After i use partitionmagic to merge drive (D & E ) and rename to D the Drive D disappear and wheni check error it shown Error #1520 Externak attribute header mismatch How to solve this problem
  • 496 Answers
This error occurs when the PC hard disk has error(s) and your using particular software as you have mentioned like partition magic. To solve this problem shut down all your applications and running software.
If you are using Windows XP
Go to Start>Run>In the run box type cmd
A black Window will open its called CLI or Command line interface. In this Window run the following command on the C partition CHKDSK /F if the message appears"Check the system next time the system restarts (Y/N) type "y". then type "d:"to enter D partition. When the D prompt (D:) appears type the same check disk /Fix command which is "CHKDSK /F" and hit enter.
Similarly repeat this command for all the partitions.
If the this option statement appears "would you like to force dismount on this volume? (Y/N). Select "Y".
If you are using Windows Vista or Windows 7 then when you perform the first step which is Start>Run>In the run box type cmd before hitting enter in the start menu look for a small black icon named cmd on the top of the start menu. Right click it and select "Run as Administrator" When the black cmd window opens all the steps after that are the same as described above.
Good Luck!
Posted on Jul 29, 2010
My tredstor external hard drive dsmmu-p-in-a all of a sudden asks if I wants to merge the files (on my computer hard drive) with the previously saved files on my trekstor (of the same name). It hasn't...
OK hello I'm new to the tech support any way how much memory on the Hard drive and much is left on the external drive it may ask you to merge to tell you you need room for all files and that you may have almost reached the compasity on the drive
Mar 12, 2017 | Trekstor Computers & Internet
Create partitions in BIOS on a D3315 E-machine
rather than creating pertitions using bios use partition magic
http://www.filehoo.com/download/Partition-Magic-8,0.aspx when you download partition magic you will have the option to make rescue to disks to boot from make these disks then change your first boot device your to floppy drive this will give you options to partition then partition only the good sectors of your hard drive and install an operating system to the good partition
Partition Magic 8.0 description
Partitioning your hard drive plays an essential role in maintaining your computer-preventing conflicts, protecting data, improving efficiency, and increasing performance.
PartitionMagic allows you to create, resize, merge and convert partitions without destroying data. Award-winning
PartitionMagic Pro from Symantec is a leader in hard-drive partitioning software. PartitionMagic Pro allows you to create, resize, move, and convert partitions without destroying your data. You can quickly and easily create partitions, which can act as file drawers on your hard disks for storing valuable information such as data files, applications, and operating systems.
Storing information in separate partitions helps you organize and protect your data, safely run multiple operating systems, and reclaim wasted disk space.
hope this helps
Jun 20, 2012 | Computers & Internet
How to create c drive in pc?
hope this helps
Jun 18, 2012 | Intel Computers & Internet
I have 1 gb thumbdrive and i want to make a small partition about 2mb in my thumbdrive for my machine...this machine can read 3 binary numbe only.........................
PartitionMagic allows you to create, resize, merge and convert partitions without destroying data. Award-winning PartitionMagic Pro from Symantec is a leader in hard-drive partitioning software. PartitionMagic Pro allows you to create, resize, move, and convert partitions without destroying your data. You can quickly and easily create partitions, which can act as file drawers on your hard disks for storing valuable information such as data files, applications, and operating systems. Storing information in separate partitions helps you organize and protect your data, safely run multiple operating systems, and reclaim wasted disk space.
hope this helps
Apr 28, 2011 | Computers & Internet
How do i use my second partition of my hard drive? my laptop is a dell vostro 1088. It seems that my OS (C:) is full but i see that i have a new volume(F:) so how do i use that? Originally, my laptop...
http://www.filehoo.com/download/Partition-Magic-8,0.aspx when you download partition magic you will have the option to make rescue to disks to boot from make these disks then change your first boot device your to floppy drive this will give you options to partition then partition only the good sectors of your hard drive and install an operating system to the good partition Partition Magic 8.0 description
hope this helps
Apr 23, 2011 | SIB 320GB 5400RPM 8MB Cache SATA Hard Disk...
Partitionmagic is coming up with error 27 ''cannotlock drive'' when tried to enlarge a partition.
The file system utility requires exclusive use of a volume (for example, to format it). However, the utility cannot lock the volume for your exclusive use right now. Somebody else may be using it.Shut down other applications and console windows that are using the drive, and try again.
Dec 28, 2009 | Symantec Norton PartitionMagic 8.0...
Inspiron 1520 error code 0f00:137B or dvdrw_4
this is either a faulty dvd drive error message, or you have missing system files on the hard-drive.
The computer is asking you for the ( Media-Software Disk ) that is missing, and is required to start the computer.
Try putting your restore cd, or operating system in the dvd drive when booting the computer.
Mike @ Compurepair.
Jun 15, 2009 | Dell Inspiron 1150 Notebook
Raw file system
To fix the problem
Disable the S.M.A.R.T error detection feature in the CPUCool program or similar utility.
Boot to the Windows 2000 or XP installation CD, and at the Startup menu, press R for repair.
In the Recovery Console, type the following:
chkdsk /p
When the CHKDSK process has finished, reboot the computer.
Run the program again.
The error should no longer be reported unless you start using the S.M.A.R.T error detection feature again.
Error occurs with PartitionMagic 8.0
If you encounter Error 1516 with PartitionMagic 8, first run CHKDSK /F on the affected partition. For instructions on how to run CHKDSK, read How to Run Microsoft's CHKDSK from the Command Line. If this does not fix the error, try running PartitionMagic with the /IFC switch, which causes file system errors to be ignored.
To run PartitionMagic with the /IFC switch
Boot from the first PartitionMagic rescue disk.
When you are prompted to insert the second rescue disk, press Ctrl+C to drop to the command (A:>) prompt.
Insert the second PartitionMagic rescue disk and type the following:
pqmagic /ifc
Press Enter.
please go ahead and try the above steps may be it will fix it
Feb 26, 2009 | Symantec Norton Partition Magic-8.0...
Hard Disk Partition
you have make Bookable floppy to boot & restart when it show 3 types you can choose without cd rom sopport and type fdisk then u can edit from there.
Sep 21, 2008 | Maxtor Hard Drive
Computers & Internet Logo
54 people viewed this question
Alun Cox
David Payne
David Payne
