Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
Free Agent P/N 9NK2AE-500, S/N 9QE1WQ4X - CAN'T SEE ON SCREEN
External drive connected thru USB to IMac G5. Was working fine until mouse freeze. Ran hardware check and everything OK. Restarted and everything OK except Free Agent doesn't show as connected. Process required disconnect all USB which included Free Agent which I did without ejecting since disk was partitioned into 4 partitions. Disk contains backup. Help.
SparkGap
  • 363 Answers
SOURCE: Seagate drive partition
This is fairly straightforward using the Windows XP tools.
IMPORTANT, copy everything you want to keep from partition F otherwise it will be deleted. Drive G will not be affected.
  • Right click 'My Computer' >'Manage' then click disk Management.
  • Right click your drive F and 'Delete Partition'.
  • You now have 210GB unused space on the drive.
  • Right click the unused space and "Create Partition".
  • Specify the size of the new partition to your requirements or create more partitions until the free space runs out.
  • You can then right click and format the new partitions. 'Quick Format' is fine unless you have been experiencing disk problems.
To swap around drive letters in Disk Management:-
  • Right click the drives and 'change drive letters', to X, Y or Z or whatever
  • Now you can change the drive letters back to F, G, H or whatever order you want them in
I'm sure you get the idea, you just have to change the letters of the drives to unused letters to make a space in the sequence (not that any sequence really matters)
Good luck
Posted on Nov 08, 2007
SOURCE: help for Seagate Free Agent 500 GB external hard drive
I just got a Free agent 500gb today and I checked from my computer to see how much actual space was available on the HDD and it showed the same amount that you're getting 465gb. I believe the 35gb that's missing is used for some standard program/files that the Free agent requires for regular operation.
Posted on Jun 11, 2008
  • 23 Answers
SOURCE: not detecting
Sounds like a loose power cord...
-Damian
Posted on Jun 12, 2008
SOURCE: external hard drive can not be read by the computer
The hard drive was originally formatted for a PC and I was using it with Mac products. I had to delete all the information on the hard drive so that I could reformat the external hard drive to work with my Macbook Pro.
Posted on Dec 09, 2008
robomatic
  • 3 Answers
SOURCE: FAT32 format, how to do it in Windows XP?
Windows 2000, XP, Vista can format your drive into NTFS and it sounds as if you're already there. If you want to format in FAT32 they'll do it, but they will limit partition size.
The way I've done it is to use linux. there is a form of linux called "knoppix" which is a CD or a DVD which will boot your PC and turn it into a linux box running from the DVD drive. Linux will allow you to format your drive in about a dozen ways, so choose carefully. If you are tech savvy and adventurous, this is fun and not dangerous (providing there is not data to lose). On the other hand, if you want safety without the hand-holding, there is formatting software you can buy to do this in windows, but the modern Windows systems will not of themselves give you a massive partition in FAT32.
Posted on Dec 27, 2008
What is the AC DC adapter spec for SEAGATE 9NK2AE-500. i lost the original adapter that came with this external seagate freeagent harddrive.
most of these external hard drive units work with a 12V 3 amp DC power supply like this one
OEM AC POWER SUPPLY SEAGATE 9NK2AE 500 Free Agent HDD
Make sure you get the correct power connector for your country.
Aug 17, 2014 | Computers & Internet
G5 keeps powering up for a few mins then switches off?
Thank you for contacting Fixya Support, I am glad to assist.
There are a few steps you can try to troubleshoot this issue:
Try a PMU Reset:
* Turn of your iMac if it is already turned off
* Disconnect all connections to the iMac except the power cord
* Now disconnect the power cord for approximately 20 seconds
* Reconnect just the power cable the keyboard, mouse and power cord, and then power your iMac G5 up.
* Check to see if the iMac boots up normally without power interruption.
* If the iMac G5 shuts off again, try these steps, another recommendation would be to remove all connections including the power cord, and lay the iMac G5 on soft cloth face down and with a philips screwdriver, remove the plate on the bottom of the iMac G5 where your RAM memory is located.
Before removing the RAM however, touch your hand on the metal boot to discharge any static current you carry for approximately 5 seconds.
Now remove each RAM card and then reseat (re-install) each card.
Restore the RAM card cover with your Philips screwdriver, reconnect your power cable, keyboard an
d mouse and turn on your iMac G5.
See if this second procedure helps if the first procedure does not work.
Let me know if this helps.
Regards
-Mactechtrainer
Sep 11, 2010 | Apple iMac G5 Desktop
G5 laser mouse freezing
Download the latest mouse driver from it's manufacturer's support website.
