Question about Sharp AR-168S Copier
I have a Sharp 168S copier/printer/fax and replaced the toner cartridge with a remanufactured cartridge. I made approx. 100 copies then it gave a U2-40 system error and would not print. I replaced the toner cartridge again with a new Sharp cartridge and the error went away but now I am getting a maintenance needed-call for service message. What could this be?
  • Sharp Expert
  • 1,326 Answers
Try taking the toner out and shake it gentle, then reinstall the cartridge. If that does not work, you may have a bad toner cartridge.
Posted on Jul 30, 2010
Ar-m276 u2-40 error
its bad comunication between the toner cartridge and developer so you need to replace the toner cartridge or the chip on the rear side of it
Mar 14, 2012 | Sharp AR-168S Copier
Just purchased a Zerox XC1255 Copier at an Auction. Replaced the toner cartridge because the light was on. The copies seem to have excessive toner in the background of the copies. I am wondering if I...
Could be a bad drum unit. Is the new toner cartridge a refilled? Remanufactured? or Brand New Xerox brand toner? If it is refilled or remanufactured I would run some copies and give it a chance to clear. Sometimes they end up with too much toner in the Developer mix and can be overtoned which causes a general background over the whole page. They should clear up as you run copies, say within 100 pages. Also try manually lightening the copy with the exposure control on the operation panel. If lightening the copy clears all of the background then you need to have the optics cleaned. There are 4 mirrors under the large original glass that need to be cleaned. If all this fails then you are looking at either drum unit or a defective or out of balance toner/developer cartridge.
Good Luck and Thank You for using Fixya.
Aug 18, 2010 | Xerox Office Equipment & Supplies
HP 3055 All In One laserjet prints all black pages
Odds are that you have a bad toner cartridge; especially common when using remanufactured cartridges. (Staples, Corporate Express, etc.) Replace your cartridge with an OEM HP cartridge and you should be OK.
Feb 22, 2010 | HP LaserJet 3055 All-In-One Printer
I have an older Sharp AR-168S printer with U2-40 error code.
U2-40 CRUM communication error
Detail-Toner cartridge CRUM data read
error
Cause-A toner cartridge of a different
destination is installed.
EEPROM trouble
Check the destination setup.
Toner cartridge CRUM PWB trouble
MCU PWB trouble
CRUM connector disconnection
Check and
remedy-
Install a specified toner cartridge.
Check the SIM 26-6 setup.
Replace the EEPROM.
Replace the toner cartridge.
Replace the MCU PWB.
Check connection of the CRUM
connector.
Execute SIM 16.
Feb 09, 2010 | Sharp Office Equipment & Supplies
Error code F2-04. Have replaced cartridge but to no avail for the Sharp Model # AR 168S Copier.
Try this solution I found on an other site.
In a Sharp MX-M450N copier this is due to improper cartridge.
The reason for the error code is of course due to an incorrect toner cartridge being used on the copier. You can turn the copier off, but it will not flush from memory. in order to correct the issue perform the following:
1. Turn the printer off
2. Remove the incorrect toner cartridge
2. Unplug the power cable from the wall outlet.
4. Plug the Printer back on
5 Turn the printer back on
You will see the message change to another message requesting to insert the toner cartridge.
6. Insert the old or new correct toner cartridge into the copier.
Dec 28, 2009 | Office Equipment & Supplies
Hp 3550 not reading toner
Initially check the silver metal parts on sides of toner are not covered with any plastic tapes, then also check that the spring for earthing on the right side of toner is fitted properly.
Also clean the inner parts of printer which comes in contact with cartridge sensing assembly and then reinsert the toner.also unplug and replug-in the printer power cord once if necessary to reset the printer.
thanks.
Aug 31, 2009 | Sharp AR-168S Copier
System error [f02-04]
I believe you asked the same question before.... Make sure the waste toner cover / plug is removed and that you shook the cartridge to loosing the toner. You may have recieved a bad or defective toner cartridge...Good Luck
Aug 16, 2009 | Sharp AR-168S Copier
Sharp AR 168s cant fax
If the fax kit is installed you will see the phone ports on the back. If no ports then you don't have the fax kit. It was not standard in the 168s
Jan 23, 2009 | Sharp AR-168D Copier
I BOUGHT A REPLACEMENT CARTRIDGE FROM A COMPANY THAT REMANUFACTURES THEM THRU XEROX,ANYWAY THE INK TONER CARTRIDGE IS FOR YOUR Z-85II COPIER AND THE INK WAS EVERYWHERE WHEN I TOOK IT OUT OF THE PACKAGE AND...
You are right about the cartridges having a seal. These toner remanufacturing companies are known as TONER PIRATES, they don't change the drum or cleaning blade, they just dump in toner.
Try wiping the inside with STRETCH AND DUST cloths before you put the new cartridge in.
If that doesn't work, I have to recommend that you get it cleaned, as the spilled toner will blow straight through a regular vacuum.
Oct 28, 2008 | Sharp Office Equipment & Supplies
Drum replacement
please open right cover and out in your toner box you saw a screw is open and turn in fornt developer unite open your drum unite
Oct 15, 2007 | Sharp AR-168S Copier
Sharp AR-168S Copier Logo
104 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
