Question about GE GSS22JER Side by Side Refrigerator
FREEZER FREEZES OK BUT THEN IT WARMS UP TO MUCH AND THE ICE IN TRAYS TURN LIQUID THEN IT FREEZES AGAIN THIS HAPPENS REPEATEDLY WHAT DO U THINK THE PROBLEM MAY BE. ALSO WHERE CAN I FIND A SERVICE MANUAL FOR THAT FRIDGE?
  • caple_m Jul 29, 2010
    nah dont think that the problem the frigge used to work fine before the mother board was changed I had an voltage spike at home that burnt the old board
  • 420 Answers
It sounds like the condenser is not getting proper airflow, I am assuming you've already turned the temp control to a colder setting
Posted on Jul 29, 2010
Can you buy ice cube trays with lids so that everything does not spill all over the place in the freezer?
Bed, Bath and Beyond have a great ice cube try that has a lid which slides on. I think it's a brilliant invention;
http://www.bedbathandbeyond.com/product.asp?SKU=11894224
Amazon also have ice cube trays with click on lids;
http://www.amazon.com/Chef-Buddy-Cube-Trays-Lids/dp/B004UII7JE
Feb 18, 2013 | Home
Water Shute freezing up in ice maker
freezer maybe turnedup to high ck manufacturing recommendations
Feb 06, 2013 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice cubes won't eject
if they will not eject . then i would think the mold & or heater have failed . it works like this . it fills / it freezes/ ( the freezer must be 15 deg or lower for ice mker to cycle . ( cck the tempt ) and if ok then the thermo cycles the ice mker . during the harvest cycle the mold heater comes on and warms the mold and releases the ice. the hands move the ice out . .. so if cold enough the ice mker is bad. cheaper to repl ice mker than repair it . in most cases . mm hope this helped feed back pls ..
Oct 21, 2010 | Maytag PTB19BBGR Top Freezer Refrigerator
Temp not holding. temp up in the 60's
Possible poor connection where the fan was replaced on 6/9. Possible bad switch that turns the fan and light on and off as the door is used.
Jul 28, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Inside freezer is icy and water cant get in to make ice.
the water valve is probably bad. it leaks slowly into that tube and freezes up solid causing this problem.
  • if you already checked this and think it is a different problem then let me know, i will help you figure it out.
Jul 18, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Maytag side by side model GS24C8C3EV Refrigerator too warm
it is almost certainly a defrost problem. when fault has occured, remove freezer bzck panel and see if there is ice build-up. if so this confirms a defrost problem - possibly that the element is open circuit
Jun 21, 2007 | Maytag MSD2434GE Side by Side Refrigerator
Leak from icemaker shorts electricity in house
It sounds like the ice in the bin is warming up enough to melt for some reason then re-freeze. Check your door gasket seal and also the ice chute door flapper seal to make sure warm room air isn't being drawn into the ice bin area. Also make sure the freezer area is VERY cold like 0 degrees F or lower, that will keep the ice hard and help stop the ice from having a liquid surface film from opening and closing the freezer door too often (then freezing again). The water down the back is from the ice cubes melting a little then re-freezing. Also, is the frige working OK? Does the compressor turn on and off normally? I ask because sometimes the compress start device is failing and the refer can warm up quite a bit while the compressor is trying to start up... eventually the compressor will start but by then the ice has melted a little then the compressor runs for a long time to bring the temps down again. Monitoring with a thermometer every hour will show if the temps are lowering in the freezer section too much.
Dec 10, 2006 | Maytag MZD2669KE Side by Side Refrigerator
GE GSS22JER Side by Side Refrigerator Logo
117 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
