Question about GE JKP15 Electric Single Oven
The self-cleaning oven latch is stuck and won't open. How do I resolve this problem?
SOURCE: Door won't open
Try holding the Off/Cancel button.
Posted on Apr 14, 2007
vest6
  • 196 Answers
SOURCE: "Door Locked" flashing on GE Oven JTP15 - can't unlock
The problem may very well be in one of the micro switches on the self cleaning motor bracket. These switches control the electrical flow to the heating elements. In the owners manual there is/should be a chart that lists the unlock and safety combinations. This would be your best source of information.
Posted on Jan 26, 2008
  • 905 Answers
SOURCE: Locked latch on the self cleaning oven
try wiggling the door latch to get it open if not try the cleaning process, if that works, and see if the door comes unlatched and the light goes off. if not the lock light switch is stuck and it will need to be taken apart and cleaned
Posted on Oct 13, 2008
ginko
  • 19396 Answers
SOURCE: GE Elec oven JT952-30" blinks the "lock" after self-clean
Try unplugging power cord or trip circuit breaker, to cut the power to the appliance, then wait one or towo hours for the oven to cool down completely.
If the door stays locked, then there is a fault, probably a faulty temp probe that had blown because of high temperatures generated on self cleaning, or a defective control assembly. In that case you will need to call a technician to take apart the oven and fix the fault.
Enter model number here to find assembly diagrams and parts.
Posted on Jan 02, 2009
MY REPAIRMAN
  • 61 Answers
SOURCE: F2 displayed when using self cleaning
REPLACE THE OVEN TERMISTER PROB IT WILL FIX YOUR PROBLEM. CALL 800-614-2700 TO GET PRICE ON IT AND HAVE MODLE # REDAY
Posted on Jan 25, 2009
Oven locked E1 F5 oven locked, how to unlock whirpool oven
try unplugging it and when you plug it back in hopefully it will open.the latch assy. is stuck,i don't know what model you have,if you look above the door through the grill slots can you see the latch assy. if so unplug the stove or flip the breaker with a screw driver see if you can move the latch or if you have a long skinny screw driver or anything that you can push on the latch with see if you can lift up on the latch to see if it will free up and when you plug it back in it will unlock,if you try to free the latch in the door and are not sticking anything through the slots you can leave the power on,you can try lifting up on the door or wiggle the door,all you're trying to do is get that latch to free up so it will move and don't self clean it again if you get it open,self cleaning can cause damage to the electronics on an oven and i would never use it.good luck
Nov 08, 2017 | Ovens
Kenmore self cleaning oven 362.75471691
see to it the there was no stuck object or parts on the door parts...
Sep 30, 2008 | Ovens
My whirlpool oven model RBD245 is locked after the self cleaning cycle, it does not heat up even if i open the latch with a tool?
Whirlpool have the self clean latch assembly solenoid go bad and wont return back to unlock the switch to tell the control is is no longer in self clean. Replace the self clean latch assembly or make sure the switch on the assembly is in the non self clean mode, If the oven starts working then you know the problem if it still doesn't work then there may be other issues.
Feb 13, 2014 | Whirlpool RBS245PDS Electric Single Oven
Door stuck after cleaning cycle? Can hear latch release but door will not open. Power still good. Oven still works, just can't open door,
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Sep 16, 2010 | Whirlpool GMC275PD Electric Double Oven
Opened oven door seconds after pushing clean. Lock stayed out but by pushing clear and door switch, unlocked but oven will not work, says it is "off" Have turned off power for 5 mins but didn't solve...
the door latch may have over run its normal reach causing it to stick . ck the lever / also try putting it into a clean cycle while holding the latch in the closed position ... i thnk the latch is stuck . you may have to remove it and reinstall . to correct .. power off should have corrected it . so it may be stuck .. mm
Jul 15, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Hot point oven 20 years old cleaned oven now door
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Jun 15, 2009 | Hotpoint DY46 Style Line Stainless Steel...
Oven door will not open
If you have just finished using the self clean part, the latch may be stuck. Push the door closed and hold it and then tap moderately on the door where the latch is and it may release. Unplug the oven and then then replug after 10-15 seconds.
Jan 28, 2009 | Frigidaire Ovens
Oct 13, 2008 | GE JKP15 Electric Single Oven
OVEN NOT WORKING
You have probably damaged the latch and other sensors around the door. Make sure that the is not bent or out of alignment.
more asst.
eboukater@gmail.com
Jul 01, 2008 | Jenn-Air JJW8530C Expressions Collection...
GE JKP15 Electric Single Oven Logo
269 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
