Question about Pit SSR 110CC Pro Beginner Bike
Oil leak from engine to barell
I have stripped and re built a 110 semi auto quad bike engine but am suffering an oil leak from engine casing to barell, i have tried to double the gasket , and re tighten but still have a steady trickle of oil running down.
Any IDEAS
    New Friend:
  • 25 Answers
Gasket seal
Posted on Jul 27, 2014
    Problem Solver:
  • 6 Answers
Locktiet
Posted on Aug 05, 2010
I switched to semi-synthetic now my oil is leaking under the bike what can i do to stop it ?
change back to normal oil some engines run better on thicker oil ,this is what they were designed to run on .
Apr 03, 2017 | Qlink Motorcycles
Where do you adjust a vuka semi automatic clutch
Hi, Christaan for more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
110 semi auto clutch adjustment
Mid bike 110cc Clutch adjustment problem
ATV Connection
http://www.agri-moto.com/images/Parts/Vuka/vuka_xl110_xl125_parts.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Nov 08, 2016 | Vuka Motorcycles
Iv'e just stripped down and repaired my gearbox on my scooter. however i don't know what oil, grease is required could you help.
hji, on most scooters it recommended you use a semi fluid grease, recommend by shoprider on their scooters... plain grease is not ideal as it sticks to the sides of the casing , not lubricating anything ...
a thickest oil would also be ideal, however remember if no gasket is fitted it may leak...hence the semi fluid route..
http://www.castrol.com/en_us/united-states/products/truck-and-bus/greases.html
Regards
Rob
www.gewizrepairs.co.uk
Aug 05, 2014 | Shoprider Health & Beauty
Oil level TDM 850 without oil level window
The tdm is a dry sump engine where the oil is in a tank under the seat and is pumped around the engine and returned to the tank by a scavenger pump in the bottom of the engine so a level window on the engine is not required
Apr 04, 2014 | 1999 Yamaha TDM 850
2004 honda 350 fourtrax exhaust seat loose in head. What years of honda 350 heads will fit a 2004
Do I take it the engine is already stripped to establish the fault. I've owned several Honda's and never seen this fault. If its in bits a good motorcycle engine shop could do it and recut the seat but only a search of parts books would tell you if Honda used a motorcycle head. Saying that, Honda do appear to use modified bike engines to power quads. New crank cases built onto a previous barrel and head.
Call a Honda specialist or a quad shop who may have already worked it out for themselves. Check out quad forums as well?
Nov 04, 2013 | Honda 2005 FourTrax Foreman Rubicon
What kind of transmission oil should I use for a FXSTD 2000
Your bike came with H-D Syn3 20W50 synthetic engine oil in the engine, primary case, and transmission. There are many other brands of oil that can be used however. Go to their websites and check for their recommendations. Personally, I like the H-D semi-synthetic primary and transmission lube made for the earlier bikes. I think the transmission runs quieter with it in there.
Good Luck
Steve
Aug 04, 2011 | Harley Davidson FXST Softail Standard...
My 2006 ktm 450 xcw is spraying oil out of the over flow tube the one the factory routes to your carberator its everywhere only sprays when the bike is wide open and under a load bike had 110 compression...
should be more tahn 110 psi in the cylinder my 85 is capable of going to 155psi and it reached 185 when the rings were new its either the ring gone or valves are leaking i would strip the pot off and inspect buddy
Oct 03, 2009 | 2005 KTM EXC 450 Racing Usa
Leaking Oil Sump Plug on Honda 300 ATV 4 wheel drive Quad bike. Threads in the bsae of the sump (presumably alloy) seem to be partly stripped. Any suggestions for a cure please.
buy a tap and die set and re tape the threads on the bolt or if too the threads are really messed up buy a new plug bud also check to see if there is a seal on the plug e.g. o ring/washer
Aug 14, 2009 | 1994 Honda CB 500
Using to much oil on long trips 2004 gsx1400 suzuki
That is a lot of oil - is it blowing smoke? Is there any indication of where the oil is going?
The GSX engine is bulletproof - normally - and doesn't use much oil at all. I have serviced 35,000 mile bikes after 7500 miles and the oil has been spot on.
Looking on the net, it seems the 1400 is a bit vulnerable to oil-cooler damage. With an air/oil cooled bike this could be an indication of where the problem lies. The engine won't leak oil while stationary - well, maybe a drop... but when it is warm and under revs any hole in the oil cooler could be a direct exit point for oil. Look for stains on the exhaust headers - if you are driving and there is a leak, that'll be the first place the oil will go.
It would be the first place I would look - as well as oil cooler, pipes, connectors...
Run the bike for a while and try to inspect it to see if there are any leaks you can spot while the engine is running.
Jul 01, 2009 | 2008 Suzuki GSX 1400
Pit SSR 110CC Pro Beginner  Bike Logo
221 people viewed this question
Top Pit Cycling Experts
john h
Mack Baxter
Are you a Pit Cycling Expert? Answer questions, earn points and help others
