Question about Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF
When using hot water, the Rheem revs up like a motor cycle
Rheem unit when heating up the noise is very loud (as I said like a motor cycle) and causes the walls around it to vibrate, very disturbing. Wondering if there is an adjustment to be made on Rheem unit?
    Problem Solver:
  • 9 Answers
I would check and see if the ventpipe that is coming off of the top of the motor is strapped to any duct work in the basement or touching and floor joyces. Even if the venting is touching the duct work a bit, it will amplify the vibration through out the home.
The only other issue it could be would be that the fan blades are bent and rubbing up against the inside of the motor causing the noise and extraem vibration
Posted on Jul 29, 2010
Elite 50 boiler
There should be a pressure drain to purge out all the air. Sound like there is an air bubble in the system somewhere.
Jun 03, 2013 | Water Heaters
Rheen PVW50 Hot Water Heater Making Buzzing Noise and Doesn't Light
Why is it always Rheem problems?
Every water heater problem is Rheem.
And Rheem doesn't post any service manuals, like the other two big manufacturers, AO Smith-American, and Bradford White.
Copy following link for troubleshoot by gas control valve.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Scroll up and find pressure switch heading among links.
You can install gas control valve yourself.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Sep 06, 2012 | Rheem Water Heaters
My electrid rheem hot water heater makes a loud pop sound after using hot water to fill bath tub . Why?
The sound is the water heating through mineral buildup in the bottom of the tank...
The water gets superheated (boiling) because the mineral traps it aroung the element for too long....then it makes the noise as it percolates there....
How to Clean Hot Water Heater
heatman101
Jan 16, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Loud Vibration/Noise when System Starts
This happen when there is air in the gas line...if the problem is still there after a couple of days you will have to return the unit for an exchange the gas control is giving problem...contact rheem first before making a exchange decision..they will walk you some step first to ensure there is not a problem
Jul 03, 2010 | Rheem Direct Vent Natural Gas Tankless...
Rheem glas fury water heater rattling
Thermostat may be heating element hotter than normal causing a change in temperature causing the noise. You could try adjusting temp down a little on thermostat. It sounds like it's getting the water very hot and thermostat may not be working correctly.
May 21, 2010 | Rheem 81VP6S/430126 Water Heater
Sounds like a squirrel inside water heater
Check your thremostat setting if it is set to highest position it may be causing some of the noise over heating the water and making the noise. And you can put an insulated jacket on it to maybe help with sound.
May 14, 2010 | Rheem 30 GAL ELEC SHORT Water Heater 6YR...
My rheem water heater doesn't seem to be heating the water. I have a Rheem model 81SV40D and the water is not hot and doesn't seem to get hot. I have checked the dials on the water heater and they are set...
try setting the bottom 10 degrees hoter than the top could be in short cycle (thatis the bottom calls for heat on the bottom element and set too close so goes back to top and cycles off
Jan 04, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
After use, while its refilling, my Rheem hot water heater makes a banging sound inside. Anyone have this issue?
I suspect the noise is being caused by expanding metal groaning or 'popping' due to the expansion. We have a metal roof on our home and heating and cooling are always accompanied by similar noises that are inaudible inside the house but catches our attention if we are on the porch.
Nov 04, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Loud blower on my new Rheem Power Vent 2 water heater
find out if it does the same noise with the venting disconnected
Nov 01, 2009 | Fasco Bradford White Hot Water Heater...
Noisy Rheem 16 instant hot water heater
About the only device in that heater that could cause the noise you describe is an electrically operated valve that controls water flow. Rheem is a better-than-average company so I would give them a call and describe your problem to them; I'll bet that they will be glad to tell you which part you need and supply it to you.
We had a heat pump system from Rheem that needed only the replacement of one large relay and the outside unit fan motor during more than 25 years of service and is still operating at age 30 in our former home.
Oct 03, 2009 | Rheem 81VP6S/430126 Water Heater
Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF Logo
381 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
