me know how this goes. Loringh
Posted on Nov 08, 2008
  • 3230 Answers
SOURCE: Ge Profile stopped draining
The water doesn't drain from the machine
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap
Pump
Drain valve and/or solenoid
Belt
Motor
Timer
Drain line/air gap
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Pump
Your dishwasher pump ejects the water. The pump is usually mounted directly to the motor, then attached to the bottom of the dishwasher. You can reach the pump from inside the dishwasher, but first you need to remove the lower rack, the spray arm, and the spray arm support.
Look for an impeller--a round plastic fan blade-type of device that spins around. This is the wash impeller, which forces the water through the spray arm. Beneath the wash impeller is the drain impeller, which is similar in size and shape to the wash impeller. The drain impeller pushes the water toward the drain port. These components make up the pump. If any of the pump components are defective, you need to replace them.
Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Belt
One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor
If the motor isn't turning or working, the unit won't drain. First check to be sure you have power to the dishwasher. If not, see the section "It doesn't work at all." If the motor hums but doesn't turn, it may need to be replaced.
Some dishwashers are susceptible to getting stuck if you don't run them regularly. If you haven't run the dishwasher for more than a week, you may need to manually spin the motor to free it up. If the motor is defective, you need to replace it. Dishwasher motors can't be serviced.
Timer
Part of what the timer does is control the motor and drain valve. If the timer doesn't work properly, the water may not drain and you need to replace the timer. This problem is uncommon.
sorry to say but there is no images now... i'll try to find some for you.
good luck
thanks
Posted on Jul 07, 2009
Frigidaire pld2850rdc1
It is likely that the door seals on an 8 year old dishwasher could be ready for replacement.
Dec 21, 2013 | Dishwashers
GE Profile Dishwasher leaking from the bottom
If your dishwasher is Leaking check the following
Dishwasher Not Leveled
This is a very common reason for a leaking dishwasher especially if this was a new installation. The framing in a dishwasher is made up of mostly thin sheet metal, so if it is not sitting flat and level things can get distorted very easily.
Door Seal
This is not very common in most dishwashers. To check this look for rips and distortion of the seal. If it is ripped or distorted you will need to replace.
Dispenser Seal
This is a more common place for a leak to develop. This is easy to check, remove the front panel and carefully inspect around the seal for water dripping or stainage. If any is found replace the dispensergasket.
Water Inlet Valve
Usually it is the connection to the water inlet valve that ends up leaking. Check this connection ( there is usually some sort of adaptor between the valve and supply hose) for leaks. Check the connection on the back of the water inlet valve also. Ocassionaly a water inlet valve will leak around the solenoid in this case reokace inlet valve
Drain / Circulating Pump
Some dishwashers have separate drain and circulating pump. Some use one pump to serve both purposes. In either case you will need to check the housings for leaks along with all the connections. Some dishwashers have a seal that leaks down into the pump . This is easy and inexpensive to replace.
Door Latch
The door latch can become loose or misalinged. Check both the striker and the latch. To adjust the latch you will need to remove the front panel and adjust switch until properly aligned.
Door Hinges
They can cause problems, but this usually only happens from opening a heavy load of dishes on the door. Occassionaly a broken spring or cable occurs. You will need to remove the toe kick and maybe the front panel to inspect.
Use the VOM. God bless you
Apr 05, 2013 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher leaking at lower door seal
Possible that the door seal has failed and there is leak when the pressure spraying takes place. Please check the seal and replace, click for tips to replace: door seal
Jan 02, 2013 | Dishwashers
Leaking at the bottom in the middle of the door
you need to determine if it's coming from inside the door or under the front of the dishwasher, if the door latch needs adjusting it can get water through the latch slot, the dispenser can work it's way loose and water can leak through it, or the seal on the bottom of the door can get dirt stuck on it which can cause water to leak out.
Otherwise it could be in the bottom of the dishwasher, it is a matter of closer investigation.
Mar 10, 2012 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher leaks
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
n
Jul 31, 2010 | GE 24 in. GSD4020Z Built-in Dishwasher
Door leaks at the bottom of my ge profile dishwasher
1 has the machine been pushed into the cupboard hole,this will push the door away from the front of the machine,does it hit the trim around the opening before the closeing?pull out check under are the legs still straight,some you can remove the lower front panel to look under
Dec 02, 2009 | GE Profile PDW8400J Built-in Dishwasher
Dishwasher leaking
There is a front door seal that may be the issue. It seals along the door sides/top and continues under the door to seal the bottom surface when closed. Mine pulled out of the seal channel under the open door where you can't see it without a small mirror. The seal took a "fixed set" out of the channel so now it will not stay put. It requires replacement.
Hope this helps.
Jan 26, 2009 | GE Nautilus 24" Built-in Dishwasher
Apr 15, 2007 | GE 24 in. GSD4630Z Built-in Dishwasher
GE 24 in. Profile PDW9880JSS Built-in Dishwasher Logo
123 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
