Question about Garden
The cutting head on my bolens bl160 2-cycle trimmer will not cut grass. The cutting head still turns, but when I try to cut grass the head will stop moving, but the engine is running fine?
The clutch is fouled with assembly grease. Separate the boom from the powerhead, then use a T20 screwdriver insert into the clutch drum. Remove spark plug and insert a small length of rope to hold piston, now remove screw in clutch hub. Slide off clutch hub and clean with soap and water. If excessive grease is on end of boom drive shaft remove the excess but leave a little. the rubber clutch shoe works by stretching with faster engine rpms.
Posted on Sep 13, 2010
Why did my weedeater lost power when trimming on grass but still spun?
There is a cable that runs from the motor to the trimmer head check that. Remove trimmer b.y removing small screw at the base of trimmer head
Aug 05, 2014 | Troy-Bilt 25cc 2-Cycle Curved-Shaft Gas...
What causes the trimmer head to stop turning when it starts cutting heavy grass?
Check out the drive unit from the head of the motor down to the trimmer head it may have a problem.
Jun 27, 2014 | Troy -Bilt String Trimmer/Blower...
Yard machines trimmer. 4 cycles
Victor you need to invest in some copper grease. This will stop it getting to hot and jamming when it expands with the heat.
Apr 26, 2014 | Yard Machines Garden
What could be causing this?
to much dirt got up in clutch housing and shoes are not making full contact unit needs to be dissembled and cleaned.
Sep 06, 2012 | Garden
Troy Bilt TB575EC cutting head hard to load, now doesn't spin.
Remove the cutting head spool and see if you have old grass stuck around the shaft area that could be causing to cease your shaft..
Mar 03, 2018 | Troy-Bilt 4 Cycle Straight Shaft String...
I have a Bolens BL110 Trimmer - it starts just fine, but won't rev up completely. Suggesstions?
Could be blocked spark arrestor or carboned up in the exhaust port.
May 06, 2012 | Garden
Stihl strimmer engine runs but wont cut grass the head wont turn what cuts grass
First take the head off and look for grass, weeds and string wound up in there. A lot of times that's the problem.
Next, with the head off and the switch in the off position, pull it over a few times and see if the shaft spins. If not, could be a broken shaft or a bad clutch.
Apr 04, 2010 | Oregon Scientific Complete Carburetor for...
String trimmer cutting attachment doesn't turn fast enough
Take the shaft off at the motor,see if any thing is worn there.Also,take head off of end of weed eater,check for grass or any build up in there.
Aug 29, 2009 | Troy Bilt Tb70ss Gas Trimmer
Garden Logo
489 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
