Question about Mitsubishi Vehicle Parts & Accessories
Not colling well
Sir i have mitsubishi model no MS-A13VD 1Ton and room size is 11*11 but my mitsubishi is not colling and its condenser is working and working and working and after 12 hours room temperature not come down even 24degre
its through is good but only fan through not colling
i checked it to makanic he cheaked voltage and condensor is working
but outer not through hot air he through normal through#
he also check gas but gas is full and we are unable to solve kindly help me in this mater
i am too much depress
  • 105 Answers
SOURCE: Cool air when running; warm air when compressor is off.
It sounds as if warm outside air is being drawn back into the room when the unit is not actively cooling. Portable units depend on room air to carry the heat outside, & therefore will not work properly if the room is too airtight. Provide a makeup air passage by leaving the door slightly open, & see if this helps. Use a room thermometer to see if your desired temperature is being reached. Note that if the wind is strong & coming from the wrong direction, it may not be possible to prevent warm air drawback.
Posted on Jul 18, 2007
fridgetech
  • 473 Answers
SOURCE: Freezer and Refrigirator not cooling
You didn't say if the compressor is running or not. If it is and all other things you stated are running then it has a sealed system problem. The sealed system comes with a 5 yr warranty in most cases (check owners manual). If the compressor is not running then listen for a click at the compressor. If you hear the click then I would replace the relay on the compressor. If you need further help I will need the complete model # off the sticker inside the fridge section.
Posted on Nov 09, 2007
SOURCE: Kenmore 18,000 btu Air Conditioner model # 75180 - Condensor Problem
HI , LISTEN MY AIR CONDITIONER DOES NOT START. CORD,THE POWER-TEMP CARD OR WHAT ELSE IT HAPPENED IN A LIGHT OUTIGE. THANKYOU. IT A KENMORE 18,000
Posted on Oct 20, 2008
  • 588 Answers
SOURCE: York HVAC unit fan is
If your fan is making noise the blade or blower wheel is either hitting something or the bearings in the motor are bad and the motor needs to be replaced.
Posted on Apr 23, 2009
roniecon
  • 6927 Answers
SOURCE: Condenser Fan not working when the Air Cond is On.
There is a high pressure switch on the high side of the ac system,it most likely is bad.
Posted on Apr 06, 2010
Testimonial: "I had change the pressure switch but the problem still same"
I need to pull an 11" x 48" sheet through my printer
That will never work as the printer looks for pages that are standard sizes. If it comes across something that is larger, the printer reports a paper jam. Making banners is best done on dot matrix printers using listing paper. Otherwise on a home printer, you use the banner setting in your creation software, MS Word, MS Publisher, and you print as separate pages and stick them together or stick them on a backing sheet.
Oct 22, 2015 | Epson WorkForce WF-2540 All-in-One Inkjet...
What size is this evaporator coil, trane R384JM9FG
3ton,the #38 in model # close to 36.12,000 1ton,24,000 2ton.etc
Apr 01, 2015 | Heating & Cooling
Intermittent colling in Samsung Window AC
so your reported figures show that the unit is operating as planned
the closer to ambient temp the shorter it runs for
the further away from ambient temp the longer it runs for
when the desired temp is reached , the compressor will stop but the fan will continue to run to circulate air past the thermostat so that it will switch back on when the room temp reaches too high temp
and that is why it is recommended to set the temp at 25 C as that is the most economical temp to run it at
Oct 30, 2017 | Heating & Cooling
I don't have a problem, I was just looking up reviews of the product to see if it was worth buying. Model # AJCS12DCB
It should be as good as any about the largest 110V available a 12,000 (1ton) enough to do a medium sized room or 700 give or take 200 for building construction. Good luck,Mastatech.
Aug 21, 2011 | GE AJCS12DCB Air Conditioner
Im installing an 2.5 ton package heat pump into a existing house running reduced supply trunk in crawlspace 1200sqft home and dumping 750 cfms to 850 cfms into conditioned space . i need to know what the...
400cfms equal 1ton of cooling/ 500 sq. ft equals a ton of cooling. It also depends if you are starting from one end of the house or in the center.
Count how many 6inch leads you have or registers you have in the entire house. If you have11 leads on one side of the house and 11 leads on the other side of the house. Then you need 24x8 duct on both sides of the plenum.
Take 11 times 2= 22 plus 2= 24x8 duct. If you have a ductulator this always comes out right if you selct .01 static pressure.
Good Luck
Jun 24, 2010 | Heating & Cooling
How can change Font Size 11 into12
Under MS Word 2007 simply:
- In the menu bar you see the font name and beside it is the font size, for example, 11.
- Highlight some text in your document.
- Now click on the drop down arrow by font size and slowly scroll through the sizes.
- The selected text will change sizes as you move through the size listing.
- In this way you can get exactly the right font size for your document.
Jan 04, 2010 | Epson FX 1170 Matrix Printer
Tank capacity of 1994 model 1.8lt 1Ton bakkie
1.8litre engine for a pickup???
Anyway, the tank size for a 1994 Nissan Pickup will be 16 gallons. The V6 version will have a 21 gallon tank
Sep 10, 2009 | 1994 Nissan Pickup
Respected sir sachin i am working for ritz carlton hotel in bharain as an refrigeration tech i would like you to ask that we have lot of proble with the ice machine cube type the majour is that when we...
All harvest times are approximate. Not exact times.
The ambient temperature in the room affects harvest, so does a dirty condenser coil and a scaled up evaporator coil.
Make sure both coils are good and clean.
Ice thickness controls can be adjusted also for quicker drops. However the cube size will be smaller.
What brand and model number is the machine?
Mar 18, 2009 | Zanussi Refrigerators
Vehicle Parts & Accessories Logo
131 people viewed this question
Top Mitsubishi Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Navin Sharma
Navin Sharma
Are you a Mitsubishi Vehicle Part and Accessory Expert? Answer questions, earn points and help others
