Question about Panasonic TH-50PX75U Plasma HDTV
My panasonic 50'is showing a bottom half picture
  • 51 Answers
This is normally caused by the upper scan buffer board.
Posted on Jul 29, 2010
Pioneer pro-1130hd no image top half of screen which board does this issue point to the x or y drive
X is for all display lines
Y is for individuals.
Go for Y board since half screen is working.
Feb 18, 2016 | Pioneer PRO-1130HD 50 in. Plasma...
Panasonic plasma tv th42px8ob 2 inche vertical line showing
do the proper isolation proceedure and try unhooking the Su from the SC board to see if you then get a normal picture all the way across the bottom half of the screen? I am assuming the Vertcal extends extends all the way from top to the bottom of the screen?
Aug 06, 2012 | Panasonic Televison & Video
Old Panasonic tv approx 10/12 y/o? -Model TX-28CK1L Serial no ND-0360158 Last night 50% of screen from top to middle "blacked out"--half picture still visable on bottom half. Very bright thin...
The main coupling capacitor feeding the frame scan coils has failed or the output stage on the frame stage has failed due to dry capacitors or dry joints.
Fault finding and components are not a problem and yes it is very repairable. Any technician that knows how television works can repair this standard frame output stage.
I hope you find a good technician.
Dec 30, 2010 | Panasonic Televison & Video
Panasonic Plasma picture losing 50% of the screen!
it is likely the power supply board in the back of the tv. these are a huge problem. I fixed mine for $15 by taking it apart and taking the board to a repair shop. new cap on the board fixed it.
Mar 08, 2010 | Panasonic TH-42PWD5UY 42 in. Television
Horizantal lines while showing the picture
In most cases on a plama TV the upper and lower buffer boards will cause diagonal lines to appear in the picture in top or bottom half or sometimes both.
Jan 12, 2009 | Sony FWD50PX2/S 50 in. Plasma Television
Missing bottom 1/4" of screen
It is possible that you have zoomed in your picture inadvertantly. Try going to picture settings and making sure that you are zoomed out all the way.
Hope that helps!
Dec 30, 2007 | Samsung HL-P5063W 50" Rear Projection HDTV
Panasonic 50 inch plasma tv
It's hard to say without seeing a picture. Panasonic has a site with pictures of various Plasma symptoms and the board that will cause that problem. Go to: http://www.pasctraining.panasonic.com/PASS/elearn/PDP.htm Click on: Pictures of plasma symptoms It will direct you to a PDF file. It may not be your exact problem, but, it will show you which board will cause your problem. Hope this helps.
Apr 21, 2007 | Panasonic TH-50PHD8UK 50 in. Plasma...
Picture on Panasonic tv intermittently becomes striated and bottom half of picture shows on top half of screen
Hello! What you're describing sounds like a vertical deflection problem if it also occurs when you're watching a TV program. This type of trouble is a component failing in the vertical circuit of your set. A loose solder connection could cause this. On the other hand, if it just happens when you run the VCR, your problem could be somewhere in the tape drive mechanism or possibly a bad tape. Things like slipping clutches,bad belts sticking guide rollers are a few things that will cause this in a VCR. You need to have a tech check it for you. Hope this gives you some help. Stargazer
Feb 03, 2007 | Panasonic CT-34WX54 34" TV
Panasonic TH-50PX75U Plasma HDTV Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
