My WD Home external hard drive is beeping softly and I can't see it on my computer. I checked cables and all seems fine.
Xeogin
  • 9 Answers
SOURCE: New WD external drive not showing up in my computer
I just had this problem, go to Computer Management/Disk Management, and assign a drive letter to it, for some reason it doesn't automatically.
Posted on Jan 26, 2009
SOURCE: Windows Vista does not boot with hard drives plugged in
I had the same problem with vista home 32bit. I accessed the bios then went into usb configuration, and disabled the "legacy suppor" for usb, this is an older support for usb 1.0 before 2.0. Once disabled was able to reattach two external hdd, and reboot normally
Posted on Mar 25, 2009
darkoh69
  • 77 Answers
SOURCE: Flashing blue light on external WD hard drive & not recognised
sounds like you are using the wrong power supply. Check the amp output on the power plug you plug into the wall make sure its the same as the amp input of your external harddrive
Posted on Jun 01, 2009
  • 81 Answers
SOURCE: My WD 2T external My Book hard drive is not working
You will need to try formatting the drive. You can do this from the drive management section on the Mac.
Posted on Jul 10, 2009
bob_computer
  • 3153 Answers
SOURCE: I have a WD My Book 1 TB external hard drive. It
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly. 5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
Posted on Nov 17, 2009
I have the wd elements 1tb portable drive..it gives me a beeping sound and willl not come up on my laptop..i can see it in device manager but the elements will not come up on my computer..the beeping sound...
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
Jul 18, 2011 | Western Digital Passport WDXML800UE...
We bought some time ago an WD External Harddisk and now the Adapter doesn`t work anymore! What can I do?
Try connecting it to a different computer.
Any external storage device has three major parts:
* USB cable
* disk-drive
* USB-to-disk-drive adapter
Try a different USB cable.
Disconnect the disk-drive from that adapter, and connect the disk-drive as a "slave" disk-drive in a desktop computer, and see if you can read the files, which implies that the adapter is the part that has failed.
If you cannot read from the disk-drive, check its WARRANTY status. W.D. will replace it, if the warranty is still valid.
Otherwise, W.D. has a "Customer Loyalty" program: find the serial-number of your unit, access their web-site, and purchase another W.D. external storage unit, at a significant discount, by citing the serial-number.
Or, if the adapter is OK, then replace the disk-drive by a new one, and close-up the casing, to create a "revived" external storage device for your use.
Oct 23, 2010 | Western Digital Elements powered by WD 320...
Computer won't recognize external hard drive anymore
Have you tried changing the USB cable or connecting it to a different USB port on the computer?
Nov 14, 2017 | Western Digital 320GB MyBook External USB...
WD 640Gb My Book Essential: HD on main computer
files must be "imported" into your new mail program.
the new computer may have a newer or different version.
Apr 08, 2010 | Western Digital My Book Essential Edition...
I have a WD external hard drive USB 2.0 750 GB. It was working just fine for many months, and suddenly, my laptop won't "read" it -- it's not listed/detected in "my computer." I thought there was something...
If the device is recognized and not listed as a driver in the Explorer, then the disk is not recognized as having been partitioned and formatted. You can use the Disk Manager to see if there is anything listed on the disk.
Start - > right-click My Computer -> Properties
In the management console, go to disk management and check your disks. The external disk should be there and then you can see the partitions and drives assigned to it.
If there is nothing on it, your MBR could be damaged, which needs to be restored.
Alternatively you could partition and format it, but then you'd loose the data on it, so that is a last resort.
I think a program called Acronis Disk Director Suite can restore MBR's. Have a look at this external hard disk troubleshooting article.
Jun 13, 2009 | Western Digital Elements powered by WD 320...
External USB Drives No Longer Detected
There are two possibilities:
The Mybook USB/ATA controller board is faulty.
In this case you can simply take apart the enclosure and mount the disk into a new enclosure. WD Mybooks are SATA, but double check the hard disk connector to ensure.
The hard disk inside is faulty.
In this case repair may be expensive. You need to locate a data recovery facility with a 'clean room' , the cost is usually more than $800.
If this happened after a power surge, then the problem is most likely a faulty controller board.
If instead you have dropped the hard disk it is possible an hard drive failure, in that case repair will be expensive.
A replacement enclosure will stfrom art about $20 on Ebay or Amazon, and must not necessarily be WD .
Check if your disk is Sata or PATA (IDE) before buying the enclosure.
Apr 22, 2009 | Western Digital 320GB MyBook External USB...
WD 500gb external HD shuts down when plugged into USB port
Try a replacement USB cable first. If that does not fix the problem, then the USB to SATA adapter board is faulty, in that case you will need to take out the internal disk to replace the external enclosure.
see
YouTube - How To: Take Apart A Western Digital My Book Enclosure
If unit is under warranty see : WD Support > Warranty Services > End User > Warranty Policy.
Note any SATA external enclosure willl work wthe same with the internal WD HD.
Apr 17, 2009 | Western Digital My Book Home Edition 500...
Jul 16, 2008 | Western Digital My Book Premium ES...
Wd problems
Change the drive letters, worked for me. I have 2 WD My Books, I made one R: and one S: worked fine after that. On vista go to Control Panel -> Classic View -> Admin Tools -> Computer Management -> Disk Management -> Right click on WD drive and change letter. For some reason G, F, E, ect seem to run into some problems
Dec 06, 2007 | Western Digital Caviar SE16 (WD5000AAKS)...
Computers & Internet Logo
Alun Cox
David Payne
David Payne
