My router is set up correctly; however, i lose connectivity within about 25 minutes of being connected and online. when i try to reconnect, i am unable to connect and i cannot get connected without resetting the router and the modem.
    Problem Solver:
  • 17 Answers
Who is your service provider? I recently got FIOS, and had a similar problem. It turned out that there was a "patch" that was not readily available. If you have FIOS, try this - copy and paste the info below into notepad. Save it as FIOSfix.reg, then double click and say "yes" when it asks if you want to add it to the registry.
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\AFD\Parameters]
"DefaultSendWindow"=dword:0001fe78
"DefaultReceiveWindow"=dword:000ff3c0
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters]
"GlobalMaxTcpWindowSize"=dword:0000ffff
"Tcp1323Opts"=dword:00000001
"SackOpts"=dword:00000001
"TransmitWorker"=dword:00000020
"EnablePMTUDiscovery"=dword:00000001
"TcpMaxDupAcks"=dword:00000002
"TcpUseRFC1122UrgentPointer"=dword:00000000
"DefaultTTL"=dword:00000030
"TcpWindowSize"=dword:000ff3c0
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Internet Settings]
"MaxConnectionsPerServer"=dword:00000004
"MaxConnectionsPer1_0Server"=dword:00000004
Posted on Apr 25, 2008
    Master:
  • 441 Answers
Do you know how to access your router's setup page? If yes then setup the MTU on your router, for DSL use 1492, for Cable use 1500/1400/1300 (try which one will be best for you). If this may not work you may want to directly connect your computer to the modem and test if the connection there is stable.
If you do not know how to access the router's setup page, please provide me this information,what is the model number of the router and the operating system of your computer. Is your computer wired or wireless? is there a wired computer?
Posted on Apr 24, 2008
My hipstreet aurora hs-7dtb6 won't connect to a wifi connection. i have the wifi turned on and n tried connecting it to my home wifi connection but it won't seem to reconnect, it did connect to my wif
If the signal is too weak the connection will be unstable. If you have a lot of wireless routers in your neighborhood it could be affecting your connection. Everything will work fine then the neighbor turns on his equipment and you lose your connection. Try switching the router to a different channel. Try channel 11.
Oct 18, 2014 | Computers & Internet
I have a D-link DIR-655 wireless router . I have two computers wired to the router and I run a wireless laptop. A couple time a day I lose connection and get a message thay says "local connection...
Make sure the power setting does not allow the ethernet card to be shut off. Also look through the other settings on the ethernet card properties menu. Some of those affect the stability of the connection. You access the setting through device manager.
Aug 04, 2017 | D-Link Xtreme N DIR-655 Wireless Router
Enthernet cannot connect
There are many reasons why this might be happening.. You could try the following steps..
First Check if you are able to go online on modem..if not disconnect the power from the modem adn connect it back after a minute. If its still not connecting contact your Internet service provider. If you able to go online with modem please follow the below steps.
1) Disconnect the power from router for a minute and reconnect and check.
2) Try on different slots on the oruter if its wired. If wireless is the issue then try changing channels and network name.
3) Check if there is an firmware update for your product and update if any update is available.
4) If none of the above steps work you will need to reset and re-config your router. ( For that you need the CD given with the router and you will need the ISP settings.)
Hope this helped
Feb 07, 2011 | D-Link DIR-615 Wireless Router
I have a Netgear WPN824 v2 router that has been consistently losing the connection with various devices: laptop, iPad, iPhone. The Internet works and then suddenly stops. I go into the WiFi connections,...
Try to change the wi-fi channel to another one. Sometimes, due to interference with other wireless devices, there are these problems. Also try to use a network cable to connect at the router to locate if the internet connection with the modem is still available when the wi-fi blocks out.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Sep 20, 2010 | NetGear RangeMax WPN824 Router
Password not working
This is usually a problem with not remembering the correct password. Quickest path to resolution is to reset the router (usually a small pin-hole that you stick something like a straightened paper clip into). Once the router is reset see if you can connect without a wireless password. Go online for only a minute and see if you can connect to google.com. Don't go wandering all over the internet, your router is unprotected at this point. If you can successfully get to google through the wireless connection without a password, unplug the internet cable (the cable between the router and the wall, modem, whatever). Using your PC browser go to the router setup menu - usually putting 192.168.1.1 in the browser address field and pressing enter works, but if that doesn't work you'll need to check the Linksys web site for the correct ip address. Locate the password setup menu and configure the settings. Note that once you set up the password your wireless connection will be disconnected and you'll have to reconnect to the router using the new password. An alternative is to connect the pc to the router with an ethernet cable during the password menu setup steps.
Sep 19, 2010 | Linksys Wireless-G WRT54G Router
My N1 vison keep losing on wireless connection when i used 2-3 wireless devices in same time. My connection is wired to my Desktop PC & wirelessly to 1 laptop, 1 iPhone and newly 1 iPad. I noticed that...
If you have a 3G phone in the house, It operates at the same frequency and is a nono.
If not I would suggest you completley rest modem and re-enter U/N, P/W etc and set up secure network also. If still a problem, maybe faulty modem.
May 10, 2010 | Belkin N1 Vision Router
Msg. conntected with limited access
Try this.
Unplug the Router.
Unplug the modem.
Wait about 15-20 secs.
Reconnect the modem.
wait about a minute or until all the lights are solid on the display.
Reconnect the Router.
Wait about another minute until everything is given time to start up.
Try connecting again.
If it still does that, it may be a problem with your computer that your trying to access with wirelessly.
My mother had that problem on one of her laptops, it turned out that her particular installation didn't support WPA or WEP incryption. I did a full reinstall and now it works.
If you want to avoid a full reinstall you can try uninstalling the wireless network card, then reinstalling it.(Make sure you go to your manufacturers web site first to download the proper driver for your model)
I hope this helps,
Simon.
Nov 19, 2008 | NetGear RangeMax NEXT WNR834B Wireless...
Can't reconnect - NetGear RangeMax WPN824 Wireless Router
Try changing the channels of the router to 1,9,or 11. this may help minimize wireless interference.
Mar 27, 2008 | NetGear RangeMax WPN824 Wireless Router...
Cannot acquire network address from access point
then it seems thatb the wireless security key for your network is incorrect, make sure if you are entering the key correctly..
or else..
check if you are able to go online with the router wired first, if yes, then the w/ls settings has to be checked..open your w/ls network connection, remove your preferred wireless network and then try to reconnect again and check.. if you are not able to gon online wired with the router, disconnect power cables from modem- router , wait for 10 sec, and reconnect it , wait till all the lights come up and then reconnect, check if you are able to go online if not your router has to be reconfigured,,
plz check and revert back in case of any issues
Dec 02, 2007 | D-Link AirPlus Xtreme G DI-624 Wireless...
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
