Question about Garden
I have a 3x21 inch craftsman belt sander. It's about 12 years old. With the sand paper belt is mounted and tightened and I start to sand something the belt will slip and not sand. I checked the tightening latch and it seems OK. Also the rubber drive roller is loose and comes off easily, Should this roller do this? I can't get anything done in this condition.
    Guru:
  • 1,051 Answers
The drive and guide rollers are probably drying out and won't grab the paper. Take the drive roller of and treat it with a rubber restoring compund. The roller should not come off easily.
Posted on Jul 29, 2010
  • schuyking Oct 31, 2010
    My drive roller comes right off the metal shaft of my Craftsman 315.117130 sander. Any fix for that?
I am looking for a drive belt for a mastercraft 3x21 beltsander. the belt says 120xL031. cant seem to find one anywhere.
The belt you can replace with a is simply any generic 3x21 belt. You can find them at your local hardware store or order them from a website like Home Depot, etc and have them shipped to your home. Here is a link to take you to Home Depot specifically for an 80 grit, but you can look for other grits as well. 3" is your width and 21" is the diameter of the belt you need.
Gyros 3 in 21 in 80 Grit Aluminum Oxide Sanding Belt 5 Pack 12 32180 5 The...
Feb 14, 2015 | Tools & Hardware - Others
How do I get the wheels to pop back out after changing the sanding belt on my old craftsman belt sander #31511720 model?
The tracking adjuster will tilt one wheel in so's you can start putting the belt on. After it gets about halfway, you will need to adjust that the other way and just bump the switch a bit a few times as you adjust and it'll work its way back on.
Feb 03, 2015 | Craftsman 3 x 21 in. Belt Sander, 8 amp
Porter cable 352vs manual
My Porter Cable 352vs Belt Sander was clogged from sanding epoxy, wet wood, something like that. No dust collection at all.
I had to remove 4 screws on the housing, one screw under the front handle and another below the rear handle. The housing came out very easily (with a little wiggle). Pay very close attention to where the position of your plastic fan housing sits. It will only be installed in one spot.
http://www.ereplacementparts.com/images/porter_cable/352_TYPE_1.pdf
The pdf diagram was not exactly correct on the housing placement.
Once opened, The wood and epoxy were caked in everyplace. I brushed them out and replaced the screws.
Good as new.
Good luck.
Feb 24, 2012 | Tools & Hardware - Others
How do I change the sanding belt
is it a B & D 3x21 belt saNDER. iF SO, PUST THE REAR DRIVE WHEEL FORWARD UNTIL IT CATCHES, PUT THE SANDING BELT ON, THEN RELEASE THE CATCH WITH A LONG SCREWDRIVER ANDIT WILL SNAP BACK INTO PLACE. hOPE THIS HELPS
Aug 18, 2010 | Tools & Hardware - Others
After installing new belt, on Porter Belt Sander 352VS #6 the belt drifts of to one side until it comes completely off. How do I stop this?
There is a tracking adjustment knob on the side of the sander--adjust one way or the other until it tracks properly. This is something that will change by itself as the sander is being used--check periodically.
Feb 13, 2010 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
The Belt of my craftsman 3x21 sander slowly moves off track.
There is a leveling (screw/knob) on the side of the belt sander. Turn it up and the belt will drift in one direction. Turn it downward and the belt will drift in the opposite direction. play with this leveling screw/knob until you reach a good balance and the belt will stop drifting.
Dec 04, 2009 | Craftsman 3 x 21" Variable Speed Belt...
The belt slips off my Belt Sander
All sander will have two adjustments. The first is to release the sanding belt by retracting the position of one of the rollers. The second adjustment moves one of the rollers belt tension from side to side. The roller angular position is changed, sometime by a single knob or screw, and sometimes by two separate adjusting screws.
Jun 19, 2009 | Dewalt DW433KT Heavy Duty 8 Amp 3 Inch By...
Craftsman 3x21 plastic front roller needs replacing
Do you know anyone with a metal lathe or that works in a machine shop? If you do ask them if they can make the rollers for you out of metal. Or else find a machine shop and ask them to make you new rollers.
Apr 01, 2009 | Tools & Hardware - Others
Smells like wires buning
Motor may just need new brushes, Cooling vents may be clogged with dust. or bearings in the motor or front roller maybe bad. Causing excessive drag
blow it all out with compressed air or shopvac
look for external brush caps (2) oppsite from each other take them out to be sure they slide freely, sometimes one gets hug up and doesn't make good contact
Mar 12, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Porter Cable belt sander
try to rig the nozzle of a shop vac to the part where the bag would normally connect and run the sander simultaneously with vac for a few minutes and see if that helps
Jan 11, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Garden Logo
204 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
