Question about GE JVM1440 Microwave Oven
Same problem I have a Ge spacesaver model JVM1440Wh04. The unit started to emit a squeaking noise and the microwave sounds like it is laboring or under a heavy load. It heated at this time as well. Tonight we turned it on and the unit shut down. No lights on the display. The breaker did not trip. After a few minutes the ubit powered back up on its own but when we try to run it it cooks for a while but shuts off. The fan was running the other day. Is there a second fan? What would cause it to sound like it is under a heavy load. This unit was Mnaufactured in 2005 but we have only had it for 3 yrs. I AM HAVING THE SAME PROBLEM. DOES ANYONE KNOW WHAT'S CAUSING THIS OR HOW TO FIX IT?
  • 736 Answers
Your oven shut down because the magnetron got too hot (has a resetting thermal switch) .. it needs a constant and high flow rate of cooling air .. there is a fan that blows air over the magnetron fins ... sometimes the plastic frame that holds the fan becomes warped or broken .. the fan then doesn't deliver enough air to where its needed ... the squeaking noise however may indicate that the fan blade is either hitting the frame or the bearings in the fan motor need lubricated ... the fan is most likely the problem .. you can replace it or Lube it and repair any broken mounts .. make sure the fan turns freely and is aimed correctly .. use a light machine oil (intended for very small motors) or sewing machine oil .. not wd40 or oil with teflon .. your magnetron will be damaged if it continues to overheat .. you can gain access to the fan by removing the cover but do so only with the power disconnected and taped so no one can plug it in while you are working .. when plugged in there is potentially deadly voltage and current available inside .. . there are indeed two fans .. the vent fan and the magnetron cooling fan .. the loud laboring noise often happens if the magnetron is shorted or if the high voltage diode or voltage doubler capacitor is shorted ... but since your machine is still working until it gets hot i suspect those are not he problem yet but may be eventually damaged without cooling air flow .. that model GE did have problems with the fan mount and that in turn damaged some magnetrons ... the lube in the fan bearings generally is reliable up to 5 years depending on use .so that could be the problem as well
Posted on Jul 30, 2010
Why does my GE Spacesaver Profile, Microwave/Convection Oven, model # JVM1490SD003, in my motorhome, make a clicking noise when I start it up? Sounds like a fan hitting something. The noise goes away
Probably is the fan tapping something. Power it down/DISCONNECT power. pull unit and if there is a cover, remove it. look for the convection fan and see if it free-spins. should find spot where it is hitting and could be adjusted.
Nov 22, 2014 | GE Microwave Ovens
Microwave oven General Electric oven flashing F3 how can I fix this model #JVM1440WH04
Unplug the unit for 1 minute to clear the ECU.
re-plug, and re-try.
Thanks
Oct 22, 2011 | General Electric Microwave Oven
GE spacesaver II making loud noise and is not heating up food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacesaver microwave JVM1631WB002- making popping noise
The material is popping as a result of being heated.
Jan 19, 2018 | GE Microwave Ovens
Jvm1440wh04 GE Spacemaker. no microwave cooking
Could be an open internal fuse or magnetron failure
Mar 07, 2018 | GE JVM1440 Microwave Oven
Microwave no longer heats; makes no sound or buzzing noise
hi..it sounds like a magnetron problem.It might have
got into damage.
check this out..
thank u..
kindly rate my response..
Jun 14, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave makes a strange humming noise when it is working - sounds like a vibration of some kind. Does not always happen. Somethings it starts once the microwave has been running for a few seconds. ...
Assuming nothing's loose (such as from past repair attempt) then it may be the magnetron failing.
Your best bet is to keep using but (as always) do not leave it unattended while it's running.
Then if things get worse in some way, that would be a harder failure that can be assessed more easily.
If you are close to the end of the warranty period (1 year parts & labor or 9-year magnetron, e.g.) I would not wait past then.
GE Customer Service is here if you would prefer service now and want to find your nearest GE-authorized servicer.
Oct 14, 2008 | Microwave Ovens
GE JVM1440 Microwave Oven Logo
372 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
