Question about Acer Aspire m5640 PC Desktop
Aspire m5640 pc desktop 3rd master disk error. it wont load up windows vista, hoow do i fix it
    Problem Solver:
  • 17 Answers
Try remove your harddisk cable (sata or ide cable) and insert to another port of your motherboard :)
Posted on Jul 31, 2010
I NEED A ACER ASPIRE RECOVERY DISK MODEL 5640..DISK THAT WILL BRING THE COMPUTER TO FACTORY SETTINGS
try hitting alt-F10 at startup... should access the recovery partition and then just follow the prompts. hope that helps!
Sep 15, 2011 | Acer Aspire m5640 PC Desktop
Sir if i load xp in in my pc(acer m5640) it shows blue screen when checking or loading setup. so plz give me solution now
That is because it is designed to run on Vista and XP is not supported with drivers etc.
The motherboard will not run because XP has no drivers for it. XP is too old!
Jan 07, 2011 | Acer Aspire m5640 PC Desktop
Dear sir i have acer aspire m5640 desktop pc i want to load windows xp on it but its showing blue screen i from sata driver allso from floppy drive but it shows txtsetup file missing please give me the...
if u dont have orignal opreating systeam on u r pc then u can install xp u said u have sata hdd
1) check u r orignal set up is working properly for harddisk working . if it's not working check it by Herenboot it's third party sofware which boost up u r systeam for checking .
2)some time blue screen errors comes cuse CD is not good which u r using or , harddisk having bad sector or RAM problem while installing xp
3) try on of this option
Dec 05, 2010 | Acer Aspire m5640 PC Desktop
My acer m5640 with vista all the sudden crashed got the blue sceen so i renistalled windows when i did in the proccess it shut off then when i went to restart it the screen was blank it came up no signal...
Remove the CMOS battery and remove hard disk connection from the motherboard. Then restart ur system. It will give u the msg no boot device found. Now reinsert the CMOS and hard disk connection.
Apr 27, 2010 | Acer Aspire m5640 PC Desktop
Windows xp instalation stpos givibg a blue screen in aspire m5640 desktop
Windows Xp installtion give Blue Screen of Death when XP tries to installed devices driver during installation or when the cd is corruptted and cannot be read in graphical mode installation or when the hard drive is corrupted with Bad sector.
Get a new windows XP CD and configure your system BIOS to default setting ( load optimal settings) and configured for IDE drive configuration to compatible mode or disable mode if you are using SATA hard drive.
If problem still occured, get "Bad sector recovery pro" and try to repair the hard disk.If the bad sector are unrecoverable then change the hard drive.
Sometimes, faulty RAM also give blue screen too. Check your RAM too.
Dec 19, 2009 | Acer Aspire m5640 PC Desktop
How to performed system recovery on Acer desktop with Vista OS?
that shouldnt be much of an issue just use first disk and follow instructions you cant mess up
Jun 26, 2009 | Acer Aspire m5640 PC Desktop
Cd/dvd drivers missing on vista 32 install
The best way to find out if you need SATA or IDE is to open the case and look. If you have gray cables about one-inch wide with a red line on one side then that is IDE. They are parallel cables. If you have anything else then it is SATA which is a serial cable. I have never been to the Acer Website but I know on Dell, HP, etc. they have a place under support and drivers that you can go. Type in your model number and download the drivers. I don't know if you have another computer to do it, but unfortunately if your restore disk do not work then that is where you will have to go...also see if you can contact someone at Acer and find out why your restore disk do not work. I have wiped my hard drive clean and I was still able to re-install the revovery disk.....Hope this helps.
Don't forget to rate this solution before you log out.
Jan 27, 2009 | Acer Aspire T690 (AST690UP820A) PC...
Acer Aspire m5640  PC Desktop Logo
139 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
