Question about Kenmore Washing Machines
On a front load washing machine what do I do if F 35 shows up and the machine hums?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Assuming this as Whirlpool washer Error F 35 means Analog Pressure Sensor Failure- which means that there is a malfunction of the component detected by the Steamer Electronic Board.
1. Check that the pressure hose is fixed correctly.
2. Check that the air trap is not blocked.
3. Check that the hose is not blocked
If still the issue is not resolved then it is an issue with the water level pressure switch operation and there is a blockage in the air dome or pressure switch hose. The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome are clear of any blockages, then there is an issue with the water level pressure switch. Please do rate the solution if the issue is resolved or else post a comment for further assistance.
Thanks
Rylee
Posted on Jul 31, 2010
When I plug my amana front load washer in it hums and wont start the only light that comes on is the door lock light and its blinking
well a hum usually is not a good sign, do u smell anything when it hums? sounds like a bad motor or bad motor windings to be precise.
Nov 03, 2014 | Amana Front Load Washing Machine Washer...
E11 frigidaire front load washer solenoid hums
change the water inlet valve located where the hot and cold hoses screw in to it
Dec 03, 2013 | Frigidaire ATF6000ES Front Load Washer
Washing machine Front Loading Automatic Washer showing error code 35?
Hello This would be a pressure sensor failure.
Will need to be replaced.Whirlpool has them in stock or you can have a service person come out.
Jul 31, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine does not spin on spin cycle,only hear a humming noise.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 27, 2011 | Kenmore Washing Machines
WONT SPIN OUT WATER. HUMS
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Dec 24, 2010 | Maytag Neptune MAH5500B Front Load Washer
Extract not working...motor humming...wash is normal..
heatman101
Dec 13, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer won't spin making a humming noise
heatman101
Sep 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Will not go into spin cycle
machine just quit while washing the code F-21 showed up
Aug 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
F 35 light on Kenmore Washing Machine
am sorry but F-35 is not in the record.
If this is a different F# please e-mail us back
I will be more then happy to assist you
"Was this helpful?"
Apr 02, 2009 | Kenmore HE2 Plus Front Load Washer
Washing Machines Logo
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
