Question about ASUS A3Ac Notebook
Give me cd drive data download - ASUS A3Ac Notebook
    Brigadier General:
  • 10,406 Answers
Windows 2000 and XP and Vista and 7 all have "built-in" support for CD-ROM drives.
Posted on Sep 30, 2010
How can I retrieve the data in my portable hard drive. It says I have to format the drive.
You didn't give much detail as to what happened, but I will suggest what I can. It sounds like you have a corrupted partition which may give you a chance to pull that data off the drive. After your data is saved delete the partition and reformat.
>First, if you have a USB cable connection, exchange the USB cable for another; I have seen bad cables do this.
>The second thing to try is to access your drive from outside Windows; use the link HERE to download Reatogo. Reatogo is a program that loads from your DVD drive and by-passes Windows and loads into memory. You can then "see" your hard drive and attempt to access your data. It has a Windows XP screen so it is easy to navigate around in. So, do this:
>Download from the above link
>Double-click the file and burn to a CD
>Make sure your BIOS is set to CD=1st Boot Device (the BIOS checks the cd for bootable files before loading Windows).
>Reboot with the CD in the DVD drive; this takes a long time to load so be patient. You may think the load has stalled, but it hasn't. When finished loading, you will see a duplicate of the Windows XP desktop, and your hard drive will be listed. Click on it, and if the hard drive is still working you will see your C:\ directory. Plug in a flash drive, locate your data, and drag & drop it onto the flash drive..
If that doesn't work, post back for additional things to try.
Wish you the best!
Oct 13, 2013 | Western Digital My Passport Essential...
Ihave a sagate 320 inturnal HD that was installed on my desktop Comp. 1.5 years ago I am getting window massage to download all my data due to the HD failing. I am looking at the date code and it appears...
It sounds as if the SMART measurements on your Seagate 320GB hard drive are triggering the Windows message advising that the drive is failing.
You would be best advised to backup your data from this drive to a different drive or on to DVD media (depending on how much data is involved).
To test the failing Seagate disk, download a copy of Hiren's Boot CD which is a CD image file (.ISO) and must be burnt to a blank CD disc - then boot the computer with the failing disk from this CD - then select DOS Programs on the initial menu, then choose Hard Disk Tools and then HDAT2 - this is a tool which will let you try to recover any bad sectors on your boot disk.
On the Hard Disk Tools menu there is also a SMARTUDM - HDD S.M.A.R.T. viewer which will let you examine exactly which areas of the Seagate disk are giving the problem leading to the failure message.
Jan 08, 2012 | Seagate Barracuda 7200.10 ST3160815A -...
How to recover my seagate extenal hard drive ST903204EXA101-RK for free
A lot depends on what is wrong with your hard drive but assuming that it will still power up and will connect to allow data access, then I would recommend downloading a copy of Hiren's Boot CD, burning this to a blank CD, then booting the computer with the drive attached from this CD....On the Hiren's initial boot menu, select Dos Programs, then in the next menu, select option 6. Hard Disk Tools, then on the next menu, select option 1. HDAT2 which will allow you to Test and Repair Bad Sectors on the problem disk....Ensure that you select the correct drive from the Device List when shown - look at the Capacity to help doing so....Run the Drive Level Tests Menu to choose to Check and Repair bad sectors, then leave this to run - it will take some time to complete depending on both the size of disk and the number of problems found - the computer will give a BEEP sound for each error found!...If there are too many bad sectors that cannot be repaired, then time to use some of the other tools on the Hiren's Boot CD to recover what data you can from the failing drive.....Download Hiren's Boot CD from http://www.hirensbootcd.org/
Oct 25, 2011 | Seagate (ST903204EXA101RK) 320 GB Hard...
Unmountable boot volume
If you are seeing 'unmountable boot volume' when booting your laptop / notebook, then this would suggest that the internal disk drive has become corrupted or perhaps has failed. I would recommend downloading a copy of Hiren's Boot CD from http://www.hirensbootcd.org/ - this is a CD image file (.ISO) and needs to be burnt on to a blank CD disc.Boot from Hiren's CD and select DOS programs which will give you access to a selection of Disk tools including HDAT2 which can be used to test and repair bad sectors on the internal disk drive. There are also utilities which can read the SMART data from the drive and give an indication of any problems it may have encountered.
Oct 06, 2011 | Dell Latitude D820 Notebook
How do you download mp3 files from data CD?
HI just go onto my computer, right click the drive the data CD is in, select open drive . And copy them onto your desktop.
May 29, 2011 | cd-mp3 Easy Audio/Data CD/DVD Burner
I have purchased webroot essentials 2010 and need to install it on my laptop that does not have a c d rom. i have the product key how do i install it with a product key thanks jim o
You can take your cd to a computer which has a CD ROM copy all the data from CD to a pen drive bring the pen drive to your laptop and install the software with the help of your product key. or you can also go online through your laptop google for free download webroot essentials 2010 and download it from internet on your laptop and give the product key when asked by the software.
Jun 13, 2010 | Computers & Internet
My CD drive won't let me burn CD's anymore. Why?
Try choosing a different set of songs, if still your CD burning fails, try copying large chunk of data or a data cd to cd copy if possible. If this also fails, you have to give your cd burner for service / replacement based on the warranty entitled.
Jul 17, 2009 | Dell Computers & Internet
My sony dvd rw aw-g170a drive is not detecting certain DVD's!!!!!
if you have CD RAM and DVD ROM then change it to CD/DVD ram because in case of CD RAM and DVD ROM it may read CD but not DVD but sometimes it can read DVD also but when we copy data to computer it may freeze or give us error so i give you one suggest to buy a new CD/DVD RAM
Jun 26, 2009 | Sony (1-796-293-13) Plug-In Module DVD...
DVD ROM/CD-RW Drive
try to roll back the driver , if that doesn't work go to the manufactures web site and download the driver . if it still doesn't record install the drive in another computer and if it doesn't work then it maybe a bad drive itself
Aug 06, 2008 | Gateway 310S (2900621) PC Desktop
I am running windows xp on my computer and i can't get windows mediaplayer to detect any of my dvd\cdrw so that I am able to burn cd's what should i do.
There are three way to burn in your system .
  1. The burn software comes under with windows xp it is easy to write or burn the data into the cd\dvd.put the empty cd into the cd drive place the data which you want to write right click and send to , cd drive . same process for all the data which you want to write not for excess the space of cd\dvd disc.
  2. The writing software are available for cd\dvd drive while you buy the drive . that named like a nero express , in that software you can write and erase the rewritable disc and gives the maximum speed to write for storing.
  3. you can download the microsoft windows mediaplayer from the web site microsoft.com for free.the new version are also available.
these are the intial steps to slove your prob please try it and inform me.
Apr 30, 2008 | Computers & Internet
ASUS A3Ac Notebook Logo
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
