Question about LG WM-2277HW Front Load Washer
Buttons not working on lg washer
It takes me about 10 tries to get the washer going. 9 out of the 10 times I turn the power button on, turn the cycle selector knob to Permenant Press or any other setting and try to adjust the temp with the wash/rinse button and that button seems to be not working at all. I tried just turning the selector knob to various cycles and pushing the start/stop button, it does not do anything either. Then all of a sudden the buttons will work. All of the other buttons seem to work all of the time. Thanks for any help you can give.
  • 1 more comment
  • Kiota May 30, 2008
    I have the same problem on my LG WM2077CW. So far repair boards have not fixed the problem. It has been repaired 3 or 4 times. It will work fine for a bit then start having the same problem again. All the other buttons work fine. The only button that doesn't work is the start button. Critical button.
  • dmk708 Jan 13, 2009
    would the display board be covered under the computer board warrenty?
  • Anonymous Mar 13, 2009
    I wonder if it can be related to the Delay Wash function somehow. I have similar problem. I cannot get the power on at all and suddenly when I look at the machine after a while it is on.
    New Friend:
    Problem Solver:
  • 6 Answers
I had this problem with another model LG washer dryer and the problem was just the tiny switch (6mm x 6mm) on the circuit board had worn out. They cost about 30 pence on eBay and are very easy to remove and re-solder onto the circuit board as there are only 2 pins. This saved a huge amount of money for a new control board.
Posted on Mar 28, 2014
  • 489 Answers
Sounds like the display board has a malfunction in the button controls and needs to be replaced.  Call a qualified LG tech to have it replaced and that should take care of the problem.
Posted on Apr 27, 2008
    Champion:
  • 210 Answers
Could also be that the board has not been screwed on tight enough so it has a bit of play in it. You would have to check to see if the boards that are behind the display panel are on correctly.
It could also be a defect in the board.
Sgt 48
Posted on Jun 02, 2008
My lg washer wont turn on model # wm2010c is there a reset button?
No reset, but you can try unplugging, hold in power button for 10 seconds, plug back in and see if it works.
Feb 07, 2018 | LG Washing Machines
Power cycling
Push the "menu" button on your remote
Tab over to the "time" menu
check all the settings in there, turn of the sleep timer etc...
Try a factory reset
Push the "menu" button on your remote and go to settings, scroll down and push reset.
I hope this helps
Feb 10, 2014 | Samsung LN40D550K1FXZA - LN40D550 40 1080p...
Lg tromm manual
Problem is too much soap. Wrong soap. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
Wait for door to lock.
Press the START button (6) times--this will fill the tub with hot water to the maximum setting when it stops filling.
Press the START button two more times--this will enable the tub to tumble.
After 3 hours--turn "off" the washer.
Turn the washer back "on".
Select the shortest wash cycle (usually "quick wash") and press "START". This will rinse out the tub.
Jan 17, 2014 | Washing Machines
My LG washer wont turn on, if I unplug it from the wall and plug it back in, it will work for one cycle, but then the next time I go to use it, I have to unplug it again to get it to work.
After searching for the answer as to why my LG WM2455H wouldn't start unless I unplugged it and then plugged it again, and trying many "solutions", such as holding the power and start buttons for x amount of seconds, I finally found one that worked. Just before ordering a new control panel, I decided to search one more time for an answer, and found a young man claim that his uncle told him the answer to solving the problem. It's a little weird, and I was very skeptical, as you will be, but it DID WORK to let my washer power on after running cycles of wash. Here it is: Within 12 seconds, push in the POWER button and let go, then open and close the washer door, repeat by pushing in power button again, and let it go, then immediately open and close the washer door again. Do this six times within a 12 second time span. According to the young man on youtube, this procedure RESETS the controls. I would still be a little skeptical, except my machine behaves like it's suppose to now. PLUS, I did nothing that might be attributed to the solution (except think about how I was going to move the heavy washer away from the wall to replace the Control Panel I planned to buy). So, I hope this works for you. It certainly saved me a lot of time and money.
Feb 12, 2012 | LG WM2455 Front Load Washer
LG WM3987HW Washer Spining very wild
I've just uploaded a service manual.
relevant info pasted below: --
Regulate a specific spin speed that generates excessive vibration and noise as follows:
1) Put an unbalance part (rubber) inside of the drum.
