Question about LG 42LC2D 42 in. LCD HDTV
One channel - local - sound comes through in waves disappearing and then coming out in blips - this happens consistenly on one particular channel every day and one other channel sporatically could it be the providers channel changer
  • 3,230 Answers
Well the problem is not seems due to Television. It seems that the problem occurs due to channel subscriber (provider). You can try to search channel manually and then store the channel to some other channel location, if further you have the same problem then it's not your TV fault it's because of the channel provider. To correct the problem you need to call your cable operator. Please post comments for further help or information........
Good Luck!!
Thanks
Posted on Jul 29, 2010
Some dtv channels missing on VIZIO
Have you tried doing the channel search? If that does not help replace the main board
Apr 12, 2014 | Vizio VL370M LCD TV
Xpr6350
The radio frequency you mentioned may be a broadband wide frequency with greater local power for which it over powers the channels nearby. It is similar to shadow waves on a TV when someone is sending a signal with a Ham Radio. Overlap can happen. In short, the disturbance must be within close range, perhaps in the same building.
Jan 14, 2018 | Motorola Radio Communications
I have a 42" LCD
If they are all coming from the same physical source (please clarify) there is little you can do other than to look in thge audio menu of the TV and switch on auto volume if your particular model has that option.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 24, 2011 | Hannspree (K206-10U1-005) Television
Radio reception
Cb radio is line of sight. If there is a hill in the way, or some other kind of structure it will block the radio waves.
But also, radio waves, will bounce of the ionosphere and come back down.
So whats probably happening is...
You hear people close because they are near. You can't hear some one some what far away because of hills or something, but you talk to people far away because the are within range of the radio waves bouncing back down to them
Jul 10, 2010 | Cobra 25 WX-NW-ST 40-Channels Base CB...
My Westinghouse 36 inch TV has picture and sound when I turn it on but when I change channels, the picture disappears and I have only sound. The picture comes back if you turn the TV off and back on but...
Hello, it sounds like your inverter board is goin out on the set, when you change channels if you notice on almost any TV the screen goes dark and the new channel appears, it sounds like you are not getting enough power out of the inverter board to power up the backlight enough to come on. This is why the sound remains because everything else works fine and the sound is connected to the main board.
Nov 22, 2009 | Westinghouse LTV-27w6 27 in. LCD HDTV
Intermitten issue of no sound while playing NSF: MW
Uninstalled and reinstalled the game.
Everything worked fine after that.
Cheers!
Nov 12, 2008 | HP Media Center PC 873n (P9875A#ABA) PC...
Noise and popping on Sony STR-DA3ES
Sounds like its going to square wave clipping and poking a dc offset at your speakers. Happens when the amp reaches power supply ceilings. Pink noise such as "rain sound" will push the output stages and power supply to limits. If its on all channels, check power supply caps and check for dry solder joints. also look for that crappy brown hold down glue that goes conductive/corrosive. check all output stages particularly about discrete output devices that are attached to heat-sinks. They have a bad habit of dry jointing also. Good Luck
looked for a free manual on line for you
http://www.nodevice.com/manual/Sony/page139.html got heaps... but not your exact model. You may be able to cross reference one
Feb 03, 2008 | Sony STR-DA3ES Receiver
Sound problem!!!!
Hi, new one on me but heres one thing you should do with that comcast box, un-plug the AC cord on the comcast box for about 1 minute, plug it back in and be patient while it re-boots, can take as long as 4-5 minutes, this re-sets all the logic states in the box, hope this helps.
Nov 29, 2007 | Televison & Video
Picture and Sound disappear after a few minutes
Practice visual acuity technique! Look for bad solder connects==none found?? suspect flyback xformer.
Sep 26, 2007 | RCA F36674ET 36" TV
Tv is having wave problems and little blue specs
Distoritions like the symptoms you're describing are probably a defective light engine, Mitsubishi p/n#939p977020 If you go to price a new L/E they're approximately $975.00 and $300.00 of that is core that you get back when you return the defective one. This is NOT a replacement for the less than skilled either. Find a good reputable shop and have them do the job. If you get someone less than skilled you could end-up damaging the new L/E or something else like the color wheel. If you're not sure where to begin looking for a reputable shop I would suggest calling NESDA (National Electronic Service Dealer's Assn.) and asking them for a referral to one of their member shops in your area. Good Luck Bill
Jun 05, 2007 | Mitsubishi WD-62725 62" Rear Projection...
LG 42LC2D 42 in. LCD HDTV Logo
20 people viewed this question
