Question about Toshiba Satellite L505-S5966 Notebook
My numeric keypad went out a couple months ago. The numlock light no longer comes on and none of the keys on the keypad function. I have the most up to date drivers and BIOS. I've googled many different **** functions to try. I even bought a new keyboard, but when I installed it, I had continued to have the same problem. What can I do to fix this?
The numeric keypad of my laptop toshiba satellite l505 does not work even if the numlock led is turn on
Posted on Aug 05, 2012
4 Suggested Answers
  • 551 Answers
SOURCE: numlock problem in HP DV9000
why need to press numlock when it has already a numeric numbers above? when pressing numlock on a laptop it will turn the letters to number because you lock the it. now to go back on the letters you have to press again the numlock key.
Posted on Apr 08, 2010
Geekman
  • 32281 Answers
SOURCE: work with an external numeric keyboard
I'm afraid that is not possible. The only way to overcome this is to get a full size USB keyboard and plug it into the laptop's USB port and type using the full size keyboard.
Posted on Sep 01, 2009
  • 80 Answers
SOURCE: hp probook 4520s numeric keypad not working even
Hello susan, if the numlock key doesnt work.
id recommend for you to do a restore.
just type in restore on the seach bar after you press the start button on the lower left habd side of your screen.
this lets you go back to the previous setting when it last worked.
Send us a feedback if it works.
Posted on Mar 04, 2011
The numeric key pad on my keyboard does not work
There's usually a Numlock key that turns off the cursor movement and turns on the numeric keys. If it doesn't say "Num Lock" or something similar, you might need to press the Fn key with the F1-F12 key that looks like a numeric keypad. Pressing the Shift key while pressing a number on the numeric keypad should give a number output if the Num Lock is turned off, the cursor movement if Num Lock is on.
Jan 25, 2018 | The Computers & Internet
What is the keyboard combination for Ñ in a
Alt+0241
On Windows, the Alt key functions as a modifier like the Shift key. To make special characters, hold down the Alt key and type in the numbers from the numeric keypad. Note that on the some small keyboards (e.g. laptop keybaords) the “numeric keypad” is found by pressing the NumLock key and then looking for the keys on your keyboard that double as numeric keypad keys when in NumLock mode.
Jun 23, 2010 | Dell Keyboard for Inspiron 1420, 1520,...
I NEED A MANUAL TO SHOW HOW TO GET MULTIFUNCTION KEYS TO WORK. FOR EXAMPLE HOW DO I GET THE ALTERNATE USE OF THE "NUMERIC 6 "KEY ie THE" QUESTION MARK" FUNCTION
You must have a different keyboard selected other than the standard US keyboard My numeral 6 has ^ on it and the numeric keypad 6 has a right arrow. One generally uses the SHIFT key to access symbols that are written above the main alpha or numeric key. The numeric keypad on side of PC has a button labeled key marked NUMLOCK that is engaged to allow use of the numerals as a calculator or to also be inserted into text.
Please rate my help++++Thanks for using FIXYA
May 09, 2010 | Acer NSK8458AN Keyboard
Unlock numeric key pad on lap top
your laptop should have a blue FN key (Function) that will work in conjunction with other blue keys on teh keyboard. most laptops this is located in the lower left, next to the ctrl key. Look to the right top on your keyboard for a one labeled numlk. hold down teh left FN key and tap the right num lk key and you just turned off the numbers lock.
There is another option that is a little more intense - if interested let me know that laptop type you have.
Feb 04, 2010 | Microsoft Windows XP Professional
Keyboard is stuck in numeric mode. Can't type
On the Panasonic Toughbook CF-51 there is a key located on the top right next to the F12 function key called "NumLk" or Num Lock.
Press this key once and the embedded numeric keypad is enabled.
Press it a second time and it is disabled.
How do you know if it is enabled or disabled?
Simple: Observe the LED above the keyboard. If the second light with the square symbol and the number "1" is lit up, then the NumLock is enabled. If that LED is not lit up it is disabled.
Good Luck.
From Richard, Montreal Based Panasonic Canada Authorized Toughbook Dealer since 1989.
Oct 02, 2009 | Panasonic Toughbook CF-51 Notebook
Work with an external numeric keyboard
Sep 01, 2009 | IBM ThinkPad R52 Notebook
Cannot turn on the numeric keypad, even after pressing NumLock
ya !! you can try more to remove keyboard then again pluged in USB.and restart the system..may be it will wrk.... or u can try more to restore computer system....
Mar 23, 2009 | HP Internet Keyboard
Keyboard letters 'm,j,k,l,u,i,o' permanantly locked for numerals. i have no idea how i switched this function on.
NumLock is on. Look for the Fn key in the lower left corner, and lookint in the top right, the NumLock key.
Mar 22, 2009 | HP 2133 Notebook PC
Left keypad inoperable - mostly
I would get a new one and go from there. Why play around with it?
Oct 05, 2007 | Compaq Keyboard
External keypad problem
I don't think there is a solution for this, this is by design Probably on your friend's keypad there are only numbers and no arrow functions on 2 4 6 and 8?
Jul 04, 2007 | Belkin Numeric Keypad Keyboard
Toshiba Satellite L505-S5966 Notebook Logo
150 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
