Question about KitchenAid Dishwashers
Have Kitchen Aid Dishwasher KUDS01FKSS1 The lights on the control panel wont go out it wont start, sometimes the lights flash,the control lockcomes on after a cycle.
  • msfelo Aug 04, 2010
    tried everything that was recomended except replacing the control panel. some the button that were sujested to push were not on the control panel.
  • msfelo Aug 05, 2010
    I Ordered the parts and hopefully it will work Thanks in advance.
  • 6,784 Answers
HI. I need to know which lights are flashing? This in very important to know. Kindly look at the control and let me know which lights are flashing.
Is it the rinse light,cancel light or all?
Posted on Aug 04, 2010
  • 2 more comments
  • Michael Masters
    Michael Masters Aug 04, 2010
    In most cases, you will need to replace the interface board. It all depends on which light is blinking and what button that light is blinking on or under. Please let me know what light is blinking.
    Interface board - 8270168
    This board is mounted inside the control panel...
    all lights are on some times,sometimes they all are flashing
  • Michael Masters
    OK, have you replaced the microcomputer- #8528874
  • Michael Masters
    Usually, when all lights flash in unison, this will indicate that the microcomputer has failed. If only the rinse or cancel light is flashing, this will indicate that one or more of the interface buttons are damaged.
  • 3,230 Answers
Well first of all you can try try to clear it by putting the machine into diagnostics mode. You can try hitting the combination one after another - high temp wash - heated dry - high temp wash -heated dry then close the door and hit cancel. wait for the pump to stop and then try to set a cycle. If you are not able to unlock the dishwasher door then please follow the below steps -
1. Press and hold down this "Energy Saver/Dry" button for at least 5 seconds. Make sure that you do not release the button until at least 5 seconds have passed, otherwise the lock will not become disabled.
2. Check to make sure that the child lock indicator light has turned off.
Note. If none of the above step works then there is some problem with the control board, may be need to replace the board.
Please post comments for further help or information........
Good Luck!!
Thanks
Posted on Jul 29, 2010
  • msfelo Jul 30, 2010
    Tried pressing all the button combinations and it didn't work.already put two hundred in it last year.Thanks for your help the dishwasher is realya piece of junk.
My Hotpoint DWF40 Dishwasher flashes wash and rinse lights. Water fills and drains fine. How do i fix it?
test this and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 24, 2013 | Dishwashers
Cancel Light Flashing on Kitchen Aid Dishwasher
I found this post elsewhere. It seems to have worked for me: Our KitchenAid KUDP series dishwasher went into a mode where it would not start and would only respond to the cancel/drain button. The clean light would flash 7 times in a row, stop, and then repeat. I read that the 7 flashes indicates an error code and that the dishwasher has detected a problem in the heater element circuit. I tried to reset the error mode by turning off power for 15 minutes, however, that did not work.
We called for a repair. The service person found that the dishwasher was completely fine except that it had gone into an error mode. The technician reset the error mode and charge us $115.00.
The reset sequence used was reported to be the following:
1) Crack the door open.
2) Within 3 seconds press the following sequence - Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry
3) Close and latch the door
4) Press the cancel button (the circle with the triangle in it)
We were told the dishwasher expects to see the dish water temperature rise in a certain way. If the water does not heat in this way, the dishwasher becomes confused and thinks the heater element has failed. In deed, this happened just following and extended power failure and our hot water tank was cool. I am curious if this code will work for anybody else with the same problem and save a service call and 115 bucks. Overall, this seems to be a serious logic flaw in the design.
Sep 21, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
When I turn my blender on, it runs for only a few seconds, then stops and all the lights on the panel flash on and off.
More often than not it will need the motor to be replaced, only Kitchen Aid parts will do, motors are usually unique to brands and models. Sometimes it can be the control/button panel but normally the motor.
Mar 21, 2011 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
What is the reset sequence of a kitchen aid kudi01fl my dishwasher wont start the control lock button is on
Press and hold the heated dry button for 5 seconds to unlock the controls. If that doesn't work go to the link below and it will tell you how to reset the control board.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Good luck
Mar 01, 2011 | Dishwashers
How do I reset kitchen aid dishwasher with the clean constantly flashing? dishwasher won't start.
Hello, push the following buttons on your control panel.......Heated dry then High temp wash, heated dry then high temp wash, heated dry then high temp wash 3 times within 5 sec you will see the control panel all light up then you should be good to go. The reason it has failed is it has exceeded alloted time to heat the water to temp selected . The best thing to do from now on is to run the water at sink until hot then start the dishwasher more so in winter than summer.
Fixrguy
Feb 13, 2011 | Dishwashers
My kitchen aid whisper quiet dishwasher will not start and the clean button is flashing
The flashing clean light is an indication that the water did not heat properly. Follow the link below to some instructions I put together that will show you how to reset the control so you can use the dishwasher again and what may have caused the error. Let me know if this is helpful.
Clean Light Flashing
May 22, 2010 | Dishwashers
"Normal" light flashes
You need a new control bd. #W10084141. If the diagnostic mode will not work then the board will have to be replaced.
Mar 06, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
I ran into this same problem. Cutting the power didnt reset it.
After power reset, mine had the normal led blinking. If I pressed cancel, then the cancel and china button leds would start blinking too.
I pulled out the trouble shooting guide (from behind the baseboard kick panel under the dishwasher door). It that if the dishwasher wont run and button LEDs are blinking there is a short circuit in the keypad. It gave a keypad diagnostic sequence which I followed. (disconnect keypad and try to initiate the diagnostic cycle without the keypad by disconecting the yellow leads to OWI sensor twice in less than 6 seconds.
I could hear the diagnostic cycle start, so the problem is a bad keypad. Will order a new one tomorrow and let you know if it works.
Sep 01, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchen Aid Dishwasher--model #KUDS01DJ
On mine the "normal" light was the one that was flashing; after a cycling of the breaker switch in the electrical main panel and closing the washer door, it went to a 2 minute rinse before shutdown.
May 17, 2008 | KitchenAid 24 in. KUDP01IL - Multiple...
Kitchenaid Dishwasher Control Panel lights - some don't light up
control panel light all of a sudden do not come on and my unit wont start model kud101fl
Jan 13, 2008 | KitchenAid 24 in. KUDI01FLSS Stainless...
Dishwashers Logo
128 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
