Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Everything sounds like it's on spin cycle, but machine is not spinning
  • 171 Answers
Sounds like the brake/clutch assembly is not working. not a hard job but unless you have removed a transmission before i would not advise it.  a repair should not run over 150 to 175 or so
Posted on Jul 29, 2010
Washing machine won't spin
Sounds like corrosion in the motherboard . Get an electronics serviceman to take a look, could just need soldering point to point connection. Hope this helps.
Jan 14, 2013 | Washing Machines
Washer does not spin out during the spin cycle. Everything else is working properly.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 14, 2011 | Washing Machines
I'm getting a squealing noise on the spin cycle (sounds like a bad bearing). Everything else works fine
yes, your bearings will need replacing if it is on every spin cycle the machine completes
Apr 16, 2009 | Washing Machines
Washer won't spin
You won't be able to spin this by hand because you have a brake system above the transmission. When not in the spin cycle this brake stays engaged When it goes to the spin cycle it disengages so that the drum can spin at the end of the spin cycle if you have ever watched it the tub stops almost on a dime. Sounds like your brake is not releasing when washer goes to spin cycle. Try this site for what parts look like www.repairclinic.com The 2 of you sound as if you know what you are doing Good Luck.
Apr 02, 2009 | Washing Machines
Everything works great -until the spin cycle - loud noise
Have you checked to make sure all three shocks under the tub are ok?
Dec 18, 2008 | LG WM-2277HW Front Load Washer
Everything is working except the spin cycle
Sounds like the spin coil/brake solenoid is burnt out or broken. This is a coil situated on the motor plate under the machine with a lever attatched to it. When the machine goes into spin cycle, this solenoid pulls the brake away from the outer drum to allow the drum and agitator to spin together. The shaft that goes into this coil should move in and out freely. If tight, replace spin coil/brake solenoid.
Oct 31, 2007 | GE WSKS2060WWH Top Load Washer
Kenmore top loading washing machine
the problem sound like the timer contacts are stuck try tapping the timer while it is stopped and see if it kicks in to spin let me know if this works
Sep 12, 2007 | Washing Machines
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
220 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
