Question about Nokia Cell Phones
Display not working ribbon cut only kepad light show
    Sergeant:
  • 237 Answers
You will need to have your flex cable replaced. This repair averages $30 at most repair shops.
CommCentral
Posted on Jul 29, 2010
Nokia1616 no lcd light & no kepad light....
To fix this you need to contact a mobile technician.Anyway if you can do follow this link and see the emage.1616 light ways - Google Search.Good luck
Mar 13, 2012 | Nokia 1616 Cell Phone
Trio will not play, when I turn on the player, the screen is totally white.
Remove the back cover
(there's 1 screw on the left side. Remove it, then slide back cover to the left)
Look for the ribbon connector that connects the display to the circuit board.
(it's about 1 inch wide)
Lift up on the black part of the connector to release the ribbon.
Pull it out, inspect, and then re-seat the ribbon connector.
If this didn't fix your problem, try pressing lightly on the connector while looking at the screen.
If the video shows up by applying pressure, find some thin rubber (or equiv.) that you can cut & glue to the top of connector.
The idea here is the rubber will act as a shim when the back cover is on, pressing on the ribbon connector.
I suppose that the proper way to fix this problem is to replace the connector and maybe re-flow all the solder connections, but good luck with that!
If none of the above works for you, you might have a cracked circuit board. Again, applying light pressure to the right spot might help you find it.
GOOD LUCK!
Jan 29, 2011 | Mach Speed Trio TCH843 MP3 Player
The screen is white whenever i turn it on
GOOD LUCK!
Jan 23, 2011 | Mach Speed Trio TCH843 MP3 Player
W580i display light solution
w 580 i display light solution onley kepad on
Oct 28, 2010 | Sony Ericsson w580i Cellular Phone
display not working ribbon cut only kepad light show
Jul 29, 2010 | Nokia N95 Cellular Phone
I HAVE NOKIA N95 WHICH GOT A PROBLEM,THE SCREEN AND THE SURROUNDING BUTTONS,WHEN I CLICK ANY OF THE SURROUNDING BUTTON,THE SCREEN DISPLAYS LIKE THE INK IS FINISHED.AND EVEN SOMETIMES IT JUST ADD THE LIGHT...
format your cell phone by applying this code *#7370# then check if the problem still there then your mobile phone's sliding ribbon got cut there fore the display is not working change your cell phone display ribbon from mobile repairing shop
May 25, 2010 | Nokia N95 Cellular Phone
My sony ericsson Z310i cellphone has now a blank grey screen
I fixed my daughters phone last night by doing this.
This is a simple connection problem, that occures at either end of the ribbon connection at the top right (looking from the back of the phone)
you need to take the phone apart the screen side and the kepad side.
pull the connector ribbon out of both ends and then ease the screen out of the casing.
re connect the screen ,making sure to push it in firmly.
then connect the other end of the ribbon.
Now connect the battery terminals and turn the phone on.
The screen should light up and resume normal function.
Nov 03, 2009 | Sony Ericsson Z310i Cellular Phone
Samsung SGH-E800 nodisplay
Can u Help me.
How to remove slider.
In my mobile the display ribbon connector was cut so i do not know how to remove slide to change the ribbon connector.
Can you sent picture regarding servicing (to remove circute board and slider.
Thanks
Jan 27, 2008 | Samsung SGH-E800 Cellular Phone
Outer Display Failed. Panasonic PV-L454D
I have one that fell in my dam pond. If you would like to sell instead of toss let me know. boom499@hotmail.com
Nov 28, 2007 | Video Cameras
Kenwood kdc-322 faceplate problem?
I found my Kenwood KDC322 faceplate doing the same thing(cutting out) I cleaned the contact points on this 'ribbon' behind the faceplate by rubbing the discoloration off with a pencil eraser. The lights have not cut out again.
Apr 04, 2007 | Kenwood KDC-322 CD Player
Cell Phones Logo
Top Nokia Cell Phones Experts
270rexton
270rexton
