Question about Canon PowerShot S2 IS Digital Camera
Canon PowerShot S2 IS Error Code E18
Error Code E 18
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Dec 20, 2010
5 Suggested Answers
t00nz
  • 4738 Answers
SOURCE: Canon Powershot S2 IS Disassemly guide?
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it without disassembly. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 22, 2009
  • 164 Answers
Just Google in internet "Canon S2 CCD repair" and you will find several places where to donwlod a disassembly guide.
Regards
Posted on Jul 22, 2009
  • 1566 Answers
SOURCE: Canon PowerShot S2 IS camera showing code E18
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Posted on Apr 06, 2010
lock123
  • 6831 Answers
SOURCE: Error E18 . What does this mean. Canon camera
Hello
Regards
Andrea
Posted on Dec 19, 2010
Can I use a 4gb sd hc memory card in a canon powershot s2 1s? the screen says there's a memory card error
The Max. Memory Size of ur camera is : 2048Mb/2GB.........That is reason for which it says that there is a memory card error.
Feb 17, 2011 | Canon PowerShot S2 IS Digital Camera
I have a 4GB SD HC card that works well in my Powerhot SD750 but gives an error code "Memory Card Error" and "Card Locked!" on my PowerShot S2 IS. Is there a fix for this? Peter
The S2 IS uses SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. While you can use SDHC cards with the SD750, you will have to use SD cards, 2GB and smaller, with the S2 IS.
Oct 21, 2010 | Canon PowerShot S2 IS Digital Camera
Won't shut off or take pics. code E18 comes on
Try removing the batteries and cleaning the contacts inside the battery compartment with a cotton swab "dampened" with rubbing alcohol. Also you'll want to clean the battery and charger the same way. Thank you, Dana
Feb 02, 2010 | Canon PowerShot S2 IS Digital Camera
Hello there,
Jan 20, 2010 | Canon PowerShot S2 IS Digital Camera
Error code E18
Believe it or not, there is a website that is dedicated to the error code e18 lens problem. Here they discuss the error code and solutions.
PLEASE CLICK HERE FOR THE SITE
Good Luck with that!
Nov 16, 2009 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot S2 IS 5.0 Megapixel manual
Click Canon Support to download user manual of S2 IS camera.
Thanks.
Sep 02, 2009 | Canon PowerShot S2 IS Digital Camera
Canon powershot s2 is lens won't retract error e18
Try tapping not so gently. other than that it will most likely need to be taken apart and put back together the right way. And any broken parts replaced.
Mar 17, 2009 | Canon PowerShot S2 IS Digital Camera
Feb 22, 2009 | Canon PowerShot S2 IS Digital Camera
Regards
Feb 22, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Canon PowerShot S2 IS Digital... E18 Problem
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
May 17, 2008 | Canon PowerShot S2 IS Digital Camera
Canon PowerShot S2 IS Digital Camera Logo
265 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
