Question about Whirlpool Dryers
A few days ago my dryer started making screeching and loud rumbling noises..when I pulled my laundry out there was a felt belt looking object in the mix. Since then the rollers are grabbing the materials in the dryer and marking/staining them. Can I use a front bearing ring to fix this problem or is it a drum seal issue? the model is a Whirlpool Imperial Seventy (86' i believe)# LE7810XPNO
    President:
  • 2,468 Answers
You need to replace that felt piece along with the drum glides/rollers and while its out check the rear drum bearing also
Posted on Jul 29, 2010
I have a stacked Frigidaire FEZ831CA washer/dryer combo and when running the dryer it makes a very high pitched (AND LOUD) screeching sound. Any ideas as to what might be the problem? Thanks, Sean
screeching sound
Sean, Bad felt gasket body to drum, if belt drive on dryer, it could be worn and slipping, making a screech, or if not the belt, the drum may have a worn bearing on its hub allowing it to run crooked and rub where it should not.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Disassembling reassembling stacked clothes dryer
Frigidaire Stacked Laundry with Noisy Dryer
How to Replace an Electric Laundry Center Dryer Drive Belt Kenmore...
Mar 29, 2016 | Frigidaire Washing Machines
Hi i have a speedqueen awm373w-3062 have noise on
Hello.
Loud noises coming from a Washing Machines are most often caused by loose objects inside the unit or by a broken dryer belt. The Washing Machines belt allows the dryer's motor to run smoothly. Continuous wear and dry conditions may cause the belt to dry out, eventually Washing Machines cracking and then snapping. This will cause a loud noise within the unit. Repair and fix the dryer belt of a Washing Machines to get rid of loud noises.
Instructions And Things You'll Needed to solve the problem.
Screwdriver ,Replacement Washing Machines belt
1 Stop the Washing Machines and look inside the dryer's drum for any loose objects such as coins, pens or anything else that may have been in a pocket of clothing. Remove the object and restart the dyer to determine if the noise has stopped.
2 Unplug the Washing Machines from the wall outlet to disconnect all power to the unit.
3 Remove the lint trap from the lint compartment on the top of the dryer.
4 Remove the screws that hold the top panel in place. Pull the panel off to access the
dryer belt.
5 Tilt the dryer forward and lift the dryer drum to remove the belt. Check the Washing Machines belt. A belt that is worn, cracked, split or broken will cause loud noises.
6 Slide the old belt off of the drum and pull it out to remove it. Take note on how it is positioned over the drum.
7 Install the new belt. Lean the front panel away from the Washing Machines and slip the new belt over the drum. Locate the position of the old belt and slip the new belt following the old belt's position ensuring the grooved side of the belt faces down. Push the idler pulley towards the motor to allow you to slip and loop the belt around the motor pulley.
8 Place the top panel on the Washing Machines and screw it in place.
9 Open the Washing Machines door and use your hand to rotate the drum counterclockwise a few turns to ensure the belt is secured.
10 Plug the Washing Machines into the wall unit and begin use .
Aug 02, 2011 | Washing Machines
I have a LG Dryer, DLG2102W. It is about 2yrs old and is making rumbling and screeching noises when on. I am thinking is is a belt or roller
The problem (noise)can be from both side or area !
However, Loud noises coming from a Whirlpool dryer are most oftencaused by loose objects inside the unit or by a broken dryer belt. The dryerbelt allows the dryer's motor to run smoothly. Continuous wear and dry conditionsmay cause the belt to dry out, eventually cracking and then snapping. This willcause a loud noise within the unit. Repair and fix the dryer belt of aWhirlpool dryer to get rid of loud noises. Instructions And Things You'll Neededto solve the problem.
Screwdriver ,Replacement dryer belt 1 Stop the Whirlpool dryer and look inside thedryer's drum for any loose objects such as coins, pens or anything else thatmay have been in a pocket of clothing. Remove the object and restart the dyerto determine if the noise has stopped.
2 Unplug the dryer from the wall outlet todisconnect all power to the unit. 3 Remove the lint trap from the lint compartment onthe top of the dryer. 4 Remove the screws that hold the top panel inplace. Pull the panel off to access the
dryer belt.
5 Tilt the dryer forward and lift the dryer drum toremove the belt. Check the dryer's belt. A belt that is worn, cracked, split orbroken will cause loud noises. 6 Slide the old belt off of the drum and pull it outto remove it. Take note on how it is positioned over the drum.
7 Install the new belt. Lean the front panel awayfrom the dryer and slip the new belt over the drum. Locate the position of theold belt and slip the new belt following the old belt's position ensuring thegrooved side of the belt faces down. Push the idler pulley towards the motor toallow you to slip and loop the belt around the motor pulley.
8 Place the top panel on the Whirlpool dryer andscrew it in place.
9 Open the dryer door and use your hand to rotatethe drum counterclockwise a few turns to ensure the belt is secured.
10 Plug the dryer into the wall unit and begin use.If the noise still exists, you'll want to call a professional repairtechnician. Thanks for using fixya.
Jul 31, 2011 | LG Dryers
My beko condenser tumble dryer is drying fine but is making a loud scraping noise. When I took out the clothes there was a strip of white felt in the washing
Looks daunting to start with but just done mine,
remove top and all rear covers and rear panel after removing drum split washer, pump hoses, belt and elec connection, remove the drum and you will see where the felt seal goes. i had some felt i cut to 12mm wide and siliconed it in place, left to dry for 6 hrs, now runs fine.
Feb 07, 2011 | Dryers
Screeching noise when running the dryer.
Most likely source is the idler pulley. Secondly, is the drum support roller closest to the motor. If the screech is a slower frequency it's likely the roller because the support roller travels at slower speed than idler pulley. Both are replaced by raising top and removing front. Caution: Pull plug before starting and draw diagram of how the belt travels around the idler roller. You will need it to get this back on properly.
Aug 18, 2009 | Kenmore Dryers
Screeching noise and burn smell how do I open dryer to repair
Pull it out from the wall, unplug it and remove the back panel by removing the screws. The problem is most likely the belt around the drum which is either worn out or out of alignment. Take a look at it and decide if you can just straighten it on the drum or if you will need to buy a new belt.
May 01, 2009 | Dryers
LOUD NOISE WHILE DRYING
remove the back cover that covers the lint trap. there is a fan blade back there and some foreign object is probably hitting the fan blade
Jan 01, 2009 | Whirlpool LER4634J Electric Dryer
Dryers Logo
254 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
