Question about Dell E156FP 15" LCD Monitor
Dell monitor E156FPb went black
I have a Dell monitor E156FPb that went totally black. Everytime I swtich on it stays on for a second (Good light) then turns black. VGA and power are well connected
  • 11,361 Answers
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/
Posted on Aug 01, 2010
Testimonial: "Thank you very much. I do not think that I am capable of changing the needed capacitor, I will just take a new LCD.Thank you very much for your advise"
HP Pavilion F1503 only displays a split second?
well, its a 2003 LDC 13 years old ,
its bad
the monitor itself of the power pack to it is bad.
you can test it on any PC< or laptop made
if its dead on all , then its dead.
what more needs saying,
older LCD monitors had old CCFL, lamps. that love to fail
newer are LED back lights that last for ever. it seems
so up grade?
seems your back light is dead
ever do the flash light trick
shine it at the dead screen see good data
yes, then the CCFL is DEAD< (or its power supply ,deep inside)
fixed may but would never do a 2003, not now.
lots of used good LED for sale,
Mar 09, 2017 | HP Pavilion F1503 15" LCD Flat Panel...
Dell monitor screen suddenly went white. Can it be fixed?
I have a strong suspicion that you have burned a capacitor or two on the monitor. You will need to bring this in to have it serviced as it will require the monitor to be opened up and new capacitors replaced/resoldered.
Mar 18, 2017 | Dell Model 2208WFP - 22 Inch Widescreen...
My HP vs19e Monitor went black, when I turn it off...
guest, If monitor vs19e acts same when connected to different "known good" pc then try this site for info: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ How old is this model? When was last time it worked correctly? 12fixlouie
May 19, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
Monitor went black and now stays black after
pdshapiro, Learn flashlight test in my fixya profile to determine current state of shutdown of units "switch-mode-power-supply"... Then do more reading and visit some of the web links mentioned in my many responses to other owners of Black or Blank n Black screen monitors. You will find out all you need to know and all options if you read my older (late 09 posts) responses to other owners of same or similar sympton ccfl back-lit lcd monitors. JUST DO SOME READING FIRST. Then come back to this post and give it a rating if it steered you in the right direction. Bye for now. 12fixlouie
Mar 27, 2010 | Dell UltraSharp 1504FP Monitor
Second monitor is black
Simply hooked up to my onboardchipset and my graphics card. Should have tryed it sooner. Thankyou for all your help
Oct 13, 2009 | Dell Computers & Internet
Dell Vostro 1400 LCD Showing Black Screen
If you can't see it with an external monitor - it generally means the system board needs replacement. I hope that you still have a Dell warranty. Good luck.
Jun 09, 2009 | Dell Vostro 1400 Notebook
Dell E173FPC Monitor stays black and the Power switch cycles
You need to disasemble and check for dry or burn capacitors first then check for the transistors near the inversors.Good luck
Apr 03, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Monitor will not work
Your model number indicates the LCD is made by BenQ. This model is known for poor solder connection causing the inverter driver transistors to short, resulting in immediate shutdown if the inverter circuit. Disassembly and testing the transistors is the only solution I know.
Monitor Mike
Jan 02, 2009 | Computers & Internet
Dell E156FP 15" LCD Monitor Logo
714 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
