Question about Akai Televison & Video
Akai PT46DL10 rear projection tv won't turn on
No lights, no warning, no noise. It is hooked up..unplugged and re-plugged, nothing.
Posted on Feb 05, 2011
My Akai Tv won't turn on at all
hello do you mean no power, if so have you checked the fuse in the plug if ok then it's possible that the glass fuse inside the tv may have blown this will be in the power supply
regards
shaun
Oct 08, 2010 | Akai PT46DL10 46" HDTV-Ready Television
2002 akai 54in. rear projection tv wont turn on
Unplug,replug the tv back an hour later.The tv should reset itself.More problems repost,see if i can help u.
Feb 20, 2010 | Akai PT5492S 54" Rear Projection...
No power,no lights nothing!!
Hi,did you close the door cover?Make sure itsproperly shut other wise it won't tv light up. Reset the lamp
timer? you can do this by unpluging the set for 5 min
and plug it back(works for most sets). Was the fan
running ok? You can clean it w an air pressure
can. If you heard clicking or like wanting to turn on the problem could be with the board that powers the lamp.The board it's called the ballast.If its not able
to provide the power to the lamp it will not turn it on
and the red light will blink.
Dec 16, 2009 | Akai PT46DL10 46" HDTV-Ready Television
RED LIGHT FLASHES 10 TIMES BUT WILL NOT TURN ON!
There might really be a problem with the unit. Try unplugging it out of the power outlet and plug it back in after 30 seconds. If your using a power box (voltage regulator), try plugging it directly to the outlet. If all nothing happens, see a local tv tech in your area. The unit could be damaged.
Nov 08, 2009 | Akai PT4298HD Rear Projection Television
My akai rear projection dlp tv has no power and I don't know where the grille lamp is located. I'm not sure why the power is not coming on, I've check all I know to check.
The lamp is accessed removing a panel on the back right side. If there are no lights at all it may not be the lamp but the power supply (no fuses inside).
Oct 05, 2009 | Akai PT46DL10 46" HDTV-Ready Television
Akai, PT46DL10 Has sound, no picture
make sure all componet cables are in the right color coded spots on the back or side of the tv and you are on the right componet if using a cable box make sure using componet / monster cables not all cable companies support hdmi if that is how you are trying to hook up make sure to check with them
May 14, 2009 | Akai PT46DL10 46" HDTV-Ready Television
Code remote akai pt46dl10
had same problem tried all kinds of universal remotes but none were compatible look online and found only logitech Harmony® 550 Advanced Universal Remote is compatible with this model akai pt46dl10 bought one now works fine and was able to reset my lamp timer with it as i just replaced it paid $65 on craigslist for remote good luck
Apr 26, 2009 | Akai PT46DL10 46" HDTV-Ready Television
Akai PT46DL10 Image in Black and White
If you remove the lamp, you will be able to see that the lamp is defective. In order to know if something else is defective, the new lamp should be install.
Let me know if you need further assistance.
May 26, 2008 | Akai PT46DL10 46" HDTV-Ready Television
TV will not turn on...
Convergence board failure. $300 repair
Sep 19, 2007 | Akai PTH5498 54" Rear Projection...
Televison & Video Logo
65 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
