Question about KitchenAid KTRC19KM Top Freezer Refrigerator
Help 'My ice maker keeps making a growling noise
Help 'My ice maker keeps making a growling noise whether in the on or off position, and is not making ice, do I need to call a repair man or is it something I can fix? Thanks peggy
SOURCE: Ice maker not making is
It uses electronics. I took a blow dryer (suggestion from other sites) to see if thawing out the line running inside on the top to the back of the refrigerator would help. No luck!
Posted on Dec 12, 2007
aborcass
  • 2651 Answers
SOURCE: ice maker
reach your hand into ice maker assy, is there ice in it and not ejecting??? there are tines that eject the ice, do these move around freely and easily(if so you need a new ice maker they should not turn by hand)
Posted on Feb 24, 2008
  • 110 Answers
SOURCE: Ice Maker won't work...water line frozen?
HOLLOW ICE FOLLOWED BY FROZEN WATER CHUTE ARE THE FIRST SIGNS THAT THE WATER INLET VAVLE IS OR HAS FAILED, IT CAN ALSO CAUSE DAMAGE TO THE ICEMAKER BY BURNING OUT THEN TIMING GEAR DUE TO INSUFFIENT WATER OR FLOODING IN ICEMAKER WITH TOO MUCH WATER
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Posted on May 30, 2008
  • 1073 Answers
SOURCE: mfi2568aes ice maker
it is under warranty call for service
Posted on Jun 22, 2008
  • 531 Answers
SOURCE: my whirlpool ice maker makes a noise like its growling or like a
you sure is the icemaker and not the fan in the freezer
Posted on Apr 07, 2009
Ice maker is not making ice.
Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary.
Mar 27, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frigerater making abuzzing noise
The ice from the ice maker falls behind the ice bin if it gets too full and goes onto the fan. This is what is making the noise. Keep a watch on the ice so it doesn't get too full and overflow. You can shut the ice maker off when you see it getting too full by placing the lever int eh upward position.
Feb 23, 2010 | Frigidaire FRS3R5EMB Side by Side...
My GE integrated ice system stopped making ice but the water still works?
Well Check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat. Please post comments for more help or information.........
Good Luck!!
Thanks
Dec 28, 2009 | GE 24.6 cu. ft. Side-By-Side Refrigerator...
Ice maker makes grinding noise (no ice)
Sep 25, 2009 | Maytag MBB2256G Bottom Freezer...
Ice maker stopped making ice and motor keeps running like a growling noise
The mold heater has broken. You will have ti replace the ice maker module.
Sep 02, 2009 | Maytag MFD2560HES Bottom Freezer French...
Ice maker not making ice. motor is making noise,
Hi, Reach in and see if you can feel ant ice laying on top of the ice maker fingers that might be jamming the ice maker. The motor making a noise is why I suggest this. If you can remove the ice maker and look, it would be better. Another option is to pop the ice maker head cover off and see if the drive wheel is trying to turn or maybe even broke.
Please let me know what you find so I can assist you further.
Vic
Jul 12, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
My whirlpool ice maker makes a noise like its growling or like a
please switch off your refrigerator for at least 8 hrs. than again switch it on. if your problem is not cured than it is sure that your refrigerator have the blower problem because for this reason only, the problem arrises ....... please visit your service authority...........have a nice day:-)
May 15, 2009 | Whirlpool Freezers
Growling noise coming from back of fridge
Try lubricating all fan bearings that you can get to. Make sure fan blades not hitting any thing.
Aug 27, 2017 | LG LRBN22514ST Bottom Freezer Refrigerator
Ice Maker Making Noise
sounds like a noisy ice maker, is it making ice? about $100 for new ice maker. ck warr jeen air might warr parts in that unit for2 years
Feb 09, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
KitchenAid KTRC19KM Top Freezer Refrigerator Logo
195 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
