Question about Nikon COOLPIX L18 Digital Camera
I am trying to download pictures from my Nikon S8000 by either plugging the camera to my PC via USB or plugging the SD card into my PC, and I cannot! I can view the pictures in the camera, so I know they are there. Any tips will be greatly appreciated!
  • 6,826 Answers
Must install the camera's driver on to your computer before plugging the usb cord into the PC.
I would as a rule install the camera's software from Nikon.com's support site if it did not install automatically.
http://www.nikonusa.com/Find-Your-Nikon/Product/Digital-Camera/26191/COOLPIX-S8000.html
It can sometimes be difficult to setup a digital camera on a new computer. Usually the process is simple: plug the camera in, allow the system to install the driver and begin using the system, however, sometimes things can go wrong. Following these steps can solve more than 90% of problems relating to USB connection issues. You must be thorough and follow it step-by-step.
  1. What CF Card is installed in the camera?
    A large number of problems are caused by incompatible CF Cards. In many cases these cards will work while shooting but can fail to properly download to the computer. You must be extra careful that the card is approved. Actually look up the card you are using in the manual to see if it on the list. Many retailers include "Unapproved" cards in their bundles, so just because a card came with the camera doesn't mean that it is "Approved".
    If in doubt, use the "Nikon Starter Card" for testing.
  2. Is the Camera in Mass Storage Mode?
    While PTP mode can be used if your camera and operating system (Mac OS X and Windows XP) supports it, for troubleshooting it may be useful to switch to MSC USB mode using the camera's setup menus.
  3. Are there images on the card that can be viewed on the camera in playback mode?
    Nikon View will not auto launch or give a transfer window with no images on the flash card. If you have covered the first three items you should now connect the camera to the rear USB port (not through a hub or front port) on the computer. On all Windows systems excluding Windows 98 Second Edition (SE) ("Plain" Windows 98 is not supported.) make sure the Nikon View CDROM has been removed from the system prior to connecting the camera.
  4. Does the LCD Display Screen go dark after being connected for 2 seconds?
    If you are not getting the "Found New Hardware" wizard then check the LCD display. If the display stays "on" and the camera seems to be in Shooting mode or Playback mode then you may have a bad cable, camera USB port or computer USB port. If this is the case, contact Nikon Support for more information or Click Here for more troubleshooting.
  5. Does "New Hardware Wizard" Start?
    If you connect the Camera and a "Found New Hardware" wizard comes up you should allow the system to auto search for the driver by simply clicking the "Next" button until it is finished. (Windows 98SE requires the Nikon View CD-ROM to be in the CD-drive at this point.) On Windows systems newer than Windows 98SE the camera should pick up and use the Microsoft Mass Storage driver.
  6. "Hardware Handshaking"
    You need to understand how hardware handshaking works. The hardware Handshake occurs when a USB device is connected to the USB port. The computer detects the USB device on the USB bus and asks: "What are you?" The Coolpix line of cameras should answer: "I am a Nikon Coolpix 5700 currently set to Mass storage mode."
    If the computer does not understand this message the most likely cause is an incompatibility with the USB chipset on the particular USB controller that the USB port is connected to. You can check your controller chipset on the Microsoft Hardware Compatibility list. First find your "USB Controller" (i.e. Intel 82801AA USB Host Controller) in your computer's "Device Manager" and then look it up on the above link. You can tell if the handshake failed if the camera is listed in Device Manager under “Unknown Devices” or “Other Devices”.
  7. Drivers
    The Mass Storage Driver set consists of two drivers. The first driver is the “Mass Storage Driver” ("Nikon Mass Storage" driver on Windows 98SE systems) and the second is the driver for the CF card in the camera. The CF Card driver should be listed under “Disk Drives” in Device Manager. Be sure both drivers are installed and showing up cleanly in Device Manager.
  8. Auto Launch
    If both drivers are installed "cleanly" in Device Manager (no question mark or exclamation point) then you do not have a camera or driver issue. If Nikon View does not “Auto Launch” or the Nikon View “Transfer Window” comes up but fails to transfer images then the you can usually resolve these problems with the following steps. Nikon View is not required to transfer images from Nikon Coolpix camera’s capable of running in Mass Storage Mode.