(this is a special weight that service people use. It clips into the drum. If you don't have it, throw in about 4 to 6lbs of damp laundry.)
2) Start the QC test mode (Refer to section 7-2).
7-2 says turn the washer off, then press 'spin speed' and 'soil level' at the exact same time. Then, while holding both buttons, press power to start "QC test mode"
3) Press Delay Wash button, then ' tst ' is displayed on lcd
4) Press the Spin Speed button repeatedly to select Extra High.
5) Press the Quick Cycle button, the spin speed is displayed.
6) Press the Start/Pause button.
7) Press the Beeper button repeatedly to set spin speed (600, 800, 1000, 1200 rpm) and check if there is vibration
and noise.
8) If there is no vibration and noise, increase the spin speed by pressing Beeper button.
9) If there is vibration and noise, rotate the Cycle selector knob clockwise to reduce the Spin Speed (reduce by 50
and 100 rpm). In case of 600 rpm, it can not reduce the spin speed.
10) If vibration and noise are reduced, press the Quick Cycle button to store (2 beep sounds).
* If you want to return to factory default spin speed setting, repeat above steps except step 9)
Jan 10, 2012 | LG WM3987HW Front Load Washer / Dryer
My keyless entrey will not work has new battery?
Hi, please try reprogramming the fob using these procedures, and thankd for using FixYa:
Close all doors
2. Insert key into ignition
3. Hold down the power UNLOCK button on the driver's door panel, continue to hold down
until instructed to release in step 9.
4. Perform steps 5 through 8 in a fairly rapid succession.
5. Turn the ignition to the ON position (as far as you can go without starting the engine.)
6. Turn the ignition to the OFF position.
7. Turn the ignition to the ON position (as far as you can go without starting the engine.)
8. Turn the ignition to the OFF position.
9. Release the power UNLOCK button on the door panel. The vehicle should respond by
door locks locking and unlocking automatically. (If locks do not cycle after you let go,
not before you let go of the unlock button, then the vehicle has not entered programming
mode and you must start procedure over. Remove key from ignition, open drivers door
and return to step 1 ). If the locks do cycle automatically then proceed to step 10.
10. Hold down the LOCK and UNLOCK buttons on the remote until the doors lock and
unlock. This may take up to 30 seconds.
11. Repeat step 10 NOW for each additional remote. (Including any existing remotes).
12. Turn the ignition to the ON position to exit the programming mode.
13. Test remote(s).
Jan 14, 2011 | 2003 GMC Sierra 1500
Oe error code, cleaned filter, checked hose
You might be using too much detergent and causing a sudslock condition. The machine uses very little water and any amount over a teaspoon of HE will simply cause the machine to lock down. An OE error means it took longer than 10 minutes to drain the tub. IF the machine is trying to correct a sud problem it will continually toss in more water till sudslock is corrected. Press and hold: SPIN SPEED & SOIL LEVEL buttons--then press POWER button.
This method of "TUB CLEAN" is *not* from a service manual but has been the best method for cleaning out LG washers more than a year into incorrect detergent usage.
Jun 04, 2010 | LG WM2277H Front Load Washer
Drum light stays on and wont let me start it again. Its dead but has light.. I have to power down the entire house to get it to start again
I had the same problem. LG addressed the problems as follows:
1. Unplug the unit 2. Press and hold the power button for 10 seconds. 3. Plug the unit back in.
It WORKS!! It's like reseting your computer or alarm clock. You've got to kill the power and press and hold the on button while it's still unplugged.
Hope this works for you.
May 15, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Need code/s for LG WM1832CW to have washer do a spin/drain only
1. press POWER button to turn om.
2. press SPIN SPEED button only.
3. press START/PAUSE button/
May 02, 2009 | LG WM-1832C Front Load Washer
Is there a reset button on the LG front load washer
No button, but LG customer service says unplugging the unit for 1 hour and then holding the power button while turning it on will reset the computer.
In my experience this does work, but I don't think it resets absolutely everything.
Another time I had a problem LG customer service told me to unplug the unit, hold the power button for 60 seconds and then plug it back in. I can't confirm if this works or not, but it is worth a try first (60 seconds is a lot shorter than 60 minutes...).
Feb 25, 2009 | LG WM2688H Front Load Washer
LG WM-2277HW Front Load Washer Logo
1,621 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
