Question about Cooper Wiring Devices 1301-7B GROUNDING SINGLE POLE TOGGLE SWITCH
HI i have just removed the wiring from a 13 pin connector for a trailer i have fitted it with 7 pin connector. i have used the colour coding for a 7 pin connector using the white black battery, blue brake control output, yellow left brake and turn, (purple-looks pink, reverse lights, yellow left brake and turn, brown tail and running lights. all not working correctly. i am wondering if the colour codes are different from a 13 pin?
3 Suggested Answers
  • 30 Answers
SOURCE: I have a ceiling fan with a light that is
First, turn off the circuit breaker. The three wire bundle should be the incoming power, the four wire bundle should be going to the fixture. Using a duplex switch (one with two toggles), the incoming black wire goes to one side of the switch, the outgoing black and red wires go to separate terminals on the other side of the switch. The whites are connected together. The Grounds (or bare copper) are connected together and to the switch ground screw. Hopefully both the outgoing read and black were connected to the old switch or you may have to rewire the fan to wire up the fan and light separately.
Posted on Jul 09, 2009
  • 8404 Answers
SOURCE: I have a live 2-wire line that used to be
As I understand it you have a live circuit going to a light fixture that had a switch built into it. You have removed the fixture and now you want to run this wire to another location and install a switch in the circuit.
You will be extinding these two wires (white and black + ground) to the new location. No problem ... Somewhere between where you start and where you finish, you will break the black wire and install a single pole switch. All connecctions must happen inside a electrical box.
So, install the new wire in the box where you will start your extension. Run to the new switch box. You dont even have to cut the white wire. You will wrap the green or ground around the ground screw on the switch, Cut the black wire . put one end under one side screw, put the other end under the other side screw. From this box run your wire to the next box where you will install your fixture.
If you are using metal boxes, they must be grounded to the circuit. You can use pig tails for this, Best deal is to use plastic boxes that dont require grounding.
I hope this answers your question
Posted on Oct 18, 2009
What are the correct wiring colour codes for the rear lighting circuits, so that I can tow a caravan?
under no circumstances cut any wires
the trailer plug is generic so proper trailer wires will have the correct colors for the plug pin numbers
by using a multimeter or circuit light you can determine which wire in the block is live and then connect the corresponding color in and then to the correct pin number in the plug
probably quicker if you get a tow bar shop to fit the plug for your
takes around 10 minutes to fit the correct harness that they will have
Apr 28, 2017 | 2007 Mitsubishi Outlander LS
Wire colour code
Dec 28, 2013 | Cars & Trucks
I have a 1997 Tahoe 350 4wd. I just need the wiring diagram for the trailer hitch. The wires are there but there is no connectors. I have also found the orange and blue wire for doing the electric...
please dont ask me iam colour blind ,but to overcome this i use a multimeter or a little light and test for current this way ,going by the so called wiring colours is a disaster for me not only the colour thing but the wireing can change colours owing to different suppliers of looms in manufacture ,they run out of one colour and use another ?? you name it i think i have seen it
Aug 22, 2013 | 1998 Chevrolet Tahoe
Please help western australia.britax trailer lights not connected properly.this is how currently connected.left hand trailer light top pin yellow,side pin green,bottom left pin brown,bottom right pin...
plug wiring is in
the following web site
ww.narva.com.au
the site is very specific for 7 pin , 6 pin and rectangular to round 7 pin
the small tag that you have to use to put the plugs together is identified at the top oh the round plugs
you can get the site by googling and typing in ---trailer plug wiring australia
Apr 02, 2017 | GPS
I have a 96 ford explorer xlt with a hidden hitch. the 7 pin rv connector is not working. i found where the wires from vehicle connect to 7 pin connector and one wire was caroded at the crimp black wire...
Yes, you need the other wires to provide the trailer with battery voltage. If the trailer has trailer brakes, you should have an RV mechanic wire up the connector so the brakes on the trailer operate from the Ford.
Mar 11, 2011 | Ford Explorer Cars & Trucks
What are the wire color codes for a 4 pin trailer connector on a 2010 ford f150
hi i have got a w reg ford fiesta what is the colour code for the wires from my trailer lead to my car lights please
Nov 07, 2010 | Ford F-150 Cars & Trucks
No trailer right turn signal or brake light
Hey Boon,
The pinouts for a 7-way plug are as follows:
Seven wire Trailer plugs:
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
In both cases 4 is battery and 7 is reverse, aux or not used.
Double check your wiring using these lists as a reference.
Click here for my post on Trailer wiring
This should get us closer to the answer.
Best regards,
Mike
Sep 08, 2009 | 2004 Dodge Ram 2500
Tow bar trailer socket wiring connection point to car wiring?
The connectors for towing wire harnesses on foresters are generally on the passenger side, below the rear taillight inside the cargo space. some require pulling up the foam block that is between the spare tire compartment and the taillight. Check where you replace the tailights from inside the car, if there isn't a matching connector hanging out there, check around the spare tire compartment, see if you can remove the carpeted foam block next to the compartment and find the plug under there.
Jun 03, 2009 | 2006 Subaru Forester
Wiring for a trailer
u must install the fuses for the system in he underhood heavy duty fuse box, it will be marked trailer tow
Mar 17, 2009 | 2006 Ford Escape
LG 17'' LCD Monitor VGA 15 pin connector pin diagram
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Nov 17, 2008 | LG Studioworks 700S 17" CRT Monitor
Cooper Wiring Devices 1301-7B GROUNDING SINGLE POLE TOGGLE SWITCH Logo
60 people viewed this question
Top Cooper Wiring Devices Electrical Supplies Experts
Steve
Dennis Boxerman
Are you a Cooper Wiring Devices Electrical Supply Expert? Answer questions, earn points and help others
