Question about Weller Marksman Iron 40 Watt SP40L
We can't keep the tip tinned, what do we need to do?
    Sergeant:
  • 313 Answers
Clean the end of the tip with a smooth file down to bear metal heat it up and retin the end with fresh solder. Are you using multicore solder with resin flux ? some old solder does not have any flux in it.
Posted on Jul 29, 2010
Words with these letters
Pianist
Ani Spit
Ani Pits
Ani Tips
Pain Its
Pain Sit
Pain Tis
Pains Ti
Pains It
Spain Ti
Spain It
Paints I
Paint Is
Inapt Is
Saint Pi
Antis Pi
Stain Pi
Satin Pi
Anti Psi
Anti Pis
Anti Sip
Pitas In
Pita Ins
Pita Sin
An Tipis
San Tipi
A I Pints
A In Spit
A In Pits
A In Tips
A Pin Its
A Pin Sit
A Pin Tis
A Snip Ti
A Snip It
A Spin Ti
A Spin It
A Pins Ti
A Pins It
A Nips Ti
A Nips It
A Pint Is
A Ins Tip
A Ins Pit
A Sin Tip
A Sin Pit
A Nits Pi
A Snit Pi
A Tins Pi
A Nit Psi
A Nit Pis
A Nit Sip
A Tin Psi
A Tin Pis
A Tin Sip
An I Spit
An I Pits
An I Tips
An Pi Its
An Pi Sit
An Pi Tis
An Psi Ti
An Psi It
An Pis Ti
An Pis It
An Sip Ti
An Sip It
An Tip Is
An Pit Is
Nap I Its
Nap I Sit
Nap I Tis
Nap Is Ti
Nap Is It
Pan I Its
Pan I Sit
Pan I Tis
Pan Is Ti
Pan Is It
Naps I Ti
Naps I It
Span I Ti
Span I It
Snap I Ti
Snap I It
Pans I Ti
Pans I It
Pant I Is
San I Tip
San I Pit
San Pi Ti
San Pi It
Ants I Pi
Tans I Pi
Tan I Psi
Tan I Pis
Tan I Sip
Tan Pi Is
Ant I Psi
Ant I Pis
Ant I Sip
Ant Pi Is
Pa I Nits
Pa I Snit
Pa I Tins
Pa In Its
Pa In Sit
Pa In Tis
Pa Ins Ti
Pa Ins It
Pa Sin Ti
Pa Sin It
Pa Nit Is
Pa Tin Is
Spa I Nit
Spa I Tin
Spa In Ti
Spa In It
Asp I Nit
Asp I Tin
Asp In Ti
Asp In It
Sap I Nit
Sap I Tin
Sap In Ti
Sap In It
Pas I Nit
Pas I Tin
Pas In Ti
Pas In It
Past I In
Taps I In
Pats I In
Spat I In
Apt I Ins
Apt I Sin
Apt In Is
Pat I Ins
Pat I Sin
Pat In Is
Tap I Ins
Tap I Sin
Tap In Is
As I Pint
As In Tip
As In Pit
As Pin Ti
As Pin It
As Nit Pi
As Tin Pi
Sat I Pin
Sat In Pi
At I Snip
At I Spin
At I Pins
At I Nips
At In Psi
At In Pis
At In Sip
At Pin Is
At Ins Pi
At Sin Pi
Oct 19, 2016 | Miscellaneous
TIPS BURN OUT
It's better to get a soldering station instead.
Apr 26, 2013 | Weller 8200 Soldering Gun
How do i use this product(Weller model Standard 7200)?
You need the nuts that hold the tip in the iron--slide them on, then bend the ends sideways with pliers and leave about 1/4" sticking out sideways. Be sure to make the upper and lower bends in the same direction. Be sure to tin the new tip with solder when you first heat the tip. Hope this helps!
Sep 30, 2010 | Weller Standard Tip: 7200
Weller 8200 series soldering gun sometimes fails to heat; tightening screws and/or gently spreading arms often helps. Is there a permanent fix?
There is constant maintenance needed to keep soldering, the key ones are the tip fastening nuts, and the tip itself. The tip eventually needs sanding and immediate retinning, Clean with damp rag during and after each soldering event, and heavily re tin at end of event.
Sep 14, 2010 | Weller Welding Tools
My bread stuck to the pan and it rose to much.
Remove the container from the breadmaker and use non-stick fish-slice or palette knife to free the sides from the tin. Then tip upside down and shake to dislodge it.
If this fails, remove the bread as best you can and leave the tin to soak in water overnight.
It is best to clean the bake tin by hand as dishwashers remove the non-stick.
Try using packet mixes with a different packet dried yeast. or use less yeast next time.
Feb 08, 2010 | Kitchen Appliances - Others
My kenmore cooktop keeps blowing the fuse. as that is all that is on that fuse. i have no idea where to start
take one out turn others on keep going till you find the bad one....if you use tin foil look for it where the burner plugs in(never use tin foil in your stove anywhere)
Aug 20, 2009 | Cooktops
Jack / Cord problem
yes basically if you look at the jack end you should see where the join is it may unsrew then look at the wires in side and the looose one should be seen if not yu can get a new jack from most online electronics Maplin -RS- or any electronics supplier you will need to resolder the wires onto the new connector..make sure you keep the other snipped off connector for reference when resoldering new.. There are a few tips to soldering.. maker sure the wire is twisted before soldering and touch the wire to the solder tip then bring teh solder wire to the wire to tin (melt solder) the end then do the same with other wires. once the wires are tinned bring to plate on teh connector and touch wire to connector and then solder tip to where wire and connector are.. if you keep teh soldering iron on the connection to long you may melt the plastic jack surround so I usually use a metal jack type.. if it has three wires one is for left one for right and one earth..copy the old jack wiring and you should be ok.. Good Luck A
Aug 04, 2009 | Audio Players & Recorders
Tinning tips
Flux the tip, heat the iron, apply solder all over the tip and wipe, while hot, the solder off with fine steel wool.
If the solder is flux core, no need for additional flux
Good Luck
Jan 27, 2009 | Weller SP175 12 - 1/2'' Marksman Extra...
Weller Marksman Iron 40 Watt SP40L Logo
256 people viewed this question
Top Weller Welding Tools Experts
Lawrence Oravetz
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Weller Welding Tool Expert? Answer questions, earn points and help others
