Question about Ovens
I was cleaning my kitchenaid gas range using the self-cleaning feature. Near the end of the cleaning cycle, the display on the control panel went out and the cycle shut down. The panel has not come back on, the door is still locked and we cannot run any of the oven controls. The stove top works fine. We have checked the breaker - it is fine. We have unplugged - left it unplugged, then plugged back in - still nothing.
  • the_lickmans Jul 29, 2010
    Thanks for confirming our original thoughts regarding the problem.
  • Ovens Master
  • 11,800 Answers
The electrical controls for the oven have failed and must be replaced. The unit must be dismantled and the correct parts ordered and fitted.
If you haven't done that before it's better to leave it to a pro. Call an authorised repairman, gas isn't something to mess with. Select from one of this official list
http://bit.ly/9aUnh2
Posted on Jul 29, 2010
Unlock oven door on model #FGGS3065PF
If the oven display is showing LOC, then the lockout feature was enabled. Press and hold the key pad with the padlock symbol for 3+ seconds. This is just below the Timer On/Off key pad and to the right of the Light key pad. You should see the word DOOR and the padlock icon flash until the door is unlocked and the control panel is released.
If the word DOOR and the padlock icon are lit, then the oven is in the self-clean mode. The lock should release after you cancel the self-cleaning cycle by pressing off and the oven cools down (at least one hour). Unfortunately, sometimes the heat of the self-clean cycle will damage the oven. Either the oven temperature sensor will not give the release signal or the door lock will not disengage. In that case, the oven needs to have the correct part serviced.
The documentation for the Frigidaire FGGS3065PF is available on the product page at Home Depot: https://www.homedepot.com/p/Frigidaire-Gallery-30-in-4-5-cu-ft-Slide-In-Gas-Range-with-Self-Cleaning-Convection-Oven-in-Stainless-FGGS3065PF/204759413 . See page 15 for the Oven Lockout feature. See page 28 for the self-cleaning information.
I hope this helps.
Feb 13, 2018 | Ovens
How does the self-clean feature work on a Frigidaire CFEF366EMB model?
Hi Beverly,
I understand that you are looking to run your self-clean feature on your Frigidaire range, model# CFEF366EMB.
-To start this you will remove all racks and make sure that any excessive spillovers are cleaned up as best as you can.
-Next you will press the "Clean" button, and the display will show "---".
-Press the up or down arrows to select the length of time you want the oven to clean. Usually 2 or 3 hours.
-The door will automatically lock once your time has been chosen and the "LOCK" indicator light will flash. DO NOT open the door while the light is flashing. (it takes about 15 seconds for the oven door to lock).
-"Cln" will appear in the display during the self-clean cycle and the "LOCK" light will continue to glow until the self-cleaning cycle is complete or cancelled and the oven has cooled.
When the self-clean cycle has completed:
-The time of day or "END" will appear in the display window and the "Clean" and "LOCK" light will continue to glow.
-Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened.
-If "END" is in the display and the Clean indicator light remains ON, press the "CLEAR/OFF" button and the time of day will appear on the display.
-When the oven is cool, wipe away any residue or powdered ash with a damp cloth or paper towel.
-Best Regards-
Jan 23, 2014 | Frigidaire Ovens
It is a free standing kitchen aid oven. I put it on quick self clean and it said it would end at 2:00. The panel went blank at 1:20 and it is past 2:00 and it is still locked. I checked the circuit br
Unfortunately KitchenAid ovens notoriously blow a thermal fuse when you use the self cleaning cycle, and if you're lucky that's all that happened. Hopefully your oven is still under warranty. If so, call KitchenAid customer service and they will repair it for free.
If you're handy you can check/replace the thermal fuse yourself (requires pulling out the oven and taking off the back panel, finding and replacing the fuse- be sure to turn off power and gas first).
Nov 13, 2012 | Ovens
Dacor Preference RSD30 Gas Range My wife put the
I don't see the make and model number of your unit. I only see part of your post. Please post the make and model number. It should be a simple fix. From what I do see in your post, it sounds like the control board will need to be replaced.
Regards,Richard
Oct 17, 2011 | Dacor Ovens
I used the self cleaning, quick cycle. When cleaning completed the display panel light went off and the door is still locked. Cooking part of the gas stove still works. Could you help us...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Jan 05, 2011 | Ovens
Error F5E1 after self cleaning
Hi There
I have read the codes you are looking for,so I'm sending them to you and i hope this will help.
F5 E1 16 Door latch not operating Check that door switch is completely closed. Check latch, solenoid, and actuation switch for electrical or mechanical malfunction.Thank you for writing to fix ya.
Best regards Richard
Dec 11, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
I used the cleaning feature on my kitchen aid architect series oven KEBK101 - now when you turn the oven on it does not heat up - what part do I need to replace - Kitchenaid will not address
Yup Thermofuse stops the elements from heating after the self-cleaning cycle. You have to take out the oven, TURN OFF THE POWER at your circuit breaker, remove all the screws on the oven back panel, you'll see the thermofuse near the center (there are two 1/4" spade connectors (one leads from one leg of the power junction box). Two screws to remove it.
Oct 27, 2009 | KitchenAid KEBC107 Electric Single Oven
Self Clean cycle on Hotpoint Gas range doesn't work
We see a symptom like this due to a failure in the control board. Although it usually also affects bake mode. Another cause could be a problem with the door lock as it must be engaged (by the controller) to initiate self-clean.
If this doesn't help, you can either post the full model number or email me at bruce@fixyourboard.com and we can dig deeper.
Oct 09, 2009 | Ovens
Kitchenaid double digital convection conversion oven keypad went out. Any ideas on the problem. Electric panel circuit breakers are okay. Sharon C.
I think these use the same controller board as the Jenn-air units, they have a weak capacitor (C3) on the control board (Timer/control Display). Remove the top panel and look for a discolored or leaking capacitor (usually black about 1/2" high 3/8" in accross). Replace the capacitor and the problem goes away, until next time you use the self clean cycle which seems to overheat the control board and ruin the capacitor.
Sep 23, 2009 | Electrolux 30" Built-In Double Electric...
No power on control panel
No reset for the control panel... you can try a hard reset ( remove power by triping the breaker for 1 min ) most like you have a safety thermo thats blown or a bad control... I can help you find them if you want to take it apart
Dec 15, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Ovens Logo
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
