Question about Google Android
Droid X phone won't ring for incoming calls.
I have my Droid X set to ring for an incoming call (Android "Bell Phone" ringtone), and I have "phone vibrate" unchecked, but incoming calls continue to make the phone vibrate with no ring. How can I fix this?
Found on Motorola Support:
1. Make sure that the "Smart Profile: Face Down" feature is enabled.
2. Hold the phone face up in your palm.
3. Call your Droid X from another phone.
4. As the phone is vibrating, DO NOT ANSWER.
5. Still holding the phone, flip the phone face down as it vibrates.
6. Still holding it face down, hit your volume key to silence the phone.
7. Flip the phone back over so it's face up. You should feel a quick vibrating jolt indicating the ringer is back on.
8. End the call. It shouldn't matter which phone you end the call from, as feeling the jolt is the key.
9. Leave phone face up and call yourself again. If the ringer is now working again, turn OFF "Smart Profile: Face Down" until there's a true fix.
10. If it does not work initially, try all of the steps again a few more times and hope you get lucky.
Posted on Sep 27, 2010
I don't know. I have the same problem. Really frustrating to have an expensive new phone that will not ring!!!
Posted on Sep 19, 2010
I dont hear the ring when there is an incoming call despite the settings on volume is correct-It only vibrates.The alarm,Music,Video games,other media are ok-what could be the reason?
Please do check the Phone Ringtone
If the ringtone file is missing this may happen
Try change another ringtone (This option may be available under volume settings)
Jun 10, 2015 | Sony Xperia C1904 Android Smart Phone with...
The ringing tone just stopped - it won't ring with an incoming call. All settings are correct - and volume is set at the highest
try to assign a different ringtone (if it works its not a problem with the phone its with ringtone itself that you are currently using)
Aug 27, 2011 | Nokia 6300 Cellular Phone
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
Ringtone.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
Volume
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
Dear sirs. I hope you can help. I just got the droid HTC EVO. i somehow installed a music video that plays and displays whenever I get a phonecall with this terrible clip of some musician. I desperately...
here are two ways to setup a ringtone for incoming calls.
  1. From the Home screen tap Settings > Sound & display > Phone ringtone. Tap the ring tone you want to use on the list, and then tap OK.
  2. You can also use a music file as a ringtone. To set up a music file as your ringtone, please use the micro USB cable to connect the phone to a USB port on your computer. The Connect to PC dialog box displays and prompts you to choose Disk drive > Done. Your phone's SD card is mounted as a drive on your computer. You can now copy music files to the SD card.
After you have finished copying, open the notifications panel (by touching and then dragging the status bar down) on your device; then in the Notifications panel, touch Charge only.
Then tap All programs > Music > tap the music you want to set as a ringtone (the music will start playing) > press Menu > Set as ringtone. You can set the music file as a Phone ringtone or Contact ringtone or you can select Trim the ringtone.
Jan 16, 2011 | HTC EVO 4G Smartphone
How do I change the ringtone (incoming call) on the phone set?
You can change the incomming ringing for your set by pressing feature *6 , press the next key to select the ring type and ok to store the new ring tone.
Feb 22, 2010 | NorStar T7316E Corded Phone
Downloaded a ring tone with the memory card but when i load it on the phone it will only play as music, can't set it as a ringtone.
Hi friend,
Could you tell me if your cell phone can support the function?
You can check like the following:user profile-General-Customize-Tone setup-Incoming call,then you can see many ringtones in it,Could you see the icon"empty"?If so,you can set the ringtone you downloaded as the ring tone of incoming call.You just need to find the ring tone you downloaded,and transmit it to the "user profile".
But if there doesn't have any "empty" icon,I am afraid that you cannot set it.But you can try to cancel some ringtones ,and replace them by the ringtones you downloaded.
You can get much detailed information in the website:www.1010store.com
Sep 15, 2009 | LG Xenon GR500 Cell Phone
Have nokia 3120 , incoming call does not rings
check if the format of ringtone set is compatible with your phone..
try to restore the refactory settings once.
thankyou.
Nov 19, 2008 | Nokia 3120 Cellular Phone
Ringing time
your phone accepts downloaded audios for ringtons, if you want a long ringtone, you may set a whole song to be your ringtone, or perhaps a long ring ring sound.
or if you only want your regular tones to be longer, try to set the ringer to "ASCENDING"
Aug 09, 2008 | Nokia 2630 Cell Phone (Unlocked) - Black
Ringtone wont play
with the phone closed, goto tools, voice commands....click on settings in the lower right.......scroll down to call alert.......change to ring only or caller id+ring....on the env that should solve your problem
Dec 12, 2007 | LG enV VX9900 Cellular Phone
Phone wont play ringtone with incoming call eventhough one is selected will spell out number calli
Google Android Logo
1,763 people viewed this question
Top Google Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
David Payne
David Payne
Colin Stickland
Colin Stickland
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
