Question about Visioneer Strobe XP 100 Path-Through Scanner
Page scans black - Visioneer Strobe XP 100 Path-Through Scanner
My HP laserjet 3050 when i copy a page the paper prints black
Symptom: Black or Blank image while copying or scanning.
Part suspect rating: Scan head..70%
Scan head cable...25%
Formatter...5%
For tech guys only: Remove ADF unit from the printer, remove both side covers of adf, remove & replace scan head, check...
Replace scan head
Jul 21, 2012 | HP LaserJet 3050 All-In-One Printer
Scan and copy produce a black page
Scan head faulty(which is moving while scanning & copying) , replace it..
Nov 16, 2011 | HP Officejet 6500 Wireless All-in-One...
Black lines on scan
Dear all
I have the same problem Please Help
Mark
Jun 04, 2010 | HP ScanJet 2300C Flatbed Scanner
When I scan pages in the computer using the document feeder a black line appears on the scanned pages. what can I do?
Try cleaning the PMT (Photo Multiplier Tube) - the glass tube that picks up the image. If there is a foreign body or dirt on the tube you will see a black line vertically (in the scan direction) on the page.
Apr 12, 2010 | Canon PIXMA MX310 All-In-One Printer
I scanned a 17 page document to pdf and got a 15mg file which I could not sent by e-mail. Checking some other pdf files, I see a 47 page document that is only 5kb. What's the deal? BwO
Resolution you scanned it at as well as scanning in color versus black and white. Also, that 47 page document might be vector graphics and text rather than bitmap information.
Scan in 200dpi black and white to get a usable (readable) and small file. Should be about 100-200kbytes per page.
More info on scanning: http://en.wikipedia.org/wiki/Image_scanner
-=/ Daft Tech /=-
Oct 23, 2009 | HP Officejet 6500 Wireless All-in-One...
When I scan the pages it has a black line..
Try to peek into the scanner while scanning, you probably have a burned out LED element.
Oct 13, 2009 | Panasonic KV S2026C Path-Through Scanner
HP Laserjet M1522nf Multi page scanning problem
Check this thread in HP forums:
Second Page Scan is Garbled on HP1522nf
Download the file attached to LARS post halfway down the page and follow his instructions on how to unzip and install it.
Hope this helps.
Sep 11, 2009 | Office Equipment & Supplies
Brother Scanner, scans the page but prints black and vertical
I called technical support for this issue previously with my brother mfc. It would only do this during color scanning. b&w scanning was just fine. The tech support put me through resetting the reference point of the scanner through a series of button pressing and closing and opening the paper feeder. I kept gettting the same lousy results. Then they determined that the scanner module needs replacing and I needed to take to the nearest service center.
Dec 23, 2008 | Brother MFC-8640D Printer
Documents scanned as 256 grey scale/TIFF show up as black pages.
Grey as you know is different shades of black. Uncompressed TIF can store this information. Compressed TIFF is not designed for this. Compressed TIFF is for blck & white only. Try JPG option. JPG can compress Color & Grey. For pure black & white chose TIFF compression.
S. Mohan, Chennai , India
Jan 05, 2007 | Canon DR-9080C Path-Through Scanner
Visioneer Strobe XP 100 Path-Through Scanner Logo
69 people viewed this question
Top Visioneer Office Equipment & Supplies Experts
TomHighRidge
Mark Gough
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
