Question about HP Compaq Presario CQ70-120US Laptop
I have a compaq presario cq70 and the screw holders on the hinges have broken also have the hinges have brokenn have you got any suggestions on what i can do
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 103 Answers
With the hinges having been broken you will need to contact a repair center to have this fixed.
Posted on Jul 30, 2010
Does my compaq presario CQ70 notebook pc have a DVD burner
Yes you should be able to "burn" DVDs with the drive that came with your laptop. Look for the Windows DVD software to create DVDs.
htScribe Super Multi 8X DVD±R/RW with Double Layer Support
Jul 23, 2011 | HP Compaq Presario CQ70-120US Laptop
The screen is floppy on my Compaq Presario CQ70 and needs tightening can you inform me on how I can resolve this please ?
Check the screen mounting screws on the back of the laptop near the hinges, make sure they are tight.
If these screws ar tight and the screen is loose then the hinges need to be replaces because there are no adjustments available to tighten them.
Replacement hinges may be available from one of these WEB sites.
LAPTOP PARTS
http://www.nylaptopparts.com/
www.laptoprepairco.com/
www.laptopparts.com.au/
www.laptopking.com/
www.lappy.com.au/
www.excelcomputerinc.com/
www.laptoprepairparts.com/
www.lapzone.com/servlet/StoreFront
www.laptoppartsexpert.com/
www.sparepartswarehouse.com/
http://www.sparepartswarehouse.com/
Jul 14, 2011 | HP Compaq Presario CQ70-120US Laptop
My Compaq Presario CQ70-120us laptop needs parts
The authorized Compaq dealer can help you ordering the product. Probably you might have to wait for a week if it is not available in your area
Mar 12, 2010 | HP Compaq Presario CQ70-120US Laptop
most likely one of your hinges have broke. remove the bezel you might just need to tighten the screws that hold the brackets to the hinges. you can order all the parts and easy fix
Jan 22, 2010 | HP Compaq Presario CQ70-120US Laptop
The frame around my laptop is comming off !
pull the bezel off see iff you can tighten the hinges down some times the screws come loose.if you have to replace hinges it is a easy fix just have to remove a couple screws.
Jan 08, 2010 | HP Compaq Presario CQ70-120US Laptop
My Presario 300 has two broken hinges
Yes they can. You can buy new, or look on Ebay to see if any are available.
You have to remove the LCD Screen Bezel, LED Cover, (Switch Cover), and the Keyboard to access both hinges.
Sound like I'm typing a foreign language? Let me show you a guide to replacing those hinges, complete with photos, so that you may better understand,
This is a PDF file download for a Compaq Presario 305. After you click on the link, give it time to fully download before looking through it.
Here is the direct link,
http://www.elhvb.com/mobokive/edwin/laptops/Compaq/Compaq%20Presario/Presario%20305.pdf
If that doesn't work for you, here is the page it came from,
http://www.elhvb.com/mobokive/edwin/laptops/Compaq/Compaq%20Presario/index.html
It's in the right column. -> Presario 305.pdf
Start with Page 18, Preparing For Disassembly
Read and view Pages 24, 25, and 26. These pages show you the three connectors that must be disconnected, Display Panel cable, Inverter cable, and Audio cable.
(Pay special attention to how a ZIF connector comes apart. It's real easy to do, believe me. Page 23 shows you. You'll see that the ZIF connector is made up of two parts. The main connector body, and cable guide. The guide is shown in an up position in the illustration. It is down next to the main body of the connector, when you start. The guide does not come out all the way. You merely lift it up with your fingernails to the position shown, and the cable slides out. To replace, insert the cable in the correct orientation, then push the guide down against the main body)
Removing the keyboard is on Page 37. Removing the Switch Cover is on Page 40.
Removing the Display Panel is on Page 42.
Don't let this task seem that daunting. You CAN do it! I advise using a clean egg carton for the various screws. Label each egg holder for where the various screws come from. (Sounds pretty techy, huh? lol! That's what I use!)
Jul 02, 2009 | Compaq Presario M2000 Notebook
Compaq Presario V4000 (v4118AP) right hinge broken
I had the same problem, they are very easy to fix, I did a search earliar and found some on the link below.
http://www.pchub.com/uph/laptop/291-29919-6327/Compaq-Presario-V4000-Series-Hinge.html
You do not need to dismantle to base, you have some star screws under the battary and one either side that loosens the small panel near the screen (where the power button is). The screen cover has screws under the plastic covers then just unclips, be gentle. after that it is self evident
Aug 06, 2008 | Compaq Presario V4000 Notebook
Compaq presario 1200
there are plastic covers over the hinges, which may be part of the faceplate. being a compaq the hinge screws are most likely torx head screws. compaq used to make a special tool for removing the plastic covers on their laptops. the tool was a bar with a piece of fiberglas circuit board embedded in it. you insert the circuit board into the groove between the top and bottom covers and twist. this is, of course after removing all of the cover screws. some of the cover screws on the display may be hidden under rubber bumpers.
Jun 28, 2006 | Compaq Presario 1200XL104 Notebook
HP Compaq Presario CQ70-120US Laptop Logo
257 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
