Question about Panasonic Televison & Video
Panasonic Triple Play PV-DF2003 TV will not power up and lights are flashing on the front of the tv
  • Panasonic Master
  • 11,800 Answers
The lights are there to inform you on the status of the power source. They are flashing because the power source is in protected mode - a part inside the tv has failed and the power source has shut itself down to protect itself and the rest of the tv. To find which part you must open it and test the components. The most likely part on a tv of this age are the electrolytic capacitors - look for bulging or leaking ones.
If you haven't done that before then it's better to call a repairman, if you mess with it the damage could get even bigger and more expensive.
Posted on Jul 29, 2010
  • davidpalm861 Jul 29, 2010
    Is there a way to reset this condition. I believe it may have been a kind of glitch to the system because I missed a connector reassembling the TV
  • Azrael SRL Jul 29, 2010
    It's not a glitch - an actual part is dead. If you missed a power connector no wonder that the tv fails to work - the part that was supposed to be powered by that connection got fried by the signals that were sent to it by the other components.
    The problem you have isn't something you can reset, it's not a setting, an actual part has been fired, creating a short and the power source is designed that way as to shut down if a short happens on one of its power lines. You can disable that protection by soldering a connection on the board but this is a sure way of completely destroying it if you don't take other measures of protection.
     The tv must be tested, the fried part identified and replaced, and only then your tv will start.
How do I access the main menu on a panasonic triple play TV without the remote
asking the same question, and before anyone answers, there is no action button on the tv
Oct 26, 2012 | Panasonic PV-DM2792 Triple Play 27 in....
Remote codes for Panasonic MODEL# PV-DF2704
5 digit code for the comcast red button silver remote is 21462 this pertains to Panasonic MODEL# PV-DF2704
Nov 20, 2011 | Panasonic PV-DF2703 Triple Play 27 in....
DVD PLAYER Locker
press the stop key on the television and the on/off button on the remote at the same time.
Dec 26, 2008 | Panasonic PV-DM2792 Triple Play 27 in....
Need remote control code for Panasonic PV-DF2703
I found a newer Comcast PDF file that shows a 5 digit number for tv with vcr ( no mention of DVD) but the code worked to turn on the tv and cable box together. My problem is it won't work the volume, yet
https://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/Remote_M1067BX3.pdf
Dec 24, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
Panasonic triple play tv
press tv/vcr first on the remote then use the chanel up or down to select the next input.
Feb 08, 2008 | Panasonic PV-DM2792 Triple Play 27 in....
Dvd not ejecting
I just found my solution. I pressed the power button on the remote and the stop button on the tv at the same time, and it unlocked the dvd eject.
Sep 14, 2007 | Panasonic PV-DM2792 Triple Play 27 in....
Wont turn on
Hi Bismi, my PV-DM2792 behaves for last four days in the same way - double clicks when power button is depressed and the light PROG is flashing every second continously. I have called to the Panasonic customer service and they could not propose a solution to this problem other than contact an authorized dealer in my area. SirJ
Jul 12, 2007 | Panasonic PV-DM2792 Triple Play 27 in....
TV and remote
Some suggestions: 1. Try fresh batteries in the remote. Weak batteries make it hard for the TV to see the signal from the remote. 2. Is there sunlight or ambient light hitting the TV on the infrared receiver (the part which sees the remote)? If so, it could be "blinding" the TV. 3. DO you have a ceiling fan which is casting a "flashing shadow" onto the TV? This can interfere with its ability to see the remote.
Mar 09, 2007 | Panasonic PV-DF2003 Triple Play 20 in....
Open Questions:
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
