Daewoo CT6720-C25 Computer continually freezing
I just bought a Daewoo CT6720-C25 to replace another old desktop I had from a local computer repair service. I have had them look at it twice, but they have only been able to create the problem I am having once...but not sure what is wrong. It continually freezes, most of the time when I am on the internet or in my emails. The fan or something starts running and that is as far as I can go. If I try to shut down, it says saving files...but never shuts down. It just keeps running. I have to unplug the tower an leave it for at least an hour before I can plug it in and start over. I have Windows xp. I hope you can help. Thanks
  • 4,281 Answers
Remove temp files from computer. Press windows key + R then you can see type in run "%tmp%" without "" then press enter then remove all temp files.Type in run "prefetch" without "' then press enter remove all prefetch files. Type in run "chkdsk /r" then press enter then press "y" then restart computer then it fix errors on harddrive. Scan computer updated antivirus it is best antivirus. Download it's free version from below link. Click here Download and install then update it from internet. Then scan computer in boot time avast scanner. Then check. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Jul 29, 2010
Computer beeps 5 times and repeats the same 5 beeps continueously
5 beeps notes a memory error. Here are the possible solutions:
1.) Take the computer to a local repair shop and have the test/replace/reinstall the memory
2.) You can open the case and reseat the memory. You would want to follow proper procedures including unplugging the computer and following anti-static procedures by grounding yourself against the metal case.
3.) Reseating the memory means popping the latches loose and reconnecting (reseating) the RAM. This link has more details on the procedure.
4.) If reseating the memory does not fix the issue, you will want to replace the RAM.
Jan 11, 2011 | HP Compaq dc5100 PC Desktop
Computer freezes and gives continuous beep.has to be turned off at wall. Also freezes in safe mode
Hello
The beepcode you are getting sound to me like an overheating problem or a ram error.
Have you had a look inside the computer and see if you can see any dust particles on the fans inside the computer.
If you can see a build up, it is most likely an overheating problem. Also, the thermal paste on the cpu can be done, so you might even have to replace the paste as well.
If you do not feel comfortable doing this yourself, you need to take it in to a repair shop.
I hope this can steer you in the right direction.
Kind regards
Andrea
Jun 21, 2010 | Acer Aspire M3641 Dual Core E2200 PC...
Cd rom not working and computer keep on freezing
try with other disk if all disk getting same issue then you have to first clean your cdrom or dvdrom lense.
For that you need disk cleaner disk pur chase it and put in rom then play it.
then it clean lense.then check.
if still face problem then you need to repair or replaced lense if it in warrenty replace it.
Jul 29, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
My computer freez and go blank after formatting the computer
Greetings,
There is no problem with your computer as a whole it is your hardisk that has a problem, It cannot continue installing the system files because an error occur in your hardisk. Format your hardisk with other computer.
If you have an extra hardisk much better.
Thanks
Nov 12, 2008 | IBM NetVista PC Desktop
My computer keeps freezing when i turn it on
reboot the machine. tap the f8 key and select safe mode. boot into safe mode and see if the computer freezes up again.
in the event it doesnt, you have a bad driver or new software on the drive. to correct this go to gateway.com select your model and download any recent updates including the bios. also uninstall any new service packs or software you had loaded recently.
reboot machine and see if you have the same error.
if this continues or it froze in safemode you could have two problems,
1. Corrupt OS files, the fix: Restore Machine after backing up data.
2. GPU having issues and heating up to the point it turns off, the fix: Local repair shop or Gateway replace mobo or local repair shop reflow board.
Let me know what you try and what works! Good Luck!
Ruben
Nov 08, 2008 | Gateway MX8711 Notebook
Hello, the problem is with an acer aspire l100 desktop computer. When it starts up it freezes continuously and won't shut down. How do I solve this problem?
dear,
what are the starting and freezing conditions. i mean it freeze at what end. in the start, when windows starts, or on the other stage.
if ur computer freezes at very start, where the ram, hdd show. then its some hardware fault. it can be b'coz of ram. so check ur ram or rams.
if ur computer freezes at the starting of widows then it can be hardware but mostly software/ windows problem. so repair ur windows or try to run it on safe mod. b'coz if it run on safe mode then it dead sure that ur windows files have been corrupted or missing.
regards,
salman
Jul 21, 2008 | Computers & Internet
Computer freezing- blank white screen
Check your connecting cables to the monitor. They can become loose or you may have a cracked cable.
Jul 13, 2008 | HP Computers & Internet
Motherboard faulty, repair, scrap machine, or replace motherboard ? What is the cost and complexity to have fitted a new motherboard fitted to a acer as 5101wlm computer?.is ths repair durable and...
Firstly, check to see if your manufacturer's warranty is still active. As long as it is not a custom-made machine, you should still have warranty repair service if you bought a service contract. Most of the time, a service contract comes with the purchase. at 18 months, most contracts will still ship you replacement parts but you will have to put it together.
If the retailer sold you their own custom made computer, then you have very little choice. The repair costs are going to vary according to where you live, but here's a general rule of thumb to go by: If the repairs cost more than 3/4 of that what a comparable replacement PC would cost, then go get a new one. Some stores will give you credit for exchanging old PC's. look around for stores doing that, as this will be the only way to recoup some of your costs.
Altrnatively, you can donate the computer as scrap to local charity who will take it apart and sell the parts. you will get full retail value as a write-of on your tax returns at the end of the year. Of course, this is only helpful if you file itemized deductions.
Jul 09, 2008 | Acer Computers & Internet
Computers & Internet Logo
98 people viewed this question
Alun Cox
David Payne
David Payne
