Question about Maytag 15 cu. ft. / 425 liter Upright Freezer MQU1556A
My upright freezer is freezing on the bottom but not on top. It also is leaking water on the front corner of the freezer. Upper portion of the freezer is now at 50F
  • jgrich2020 Jul 29, 2010
    Thank you for the help. This is what I was looking for.
  • 11,800 Answers
The water flows to the front because the evacuation hole at the back is blocked by dirt - clean it.
There are 2 possible causes for your freezer's problem:
1 - the coolant circuit is leaking and the fluid is lost = the freezing capacity is slowly dissapearing and will be totally gone very soon. Now it's still freezing at the bottom because the cold air is heavier then the hot air and settles down.
2 - the valves/thermostat commanding the circuit for the upper freezer are defective and they don't sent coolant to it = the upper freezer is not operational.
In either case a pro must inspect and repair the unit, this isn't what an average customer can fix.
Posted on Jul 29, 2010
Top shel and top door shelfs are not freezing food solid ... Bottom freezes , all food on top portion thaws
you may have ab ad fan inside the cooler and all of the cold air is staying at the bottom. Also there may be bad insulation at the top and there may be warm air up there.
Jan 11, 2016 | Amana 20.1 cu. ft. Frost Free Upright...
My upright frost free freezer is leaking water onto the floor.
Hello;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number so I can only be general. Your model number is on a label on the upper side wall.
You have one of three problems.
1.) A bad defrost timer.
2.) A bad defrost Heater.
3.) A frozen drain.
4.) A obstruction/leak - Large block of ice in the upper right hand corner of your cool coil.
Mar 12, 2015 | Frigidaire Freezers
Maytag upright freezer will not drain and water will freeze in bottom. How do you repair Model CFU2046ARW
Check your door/'s are sealing if they leak u will get freezing occurring in the bottom and around the door will have allot of condensation.
good luck all the best . P's always lay liquid bottle on their side as they will cool quicker and be better on electricity.
Apr 04, 2014 | Frigidaire 20.6 cu. ft. / 583 liter...
I have a large upright freezer (Frigidaire) model FFU17FC4AW2. It is leaking water out the corners or the front door. It looks and sounds fine. What is wrong with it and can we fix it? If so, what do we...
Blow out the drain at bottom of coils also it might be frozen ice inside the drain.Pour hot water in the drain tray and wait
If this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 07, 2010 | Frigidaire 13.7 cu. ft. / 388 liter...
I have a maytag upright freezer. It is on the coldest setting. A bowl of water on the bottom shelf freezes overnight. The middle one is freezing, but not entirely. The top one is still water, but cold....
check to make sure door seals are touching the frame all round, could be an air leak,also make sure there is no ice build up around the inside casing. if so fully defrost unit,clean all vents/drain pipe, then turn back on and leave it for 24hrs (freezers work beast when full).....and door shut..how many times have you closed door after them????
Mar 01, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
Upright freezer. I can put a cup of water in the
Is any thing infront of the fan or vents?
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 17, 2010 | Freezers
GE upright freezer
If this is a frost free model the fan could be bad. If not frost free it is probably low on freon. I don't recomment fixing this as you can never really trust the freezer again. Most of the time the leak can't be found and adding freon is only a temp solution.
Jun 24, 2008 | GE 16.7 cu. ft. / 473 liter Upright...
FRIGIDAIRE UPRIGHT FREEZER ONLY 2 BOTTOM SHELFS FREEZING
someone suggested to me the other day to put weter foods closer to the top the ones with dripin water and more solids down at bottom they said this changes the climate inside to be more economical
im just passing this info cause ive never had or been in contact with a upright freezer
May 13, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Not freezing equally
Look for frost build up on back wall at bottom the auto defrost may be out. Check if the evaporator fan is blowing. If not it's stuck by something or needs replaced. If not The sealed system may have a leak or restiction causing it to only work closest to the evaporator i.e. the lower shelf.
Apr 22, 2008 | Frigidaire Freezer 16.7 cu. ft. Upright...
Freezer not keeping items completly frozen
thius suggests the defrost system not working and the defrost drain blocked. take off the back panel inside the freezer, melt off excessive ice and free the drain at the bottom with hot water and patience
Apr 30, 2007 | Frigidaire 13.7 cu. ft. / 388 liter...
Maytag 15 cu. ft. / 425 liter Upright Freezer MQU1556A Logo
100 people viewed this question
Top Maytag Freezers Experts
John Tripp
John Tripp
christian nielsen
Ismael Rodriguez...
Are you a Maytag Freezer Expert? Answer questions, earn points and help others
