Question about Canon PIXMA MP160 All-In-One InkJet Printer
Dropped ink cartridge into machine, can't get it!
I dropped ink cartridge into machine, can't get it! I had difficulty removing them and have no manual. But now one is floating around in there. Can I open the beast further without problems?
  • Canon Master
  • 6,826 Answers
I would definitely open it up, unless it's under warranty.
Get some long kitchen tongs to try to remove it, after you remove the power cord to it, so it won't short anything out.
Posted on Jul 29, 2010
Indicates black ink empty when its not.
Try removing the cartridge and shaking it. Brother printers use an optical ink monitor with a float inside the cartridge. The float can get stuck sometimes and indicate incorrect ink level.
But keep in mind that printers often indicate 'empty' (on purpose) while there is still bit of ink left in the cartridge, to prevent running out of ink during printing. If shaking doesn't help, replace the cartridge.
Aug 25, 2014 | Brother MultiFunction Center MFC-440CN...
How to change all the ink cartridges at the same time because I was unable to remove some ink cartridges. The whole cartridges cannot be fully exposed.
Here are instructions on how to change the printer cartridges in an Epson Stylus. First open the printer cover. Look for the button with the picture of the ink drop on it. Press the button but do not hold it down for more then ten seconds. At fifteen seconds the align print cartridge function comes on and this will interfere with changing your cartridges. When you push the button with the picture of the ink drop on it, it will make the machine line up the cartridges in an area that you can reach easily. Then just remove the one you wish to replace. Use these instructions each time you change the cartridges.
Oct 01, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Waste in tank
If you drop the cover the machine will send the cartridge holder across to the far side of the printer
At that point switch the printer off and by using a torch you will see a heap of nearly solid ink which has been deposited by the cleaning blades into a trough where the ink cartridge normally sits.
Pair of surgical gloves and a small lolly stick or wooden spatula normally does the trick
Jul 03, 2009 | Canon MultiPASS MP360 All-In-One InkJet...
Correct cartridge for HP 2610 all in one
Those are the correct cartridges..I use them as well.. Is the black carriage beneth the cartridges dropping down when you lift the lid? If it is not you may be on the verge of experiencing the ever so pain in the **** carriage error. Look this error up and follow the directions for checking the sponge beneath the black carriage. When I started experiencing a problem with swapping cartridges I found that the sponge that is underneath that catches the excess ink was starting to bunch up which in return did not allow the carriage to drop down all the way.
Jun 13, 2009 | HP Photosmart 2610 All-In-One InkJet...
Not recognizing ink cartridge
On the clear side of the cartridge, put a piece of electrical tape to cover the center plastic bar that sticks out. For some reason these printers have a big problem with sensing ink levels. The tape lets the sensor think the cartridge float inside is up, meaning a full cartridge. The sensors seem to have difficulty reading where the black float is inside the cartridge.
Jan 30, 2009 | Brother Multi-Function Center MFC-240C...
Printer Head needs removal to clean dried ink
Not a cleanable type head, filiment gets burnt, when ink is not around it when printing is done. Ie dodgy ink blocks lines or has air in it and has permanently stuffed the print head, fix on brothers is replace head, cost excessive.,..time for the bin and the newfound wisdom that inks aint just inks.
Ink empy or no inks is read in ink well compartment via a black flag in ink cartridge that must be up and floating as not to obstuct photocell in well area.. check the rectangler bump in rear middle of cartridge. All cartridges must have flags up ie not empty, seeing ink does not indicate a cartridge with ink, a little is always left to prevent air entering system, hence machine calling out no innk cartridge to prevent damage...
Jan 26, 2009 | Brother MFC 420CN All-In-One InkJet...
Having difficulty removing ink cartridges from dell 944 printer
I am very sorry but the Z4M Zebra Printer doesn't use Ink Cartridges, it uses a ribbon to transfer ink via thermal transfer.
Jan 07, 2009 | Zebra Z4M Printer
Dell 725 printer no manual need to change ink cartridge
Here is the manual
http://support.dell.com/support/edocs/systems/725/en/index.htm
Replacing an Ink Cartridge
  1. Turn on your printer.
  2. Lift the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Close the front cover.
Feb 09, 2008 | Dell 725 InkJet Printer
Screen reads "Near empty Cyan" but I just replaced the Cyan ink cartridge, its full.
If the firmware update doesn't work, you can reset this error.
Unplug unit. Remove offending cartridge. Plug unit back in, wait until all startup noises have stopped. Open lid and reinstall cartridge. This will solve the fault as long as the sensor is working.
Also, please be aware, you should not have to change a cartridge if it says "Near Empty", only if it says "Ink Empty Magenta".
Also, please make sure none of your other cartridges are empty. I have seen this over and over. Two cartridges empty at the same time, and the person replaces one of them but thinks they actually replaced the other one.
Turn the power off and pull all the cartridges out. Look a the side of the cartridge, you should see a window with a little plastic tab sticking out. This tab should be blocked by a black float inside the cartridge. If you cannot see the float, and the tab is clear with no ink in it and no float tab blocking it, it means the cartridge is empty even if you still see some ink in the bottom.
To be sure plug the machine in without any cartridges. When all the noises have stopped, open the lid and install the cartridges. If you're still getting an error saying either a cartridge is not installed or is empty, then one of your cartridges is empty. Redo the previous paragraph.
Oct 05, 2006 | Brother MFC-5440CN All-In-One InkJet...
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
old marine
old marine
