Fitting new door seal on on indesit washing machine widl 126
TampaNative
  • 778 Answers
SOURCE: FITTING NEW DOOR SEAL ON WHIRLPOOL AWM5125
Usually it will be just be reversing the procedure of removing the old seal. At any rate, the door will need to be disassembled.
Posted on Mar 29, 2008
  • 139 Answers
SOURCE: indesit widl 126 uk
Turn the control knob to a black dot leave the door open and press the on off button in and out quickly and look for a change in the lilght,, it should blink 3 times rapidly once it does ,, then the machine is reset and ready to use,,,
if you have any problems let me know im here for another hour..
Posted on Jan 25, 2008
  • 57 Answers
SOURCE: we have just bought a
Hi to replace the seal take off the metal ring with a small screwdriver at the spring on the front of the machine than take off the seal then take the top off the machine and locate the screw on the metal ring undo a bit then take off seal replace and put back the new seal in reverse order as I have written
Posted on Jul 18, 2008
  • 1075 Answers
SOURCE: how to fit new door seal on Indesit W103 washing machine
this is not an easy job,go online and down load a copy of the machines manual even check out indesits web page.adrian
Posted on Feb 27, 2009
localwonder
  • 6784 Answers
SOURCE: My indesit widl 126 is not drying
If electric, check the following areas.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
If gas, check the following areas.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective
Posted on Jul 09, 2009
Washing machine not working
The lid switch/latch has failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 10, 2009 | Washing Machines
I do i stop the indesit widl 126 mid cycle?
Open the door - or press stop/cancel.
Jun 28, 2009 | Washing Machines
How to fit new door seal on Indesit W103 washing machine
Feb 23, 2009 | Indesit W 123 Front Load Washer
Indesit WIDL 106 wont start -ON/OFF-Door Led Flashes rapidly
It is a defectiv controller pcb. I think the eeprom on the controller pcb lost its program (happens often on Indesit machines).
The only solution I know is to change the controller pcb, - not a cheap solution.
I have the same problem with WIDL 106.
Dec 01, 2008 | Indesit W 123 Front Load Washer
Wiring for Indesit Widl 126
Tell me, is the machine compleatly dead or what is it doing?
Sep 10, 2008 | Indesit WA 115 Front Load Washer
Indesit widl 126-problem with the drum,moving back and forth to much and noisy.
It would seem that the bearings go on this model, which causes the inner drum to knock and bang against the outer during spin. If you continue to use the machine without replacing both sets of bearings, it will cause irreparable damage and the machine will need to be replaced.
Apr 27, 2008 | Indesit Washing Machines
Indesit widl 126 uk
Jan 25, 2008 | Indesit WA 115 Front Load Washer
Washing Machines Logo
66 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
