Question about Nokia 5310 Cellular Phone
Locked micro sd card in nokia 5310 n not finding fexplorer for 5310
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Sep 20, 2010
  • 148 Answers
Your set(5310) will not support symbian applications(Like n73,n95) Fexlorer is a symbian software, and you can use mobiexplorer
Posted on Jul 29, 2010
If i copy something in to my micro sd card (nokia 5310), this message is showing "THE DISK IS WRITE-PROTECTED"."REMOVE THE WRITE PROTECTION OR USE ANOTHER DISK". I already format my SD...
ou the side of sd card their is lock move it to the open or give me a call go to my sit for info www.1quickcomp.com
If you need further help, I’m available over the phone at https://www.6ya.com/expert/omar_c87dacfef1e87642
Aug 13, 2011 | Nokia 5310 Cellular Phone
How to remove password from micro SD card in nokia 5300
Hi there, I have a micro sd card from Nokia 5300 phone.But when i use the same card in Nokia 3120 Classic, the memory card has been locked but i did not set any password for the memory card...Can this issue be solved in nokia 3120 classic phone.Can the password be unlocked in nokia 3120 classic.........Please advise.....
max2010
Mar 10, 2010 | Nokia 5300 Grey Cellular Phone
Nokia 5310 micro SD memory card
If you dont remember the password that you gave it, will be undone only by formatting the memory card and thus loosing all data on it.
Aug 31, 2009 | Nokia 5310 Cellular Phone
How to unprotect micro sd memory card password
Try to format the MMC Card:----
1. First Install FExplorer in your phone memory.
2. Got to drive C: , you will find a file called MMC store.
3. Send it to your PC directly and open it in notepad or rename the file.
4. At the end of the file you will find your password. Thank you Sir, Have a nice day.
If above doesn't avail, Try dailing *#7370#
Aug 25, 2009 | Nokia 5310 Cellular Phone
Unlock micro SD chip
U CAN PUT DA MICRO SD CHIP INTO THE ADAPTER AND FORMAT IT ON THE COMPUTER AND IT WILL ERAZE EVERYTHING U HAV ON THE MEMORY CARD?
Jun 16, 2009 | Nokia 5310 Cellular Phone
My micro SD meory Card got lock i want to unlock it but i dnthave card reader
Dear Sir,
I have Nokia 5310 xpressMusic phone with two GB micro SD memory Card, which has locked. please unlock the same at your earliest.
Yours sincerely,
Customer
Jun 03, 2009 | Nokia Consumer Headset
NOkia 5310 SD Memory Card Problem
i have forgotten the password to my SD memory card. FExplorer.sis is not supported in NOKIA 5310. Can any one help for this... plzzz...
Dec 06, 2008 | Nokia 5310 Cellular Phone
Unlock 1 GB micro sd memory card of Kingston Made
I hav a kingston 1gb micro sd card i have forgotten password.plz. help how to unlock the card?
Jun 29, 2008 | Nokia 6300 Cellular Phone
Micro sd card password unlocking.
To my knowledge unfortunately, there is no way to unlock without the password. The only information I can share is to have it reformatted. If formatting could not be performed likewise (due to password restrictions), pls try using a memory card reader attached to a PC and running HP USB Utility (cp006049.exe).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 10, 2008 | Nokia 5200 Cellular Phone
Nokia 5310 Cellular Phone Logo
162 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