Jun 09, 2010 | Logitech G5 Laser Mouse Mice
HI! I just bought a free agent 1TB to USB 2.0.
I'm not familiar with Carbonite but can't see why you couldn't use it to backup your new drive provided your PC just sees out as an ordinary (if external) drive. As for USB compatibility, the USB specification is backward compatable so your drive should work fine, if slower, when connected to a USB 1.0 port.
Hope that helps.
Aug 13, 2017 | Seagate Free Agent Go Small 12 GB USB...
I have an iMac G5 2Ghz that when it start up you can only see video for a few seconds. I connected an external monitor and my iMac works fine but with its on LCD there is no video. I check the logic board...
Sir,
The iMac G5 and iMac G5 (Ambient Light Sensor) computers have a video out port located on the back of the computer, which will mirror video. Video mirroring means you can see the same image that is on the iMac G5's flat-panel display on an external monitor, television, or projector.
Using the video out port, you can mirror video with a compatible VGA display using the Apple VGA Display Adapter.
You can also use the video mirroring feature with a television or projector that has S-video or composite video connectors when you use the Apple Video Adapter.
Both the Apple VGA Display Adapter (M8639G/A) and the Apple Video Adapter (M9109G/A) are available separately, and are needed if you want to use your iMac with a VGA monitor cable, S-video cable, or composite video cable.
The video mirroring feature is "plug and play". Simply connect a VGA display, television, or projector to the appropriate adapter (see above), then connect the adapter to the video out port located on the back of the computer.
When you connect the adapter to the computer, the screen may refresh momentarily as the computer prepares itself for the new video output. The computer tries to match the resolution of the built-in and external display. If there is no match, the computer changes both screen resolutions and may black out areas on the built-in display in order to match the capabilities of the external display.
Important: To ensure that your iMac G5 automatically detects the external display or projector, be sure you plug the adapter into the external display or projector before you plug it into the iMac G5.
You can switch resolutions and frequencies for both the iMac G5 flat-panel display and the external display, television, or projector using Displays preferences.
Want to watch a DVD movie disc on a television that's connected to your iMac G5? Select a 720 x 480 NTSC (in the United States) or 720 x 576 PAL (in Europe and other regions) resolution in Displays preferences.
Tip: Because of the display limitations of most televisions, the images displayed on a television screen are usually not as high quality as those on the built-in display or an external monitor.
Thanks
Good Luck
Aug 21, 2009 | Apple iMac G5 Desktop
I have a problem with my seagate agent go 500 gb. when plugged in to my laptop it doesn't detect it and it freezes my laptop until i unplug it. how can i get to my files in the external hard drive?
try to connect it to other computer, if it doesn't help, hdd is probably broken. If you disassemble, you will find internal hard drive, which you can try to connect to desktop PC to save your data, or look up for some data recovery company
Jul 10, 2009 | Seagate Free Agent Go Small 12 GB USB...
G5 dual processor keyboard freezes for 10 seconds or so
you might need to check the usb connections for the keyboard and mouse. and see if they are correctly connected, also to clean the connections with a q-tip from time to time. Also you might want to switch to another usb port. to narrow down the issue. Because if say you change to another port and it still persists, even when running a usb hub with external power, and even a external firewire hub with usb connection then the issue would be the com board for the usb and firewire. and hopefully the G5's usb, firewire ports are on a separate board that is then ribbon wired to the main board. because if its just ports ribboned to the main board you will need to get a new logic board. and that is not cheap. unless you still have your applecare. then just take it in to get replaced.
Jul 02, 2009 | Apple 24" iMac Desktop
Connecting external microphone to imac g5
Get yourself a great little gadget called iMic. It's a usb connector that adapts to let you used your headset mic and the mac system os will recognize it very well. Works good .
Costs about 24 bucks or so..
K
Jun 19, 2009 | Apple iMac G5 Power Supply 661-3351
While trying to install OS10.5 and it will attempt to but it freezes, you the Apple booting circle it stops.
Probably the OS 10.5 version your're installing is not compatible or supported by the system motherboard of your computer model Apple Power Mac G5. per my research from Apple website herewith is their solution quote on what applicable OS to install for such model: "Power Mac G5 (Late 2005) and iMac G5 (iSight) models require Mac OS X 10.4.2 or later, you can t install Final Cut Pro 3.x or earlier versions on these computers. Final Cut Pro 3.x and earlier versions are not supported on any computer running Mac OS X 10.4". best regards
May 20, 2009 | Apple Computers & Internet
Eject is stuck on my power mac g5
try a reboot and hold the left mouse button down during the startup. You can also hold the spacebar during startup. This should force eject the drive
Mar 20, 2009 | Apple iMac G5 Desktop
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
434 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
