Question about SanDisk Sansa Clip MP3 Player
Problem my sansa 2gb mp3 clip switch on the player to display the message not working"not enough space for music db plese free 30 mb" plese help how to solve the problem???
  • 8,596 Answers
Reformat
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 28, 2008
How do I delete 30mbs from my sansa clip the message is: not enough space for music DB. Please free 30mbs
The player needs free memory to build its database for playlists to playback.
To free memory on your player:
1. Connect to a computer
2. Save a backup of (preferred all) songs to a location on the computer
3. Delete some files off the player to free at least 30 MB memory in the Sansa Clip
Use the manual for how to connect and delete music files.
Clip manual:
http://mp3support.sandisk.com/sansa/UserManual/CLIP/CLIP_UM_English.pdf
Need more help ? Just add a comment in this thread.
May 21, 2010 | SanDisk Sansa Clip MP3 Player
Cant remove 30 mb
try looking on a differnt site!
Jan 14, 2010 | SanDisk Sansa Clip MP3 Player
The player tells me there's not enough free space for music DB and I need to free 30 mb. At that time the player was empty. I've erased the disc and it still gives me the same message. What's the deal.
try formatting the disk and then if that doesnt work run a scandisk check on it.if even that doesnt work,use sansa updater that may have come in the CD provided alongwith the player.
Sep 06, 2009 | SanDisk Sansa Clip MP3 Player
"Not enough space for music DB. Please free up 30 MB"
The mp3 manufacturers are often being disingenuous - they plug an mp3 player into a Macintosh, and it shows up, so they say, "Hey! It's Mac-compatilbe!" But, the software is certainly not Mac-compatible, so if you ever experience a problem, there is no way to fix it. Also, the Sansa e200 series does not recognize iTunes format.
In general, I would agree that you need to reformat your player, but I have no idea how to do that on a Mac (I'm good at a lot of things, but I'm Mac-illiterate).
-Tha Mp3 Doctor
Mar 15, 2009 | SanDisk Sansa e250 MP3 Player
MP3 not switching on.
I don't know exactly what's wrong but i'm on a hitch just connect the sansa to the computer delete 40 mb and it should work good luck
Jan 10, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
Not enough space for music db Please free 30 MG
Had this same problem. You need to lock turn off the player. put it into the locked mode and hold down the middle button before plugging it in. Then back up and reformat.
Detailed instructions I found were here:
Frozen sansa clip
Dec 26, 2008 | SanDisk Sansa Clip MP3 Player
Error Message
Remove the microSD card and then delete one or more files from the Sansa's internal memory to free up an additional 90MB.
Jul 02, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Not working
Follow these steps.
Put the player in MSC mode. You can do this by turning on the hold
switch before connecting to computer. Also can be set in the settings,
USB of the player menu.Turn on the hold switch and plug the m250 into
your computer. Find the Sansa removable device under My Computer.
Right click on the Sansa icon and select Fat32 from the list. Then
select format.
Hope this helps
Please rate accordingly
Thank you
Computerrep
Apr 24, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
191 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
