Question about Hitachi CLU-5713TSI Remote Control
I DROPPED MY REMOTE AND THE BATTERYS CAME OUT AND NOW I CANT TURN THE CHANNEL SO I NEED TO KNOW HOW TO PROGRAM MY REMOTE
    President:
  • 1,932 Answers
Hi.
Manual Programming:
1. Turn on the device with which you want to use the remote control.
2. Locate a 3-digit code for your device.
3. Press and hold the corresponding button on the remote control
(TV, VCR, SAT, DVD, CAB or AUD) for approximately three seconds unitl the POWER INDICATOR illuminates.
4. Enter the 3-digit code for your device within 30 seconds. The POWER INDICATOR shuts off.
5. Press power button to verify correct code entry. If the device shuts off, the code was entered correctly. If the device does not shut off, repeat steps 3-4, using a different code.
Automatic Programming
With automatic programming, the remote control tests all the codes available on the Code List and assigns the correct code for the selected device.
1. Turn off the device with which you want to use the remote control.
2. Press and hold the corresponding button on the remote control(TV, VCR, SAT, DVD, CAB or AUD) until the POWER INDICATOR illuminates. The remote control is in programming mode.
3.Press and release power button. The POWER INDICATOR flashes once and stays on
indicating the unit is in Power Scan mode.
3. Press CHANNEL UP or CHANNEL DOWN repeatedly until the device turns on.
4. When the device turns on, press OK to store the code.
5. Press any other button. If the device responds, the remote control has been programmed. If the device does not respond, repeat steps 2-5.
Thanx
Posted on Jul 29, 2010
My Serial number is 94590994 and I cant tell what universal remote I need. TV is Stuck on channel 2
Do yourself a favor and save time, money and aggravation and locate an original remote, universals if they will program will be missing key features the original had.
If you insist on a Universal, use your computer and Google with the model number search for remote. that should give you a few hundred different remotes that might work.
Dec 15, 2012 | Toshiba 32A33 32" TV
Tip
Dei viper python valet hornet boa transmitter programming help
DEI REMOTE PROGRAMMING INSTRUCTIONS
Need a DEI Remote Replacement Now? Try our all New Remote Quick-Find
Not sure what type of Replacement Remote you need?
In order to enter Learn Routine, the Valet/Program push button must be plugged
into the main brain's Blue 2 Pin Port (Look for a small black push button located under
the drivers dash or drivers kick panel somewhere). If you do not have the Valet/Program switch, you may order it at www.lesscoelectronics.com or www.lesscosales.com
1)
Open a door and make sure the dome light is on.
2)
Turn the ignition on to the RUN position or you may also start car.
3)
Within 15 seconds press and release the Valet/Program push button
to select the channel you wish to program. For example, press and release
once for channel 1 (arm/disarm channel).
For Channel 2, press and release twice (trunk release).
For Channel 3, press and release three times (remote start).
(Some DEI systems require different programming for different channels. You
can get specific installation manuals with remote programming instruction)
Press and hold the Valet/Program push button once more. You should get a
confirmation chirp/horn-honk or a flashing LED light (If installed).
If you do not get a chirp/horn-honk the alarm may have a jumper in
the alarm that has the programming feature turned OFF (disabled).
4)
Once the alarm chirps/horn-honks keep holding the Valet/Program push button.
5)
Press the button on the transmitter that you would like to control the selected receiver
channel. A chirp/horn-honk will confirm that the code has been learned. If programming
more than one transmitter repeat step 5. Old transmitter codes will be dropped only
if programming 4 new transmitters.
6)
Once the code(s) are learned, the Valet/Program push button can be released.
Learn Routine will be Exited if:
Ignition is turned off
Door is closed
Valet/Program push button is pressed too many times
More than 15 seconds elapses between steps
One long chirp/horn-honk indicates that Learn Routine has been exited.
on Jul 29, 2010 | Car Audio & Video
Dropped my remote on floor and now no buttons work
your batterys probably got loose inside the remote. take the battery cover off and push them back into place.
Jul 13, 2012 | Samsung TV Remote Control
Cant get to channel 3 on my magnavox tv
If set has a menu button go to menu and find auto program and program channels with it.
Otherwise you need a working remote to enter 03 and get back to that channel.
Mar 13, 2012 | Televison & Video
Need help to program my new T.V. to my remote
hold down code until it stays lit, then press tv then keep hitting channel up or channel down (either one can be used, keep pressing channel button til tv changes channels when it does press enter, or ok if enter is not there, it may take awhile maybe a few channel pushes up to 200 and up times, you use this method when you don't know the code for your tv. Hope this helps.
Nov 30, 2009 | RCA D770 Remote Control
Cant program remote to the tv
i cant program remote to the tv
Jun 14, 2009 | RCA Universal Remote Control
Channel edit option has gone..
switch off take batterys out of remote plug back in after 30 secs insert batterys try again should sort your prob mate send me your codes to check also kiki
Dec 17, 2008 | StarTech.com StarView SV211K 2-port KVM...
Cant turn the tv to channel 3
Go to the Menu setting, and do a auto channel scan, it will automatically program it to NOT skip 3.
Nov 25, 2008 | RCA Universal Remote 3 Device Remote...
PROGRAMING MY MAGNAVOX UNIVERSAL REMOTE CONTROL
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 18, 2008 | Philips Magnavox Learning Universal Remote
How to program my rav 300 remote
Here's how I got mine to work. FIRST THING: Once it's programmed, you use the TV function keys at the bottom of the remote for Power On, channel changing, etc. The other keys on the remote don't operate the TV.
1) Press the "code set" button with a pen or straightened paper clip
2) Press the [A] key (next to "V-AUX")
3) Enter the code
Test it by pressing the Power key in the TV section on the remote (NOT the "Source" Power" key or Main power key at the top).
Jan 10, 2008 | Yamaha RAV-300 Remote Control
Hitachi CLU-5713TSI Remote Control Logo
232 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
