Question about New Home Sewing Machines
Stitching is loose and knoting up on the underside of the material - why?
  • New Home Master
  • 7,365 Answers
1.check to make sure it's threaded correctly, sometimes the thread come off the thread take up lever on my mechanical sewing machine.
2.check the needle to see if it's bent
3.check to see if the needle is in backward
4.check the thread tension
5.check the bobbin to see if it's warped-i've gottin ahold of several of them
Posted on Jul 29, 2010
I cannot adjust bottom tension on Pfaff creative 1.5 straight stitch
Hello Mary Jane,
Are there loops on the underside of the stitching? This means that the top tension is too loose -- increase the needle tension.
Are there loops on the topside of the stitching? This means that the top thread is too tight -- decrease the needle tension.
The user manual refers to this on pages 30 and 35. The manual is available free at
http://www.pfaff.com/SiteMedia/PFAFF/Products/Machines/creative-line/creative1_5/Manual/creative_1-5_manual_EN.pdf
Please give be a thumbs up if this is helpful, otherwise please provide more information.
Happy Stitching
Sewingirl/
Jun 04, 2018 | PfaFF Sewing Machines
My sewing machine is lemeiux 7000 . My thread is breaking and Seam from the lower side is very loose .what could be the reason
It is a tension problem, check your needle to make sure it does not have a burr this will cause thread to break.
if the stitching is loose on the underside you have to figure out if it is the top thread going to the underside and making loops of thread, your tension is too loose so tighten ever so slightly and sew a few stitches till it is even, if it is the bobbin thread that is bunching up try re threading it and make sure you are using the same thread on both bobbin and top, some will not work together. hope this helps good luck
Jun 13, 2017 | Sewing Machines
The underside of the stitching is loose how can i fix that I toyed the bobbing that did not work please help!!!!!
When the underside of the stitching is loose the problem is most likely with the top thread. Unthread the machine then rethread it making sure that the thread is securely in the tension disk and the machine is correctly threaded.
Jun 01, 2017 | Sewing Machines
The bottom stitching looks like a line and not stitches the top stitching is fine
try adjusting the top thread tension and see if that helps
also try changing the thread.
also change the needle--make sure it's the right needle for the fabric
being sewed.
Dec 13, 2012 | Juki DDL8300N Sewing Machine
Big loops at the bottom of the material
Hello smallflame,
The looping on the underside of the fabric is due to the tension on the upper threading being to low. Try setting the tension dial to a higher setting. If this does not help, make sure that you are using the correct needle for the fabric you are stitching on. If the problem persists you should try rethreading the upper fabric.
Thanks,
Pat
Nov 07, 2010 | Brother LS-1217 Mechanical Sewing Machine
My machine is stitching, it just keeps bunching on the underside of my material and I end up with this wad of thread. Why is it doing this?
check to see if the needle is damaged
some sewing machines bunch up on the underside when the thread come off the thread take up lever
Sep 27, 2010 | Singer 3116 Simple
When sewing elastic type material it keeps knoting
you may need to use a certain type of thread for jersey knits and stretch fabrics also your machine should have a setting for stretch stitches to allow for smoother sewing
Dec 11, 2009 | Janome Memory Craft 5700
Stitching too tight on top
I found a screw on the bobbin case (where you put the cotton for the underside stitching) which was very loose. I tightened it and that created more tension for the bottom thread which solved the problem.
Jan 02, 2009 | Bernina Activa 130
Sewing Machines Logo
59 people viewed this question
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
Nava Hirshenson
Nava Hirshenson
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
