Question about HP LC3760N 37 in. LCD HDTV
Receiving power no picture
Failed during viewing woukd not come on. power light blinks
  • 11,361 Answers
The power supply may be in the safety shut down mode due to bad power supply or shorts circuits in the backlight inverter board, you need to do some voltage checkings to narrow down the problem.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Please post back what you find.
Posted on Jul 30, 2010
How to determine if power board on emerson tv model lc320em1 is shot
The power supply regulator board to your TV is now working fine, and has no problems at all, as, there is standby light. Check all the other voltages comes out from the power board, to main board. If all of it found OK, the fault should be at its main board.
About blinking of standby/power light;
These blinks (flashes) are fault indication. By the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside the TV. Count the blinks occur at one time switch ON, carefully. Do it once again, and make sure about the number of blinks. If the flashes are continious, non-stop, the main system control IC should be suspected. If you wish to get more details, check the site linked here. It has blinking codes detail to many brand TVs. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 19, 2014 | Emerson Lc320em1 TV
Sharp LC-32SB220U
If you wish to get more details, check this link. http://electronicshelponline.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy. You can also do a search, by type in the brand name/model number/IC used, in the search box at the top right of the display window.
Oct 28, 2013 | Televison & Video
Red power light flashing..no picture
Count the blinks of the led. The number of blinks gives an idea of which board has failed let me know
May 01, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Unable to stay power-on
Have already posted this fix twice, but to be sure hunglam_1999 receives notification, doing so again 27Oct2009:
Most common failure is the audio amp IC, reference # Q5001, which is an STK402-950 (Onkyo Pt. # 222123). Typically fails as a result of excessive volume levels or as a result of problems with the speakers or their wires. If you're technically inclined, the part can be had from various vendors & is fairly straightforward to replace once the complex disassembly required to access the PCB this IC resides on is accomplished, using standard soldering skills. A repair of this type by a reputable servicer may be more effective for non-technical folks, as typically can be accomplished for $200 or less, much less than replacement cost...
Oct 05, 2009 | Onkyo LS-V955 System
Red light flashes on power switch, but no picture or sound on tv
tv will not power on. red light on switch blinks. power relay clicks, but no picture or sound.
Jul 28, 2009 | Toshiba DVD Recorder AND Series2 TiVo...
Green light on front rapidly blinks after power outage. No picture, or can't turn on
This unit, when first plugged in or after power interuption takes 70 to 90 seconds for the digital module to boot up. During the time the LED blinks green and the set will not respond to anything. After the appropriate amount of time the blinking should stop and the set should operate normally. If the blinking never stops then you have to have the Digital Module repaired.
Apr 25, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Sony Bravia 40 inches has a defect
More then likely your power supply failed. If you do not hear a click from the relay during the power up cycle then your power supply failed.
Jul 29, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
HP LC3760N 37 in. LCD HDTV Logo
175 people viewed this question
Top HP Televison & Video Experts
Computer Links
vbalag
Level 1 Expert
Alun Cox
Are you a HP Televison and Video Expert? Answer questions, earn points and help others