  9. If the drivers are clean but you are unable to transfer images
    Double click on “My Computer" and verify that a “Removable Disk” icon with a drive letter is listed. If the "Removable Disk" is not listed then there may be Network Drives mapped with drive letters that follow the last actual local drive listed. If this is the case Click Hereto learn how to change the drive letters to accommodate the Removable disk
  10. If the Removable disk does mount
    There are two simple ways of transferring images:
    a) You can click through the directories on the removable disk: i.e. "g:\DCIM\100Nikon" and copy the entire contents of this directory then paste into a local drive location such as "c:\My Documents\My Pictures."
    b) The second option would be to launch Nikon View and select the removable disk from the folder list on the left. With the removable disk expanded down to the "100Nikon" directory you can "select all" and drag the images to a local drive location listed on the left.
  11. Transfer starts but fails to transfer all pictures.
    If Nikon Transfer starts but fails at any point during the transfer then there may be some bad picture files or corrupted data on the flash card. This will sometimes occur if the card has been used in a card reader to move non-picture files between various computers.
    Note at which file number the transfer is failing and go through the mounted removable disk to delete that picture file. You can also copy all the picture files except the damaged files from the card. Always format the flash card in the camera after you have recovered the undamaged picture files to the computer.
Posted on Jul 29, 2010
Pictures will not transfer to my pc via the usb or the sd card
Did you install the Nikon ViewNX 2 before you connect the camera? Are you sure there are pictures on the memory card?
When you don't know where you left the CD with the software, you can download it for free from this Nikon site:
Current versions of Nikon software Nikon Knowledgebase
Apr 20, 2015 | Nikon Coolpix S3000 Digital Camera
How to get the Nikon in 5200 PTP Mode? Can not find USB mentioned any where.
I would not use PTP. Too many things can go wrong. Just about all professionals download directly from the SD memory card. Follow the following steps. They are very similar for both Mac and PC.
1) With the power turned off, remove the SD flash memory card from your camera.
2) If your computer has an SD card slot, insert the SD card in the slot. If it does not, there are many USB cable input card readers for under $20. Connect the external card reader to a USB receptacle on your computer. In either case, the computer will use "Plug-n-play" to connect your SD card.
3) Double click either the device or folder on your desktop. The pictures are almost always inside a subfolder. When you open that folder, you will see your photos.
4) Depending on what you want to do with your photos at this point, you may want to move the downloaded pictures to another location or software such as Lightroom or Photoshop.
5) CAUTION! If you want to erase your SD card, DO NOT DO IT VIA THE COMPUTER. Your computer's formatting may not be compatible with your camera's format algorithm. Remove the SD card from the computer or reader and insert it in the camera. Follow the instructions on page 168 of the D5200 manual to reformat the SD card.
May 19, 2014 | Nikon D7000 Digital Camera
How to upload photos form a nikon coolpix S8000 to my computer ??
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use Nikon Transfer or any other photo cataloging program.
Dec 11, 2010 | Nikon COOLPIX S8000 Digital Camera
Can't download to computer. dell with vista
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo cataloging program.
Oct 23, 2010 | Nikon COOLPIX S8000 Digital Camera
My nikon coolpix s8000 will not charge and when i attempt to transfer pictures from the camera onto my computer (which has the nikon software already installed on it) nothing happens.
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Nikon Transfer or any other photo management program, such as Picasa.
Organize edit and share your photos
Aug 28, 2010 | Nikon COOLPIX S8000 Digital Camera
Can`t import pictures from my nikon s8000 using neither usb cable nor from sd card... help!
nikon s8000 user manual pdf but can't view it why? how can I view it?
Jun 22, 2010 | Cameras
Coolpix s220 won't transfer pics via usb cable
If you can get the pics using a card reader, why are you insisting on using the camera and USB cord? Pros always use a card reader.
Feb 07, 2010 | Nikon COOLPIX L3 Digital Camera
I'm trying to download pictures from my Nikon Coolpix. The camera has a fully charged battery and is plugged in via the USB port. However, when I launch the Nikon Transfer process, I cannot select any...
Is the camera recognised by the pc as a usb 'drive'.?? If not try another cable. If another cable does not help, then the fault could be with the camera itself.
Try inserting the card in a separate card reader attached to a pc - if you can see the latest pics taken, then the camera is taking pics ok - and we are back to the transfer problem.
If you can see the pics in your 'my computer' then you can copy or move them onto your pc's hard drive. The fault then could be your Nikon transfer program. Try reloading the software as it may be corrupted on your pc..
Nov 07, 2009 | Nikon Coolpix S210 Digital Camera
Computer won't recognise my Nikon d60
dont bother to connect camera to pc..just use the SD card reader...either external usb one or laptops internal one
Dec 19, 2008 | Nikon D60 Digital Camera
Nikon COOLPIX L18 Digital Camera Logo
2,057 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
