Question about Delphi SKYFi3 XM Radio Receiver with Car Kit
Powers up but locks up on "detectin sd card" screen
My skyfi 3 powers up but will not get past the "Detecting SD Card" screen. This has happened several times but issue would resolve itself if I let the battery run down or if I removed and replaced the battery. This is not fixing the problem this time--any ideas?
  • Delphi Expert
  • 509 Answers
A very common problem on the SkyFi3! Press the volume UP and the Power button at the same time and it will finally go off. Go to the Delphi/XM website and upload/download the latest FIRMWARE and upgrade it. Then, call the 800 phone number for Delphi and they will tell you a secret master reset you have to do once or twice, and it will cut down the number of lockups during checking media by quite a bit. Also, do not use a Micro SD card larger than 2MB as well. Good luck, and let me know how it goes for you.
Posted on Aug 10, 2010
I have a SD card for n\my camera the lock is broke in the locked position. How do I get the pictures out?
you can take all the pictures out by copy pasting it lock all ways alowes you to read just stops you from writing or deleting so just connect the sd card on your computer if it has a built in reader or put it in a card reader and just select all and copy and past it to your drive anywhere u want.
Mar 01, 2014 | Transcend 16 Gb Class 10 Sd Sdhc Memory...
Micromax Q7 not detecting Kingston 16 GB SD card I
If you need more details just click this link now : http://www.mtsdelhi.in
Aug 07, 2013 | Acer (90.18612.36B) Computer Speakers
MY MEMORY CARD WILL NOT LOCK INTO PLACE WHEN I PUSH IT INTO SD SLOT
  • Most likely the SD card is not being pushed in far enough to lock into place. You really need to use your fingernail to push it in past flush until you hear a clicking sound, at which point the card will lock into place.
  • Here are full instructions for insertion and removal of the SD card: Insert the memory card with the metal contacts going into the slot first and facing up at you. In other words the SD card label should be upside down when you insert it this way. You need to push the card in past flush to have the spring mechanism lock the card into place. To get the card out of the slot, push the card in past flush and then the spring mechanism will release it. You will hear a click when the card locks into place or is released from the slot.
  • Dec 05, 2010 | Bushnell Trail Scout 11-9500c Digital...
    Moultrie MFH-DGS-200 .... says SD Card Locked on
    ck postion of switch on side of SD card...should be pushed toward contacts
    Oct 23, 2009 | Moultrie MFH-DGS-200 Digital Camera
    My SkyFi R 1.18 does the same thing but the solution here doesn't
    If it freezes, you have to push the volume UP button and Power button to 'reset' the unit.
    go to the XM website and get the latest FIRMWARE update for the SkyFi3 and download that. Also, you CANNOT use an SD card larger than 2GB or you'll have problems too. So first, upload the new firmware (using the AC adapter plugged directly into the bottom of the radio) and the cable that they gave you to hook up to your computer and do the firmware update. Delphi customer service can walk you through this too. Good luck, you'll get it pretty soon.
    Aug 08, 2009 | Delphi SKYFi3 XM Radio Receiver
    Sd card is not working
    Try cleaning the pins of SC Card with contact cleaner or alcohol if you prefer make sure its dry enough before inserting. If nothing happens try detecting it on PC Desktop with proper Card reader, backup files if you still can then reformat thE SD Card. Reinsert in your HTC G1 if successful reformat it again using your HTC G1 to acquire compatabilty on the device.. hope this help...
    Jul 23, 2009 | HTC G1
    Powering up Delphi SkyFi 3
    I found the soloution to my problem on the "Shop Delphi" website. I had to do a hard reset described at this link:
    http://www.shopdelphi.com/contact/ce/s_pf/#2516
    It erased all memory in the Skifi and reset everything back to factory specs, but I have my radio back.
    Rod in Tennessee
    Mar 21, 2009 | Delphi SKYFi3 XM Radio Receiver
    Delphi SKYFi3 XM Radio Receiver with Car Kit Logo
    184 people viewed this question
    Top Delphi Audio Players & Recorders Experts
    Darrell
    xxxxxx xxx
    Marvin
    Marvin
    Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
